12-22-2020, 09:44 PM
CBI front skid?
I am considering replacing the factory front skid plate for a CBI off road. My factor skid has been fine and is still in great condition. The main reason Im considering CBI is because it looks like you can change the oil without having to remove the entire skid. For those that have it is it worth it? Does it make changing your own oil easier?
12-22-2020, 10:19 PM
hmmm thats a hard one to say...paying a few hundred more to make it easier...I will say it made my life A LOT easier lol. There are also other skid options that could be cheaper. Can't recall but CBI shipping used to be pretty darn expensive. Most aftermarket skids have an access port for the filter.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
12-22-2020, 10:55 PM
CBI shipping to AZ was I think $325 when I checked a few weeks ago.
Most skids other than the TRD allow you to change the oil with out full removal. I went with CBI
I'll agree with that, for whatever reason CBI shipping rates are ridiculous. The best you can do is buy a CBI product through a reseller/retailer that will charge significantly less for shipping or even for free.
@ TheJokingExplorer
you should contact running4tacos shop to see if they can get you a CBI skid locally and that way you can avoid their shipping rates
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
12-22-2020, 11:09 PM
Originally Posted by sn_85
I'll agree with that, for whatever reason CBI shipping rates are ridiculous. The best you can do is buy a CBI product through a reseller that will charge significantly less for shipping or even for free.
@ TheJokingExplorer
I just saw that SDHQ has them and their down the road from me in Gilbert AZ.
12-23-2020, 12:12 AM
Sounds like you found a good deal if you can drive over and pick it up locally. As others have said already -- most aftermarket skids make it easy to do oil changes. CBI, RCI, LFD, C4 and 4x Innovations to name a few. Personally, I'll probably end up with a set from LDF because of the $75 shipping. I also like that there is a hole for the engine oil drain plug and a plate for the oil filter instead of having two plates to remove.
[ Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo Open Country A/T III 265/70/17 (TE Wheels) | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs (Amber) | Diode Dynamics XPR Backup LEDs | Lasfit Blinker LEDs Front/Rear | Several big items on backorder... :
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Diode Dynamics LEDs (throughout)
12-23-2020, 01:12 AM
If youre using your skids that little convenience oil filter door will be useless eventually
'12 Silver 4Runner SR5: 14+ facelift, Pelfreybilt front, CBI Rear, Warn M-8000S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, Icon CDCV suspension w/UCAs, OME 899, Nitto RG 285s, Full RCI Skids, Metaltech Sliders, Gobi Rack, ARB Awning, Rotopax,1up Hitch Rack
Xtremluck's 2012 SR5 Build Thread
Instagram - @Aperture20
12-23-2020, 01:15 AM
That just makes it more convenient!
12-23-2020, 08:53 PM
Haha true. Dented that oil door and sheered off the bolt for it. Now I just take off the skid every time.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
