Old 12-22-2020, 09:58 PM #1
4RFritz 4RFritz is offline
4RFritz is on a distinguished road
2020 Auxiliary lights behind grill
I've just searched for 39 minutes and haven't found anything that helps - but has anyone added auxiliary lights behind their front grill on each side of the TSS? It looks large enough to add some auxiliary lights.
Loving my 2020 ORP and upgrading the fog lights to amber Baja designs next, but if I have the front end open, looking at grill lights, too.
2020 Auxiliary lights behind grill-4runner-jpg
4RFritz is offline   Reply With QuoteReply With Quote
Old 12-22-2020, 10:15 PM #2
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
I've seen people add lights there. Here is an example-->
Login • Instagram
(not a 2020 though, Mocha MA44 light pods. Would recommend something else though like an SS3).
Have also seen folks add DD SS3 behind the top grill. Output looks good.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 12-22-2020, 11:13 PM #3
[QUOTE=SpeedyKevin;3582787]I've seen people add lights there. Here is an example-->
Login • Instagram
I like that one, thanks for sharing.
I added a transmission cooler in the middle behind the TSS, and some tubing that I have to tend with, so I was thinking like you, something slightly smaller like the Baja Designs LP9, 6 or 4, or the DD SS3. I have seen some brackets for a light bar for pre-2020, but not sure how it would connect. It's one of those issues where I don't want to have to order a custom bracket when I have the front taken apart, as I don't have tooling to fabricate a bracket.
Old 12-23-2020, 12:49 AM #4
[QUOTE=4RFritz;3582809]
Login • Instagram
Took awhile to find some pics of Tory's SS3 set up. Might night work well if the 2020+ as it has the chrome? part in the upper grill. (Tory if you're reading this, please send your wiring diagram for the switch!)
https://www.toyota-4runner.org/3461632-post35.html
Old 12-23-2020, 03:44 PM #5
I thought about the upper grill, but on my 2020 ORP, it's got those dumb chrome logo wings, and it's not ideal. I'm thinking I could add the baja designs cross bar light bracket in there, then find a way to either add a cross bar (instead of an LED light bar) and then install from there. I just think it's not ideal.
Old 12-24-2020, 05:20 PM #6
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
NFab has a light mount that goes behind the grille and lets you bolt whatever lights you want to it. I've found a post on another forum (link below) where he used it to mount some lights behind the grille on his 2020. Looks pretty good I think. Looks like there might even be room to put two pair in there...maybe some spots and some wider pattern driving lights or something?
LBM Bumper Light Mounts | Light Mounting - N-FAB | N-FAB
Behind grille lights with TSS | Toyota 4Runner Forum [4Runners.com]
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 12-24-2020, 07:57 PM #7
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
The one @SpeedyKevin posted is awesome. I love the look of the square lights up front behind the grill.
Off topic, I see you're from OR. I live in Beaverton if you ever want to meet up, hit me up.
Feel free to PM.
Doug
A10MileHusker is offline   Reply With QuoteReply With Quote
Old 12-26-2020, 12:15 PM #8
dakgildea dakgildea is offline
dakgildea will become famous soon enough
Rago Fab makes a hidden light bracket setup with mounting plate
| IG: daks.4rnr | 2018 TRD Off Road Premium | Dobinsons 302/505 700/705 | Dobinsons UCA | Shrockworks Angled Sliders | RCI Skids | C4 LoPro | Prinsu 3/4 |
dakgildea is offline   Reply With QuoteReply With Quote
Old 12-26-2020, 09:40 PM #9
JMN2116 JMN2116 is offline
JMN2116 is on a distinguished road
Just a FYI, you don’t need to remove the grill or any front end pieces to install the Baja fog lights. Only have to remove the inner fender.
2020 T4R TRD OFF-ROAD PREMIUM, RSG METALWORKS SLIDERS, BAJA DESIGNS FOGS, SCS F5 WHEELS, FALKEN WILD PEAK AT3.
JMN2116 is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 09:53 PM #10
Finally added some Baja designs lights, SAE for now. Also added new fogs- will look to maybe cutting grill to get more light output. Or I might get brighter lights... there’s room where they are and moving outward, but time to see how they work for a bit. Thanks for all of the advice folks.
2020 Auxiliary lights behind grill-09843504-0228-494b-85a0-caef1ae5dafb-jpg
Old 02-25-2021, 11:07 PM #11
mrluilou mrluilou is offline
mrluilou is on a distinguished road
I placed some BD LP6's behind my grill
[IMG][/IMG]
Instagram- Mrluilou
mrluilou is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 11:13 PM #12
Real Name: Doug
Real Name: Doug
Looks good! I need to figure something out to get lights back there. I have a hidden winch so I have to get creative on some mounting points.
Sent from my SM-G986U using Tapatalk
Old 02-25-2021, 11:36 PM #13
Looks good! What mount/s did you use?
1998 BMW M3/4/5
Old 02-26-2021, 12:07 AM #14
Big thanks! It’s some bent steel stock, holes in it, painted and attached to middle grill / frame support. Super strong, versus trying to come from the outside in. I couldn’t find a good mount when I searched.
Old 02-26-2021, 12:08 AM #15
[IMG][/IMG]
That’s soooo sexy!
add , auxiliary , front , grill , lights
Grill upper/TRD pro heritage grill installation info (2020) Gamma Ray 5th gen T4Rs 0 08-25-2020 10:19 PM
Auxiliary Lights RHP4R Engines / Suspension / Wheels / Tires / Audio / Accessories 7 09-20-2011 05:49 AM
WTB: Auxiliary Lights sheik Want to Buy/Trade 6 05-13-2010 12:16 AM
Auxiliary Lights sheik Engines / Suspension / Wheels / Tires / Audio / Accessories 12 11-03-2009 11:54 PM
Auxiliary Lights 4Run97 4th Gen T4Rs 4 01-01-2007 12:17 PM
