Old 12-24-2020, 11:41 AM #31
Sp00ner's Avatar
Sp00ner Sp00ner is offline
Sp00ner will become famous soon enough Sp00ner will become famous soon enough
Sp00ner's Avatar
Originally Posted by whippersnapper02 View Post
viscosity doesn't matter as long as you run the power trio mix of slick 50, prolong and lucas oil stabilizer in with the oil.
but does it have enough zdp in the oil?!?!?!?
RCI Sliders & TRD Integration, Transmission and Transfer Case Skids
Eibach TRD Pro Lift, 285/70/17 KO2s
TRD Intake, ARB Breathers
Pioneer 8500NEX
Sp00ner is offline   Reply With QuoteReply With Quote
Old 12-24-2020, 12:29 PM #32
Whippersnapper02's Avatar
That's rocket fuel.
Old 12-24-2020, 11:51 PM #33
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Originally Posted by Nobody Special View Post
In another decade, it will be 0w10.
A decade after that -5w0
I had to look into this a little. On the BITOG site I saw that Pennzoil is already producing a 0W-16 for turbo direct injection engines. And they said they will produce a 0W-8 if OEMs want, in this FAQ:
0w-16 & SN Plus - Bob is the Oil Guy
“ 21. Is Pennzoil going to produce a 0W-8 oil?
OEM’s have shown varying interest in these lower viscosity oils. Although no recommendations are yet made by OEM’s for this grade, Pennzoil will be ready when they are approved and ready for use. PurePlus base oils were designed with such considerations in mind.”
Old 12-25-2020, 12:42 AM #34
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
Wow. And I was sort of kidding.
Maybe go back to steam engines.
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 12-25-2020, 01:09 AM #35
It is not in a vehicle manufacturers best interest to make things that last 250k+.
Hence why Toyota doesn't treat chassis like older Land Rovers.
It's a Catch 22 though.
Buy a new car every 100k is wasteful, but they can also force in more strict EPA crap with ease.
Basically ruining the gas engine to force electric?
Once warranty is up, POOF!
Time to support the "boutique" oil companies so they don't fold and you have no better options.
Old 12-25-2020, 01:11 AM #36
From 2015.
0w8 and 0w16 engine oils! | Charger Forums
Discussion Starter • #9 • May 27, 2015 (Edited)
You can see by the chart that the new 0w16 weight oil at 150 degrees C (302 F)....... the standard of 2.6 minutes has been reduced to 2.3 minutes. The high temperature and high shear is not going to be able to withstand the long term temperatures on a stock engine let alone modding it for performance. This is what we are saying is that OEM is strictly for mileage and emissions and the rest of it is going to be at the expense of longevity. There is a 13% reduction in kinematic viscosity at 100 degrees C (212 deg F) While viscosity isn't film strength, there is a limit to what additives can be added to these lubricants.
"High temperature high shear (HTHS) viscosity of engine oils is a critical property that relates to the fuel economy and durability of a running engine. The drivers behind lowering HTHS viscosity are new global governmental regulations to improve fuel economy (FE) and lower greenhouse gases (GHG) in new vehicles. Lower HTHS viscosity tends to improve FE and lower GHG but higher HTHS viscosity affords better wear protection so a careful balance must be found when formulating an engine oil. Sufficient HTHS viscosity is critical in preventing engine wear in the critical ring/liner interface area by maintaining a protective oil film between moving parts. One method used to measure HTHS viscosity is ASTM D4683. Oil is introduced between a rotor and a stator at the test temperature of 150°C. The rotor experiences a reactive torque to the oils resistance to flow (viscose friction) and this torque response level is used to determine the HTHS viscosity. HTHS viscosity by ASTM D4683 has been found to relate to the viscosity providing hydrodynamic lubrication in light duty and heavy duty engines. HTHS viscosity has also been found to relate to fuel economy. Think of the protective oil film as if you are trying to swim. If the film is too thick like molasses you can barely move and have to expend a lot of energy; too thin and you sink to the bottom. What you want is the right balance of support and ease of movement. The oil has to be thick enough to maintain separation of the critical moving parts but thin enough to allow for fuel efficient operation."
Old 12-25-2020, 03:48 PM #37
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Friend has a new Rav4 and it specs 0w16 on the oil cap.
seatia is offline   Reply With QuoteReply With Quote
Old 12-25-2020, 04:44 PM #38
Rainier42's Avatar
Rainier42 Rainier42 is offline
Rainier42 is on a distinguished road
Rainier42's Avatar
Really? Just purchased a 2021 Rav4 for my wife, will have to check to be sure I put in appropriate oil.
2020 Silver 4Runner Venture w/KDSS, sliding cargo tray, Falken WildPeak A/T3W 265/70R17 tires
Rainier42 is offline   Reply With QuoteReply With Quote
Old 12-25-2020, 04:48 PM #39
WD-40 or Kroil may work.
Kroil does smell nice.
Old 12-25-2020, 09:28 PM #40
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
I wonder what oil viscosity Scut Farkus would use?
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 12-25-2020, 09:43 PM #41
https://www.redlineoil.com/heavy-shockproof
(This stuff helped tremendously in my Rover D1)
Old 12-25-2020, 10:05 PM #42
tundradan tundradan is offline
tundradan is on a distinguished road
Surprised we haven't had the suggestion of adding Seafoam yet!
tundradan is offline   Reply With QuoteReply With Quote
Old 12-26-2020, 12:36 AM #43
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
It's too viscous compared to factory 0w oil.
delloro is offline   Reply With QuoteReply With Quote
Old 12-26-2020, 12:52 AM #44
Seafoam is good for 2 cycle engines.
Pretty much useless compared to other products in the price range.
Old 12-26-2020, 08:41 PM #45
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
It's been said before, but I'll repeat it:
Thinner oils are for mpg and CAFE, and offer less protection. [insert discussion about how additives take over when the film strength is insufficient here, with counter argument about how additives ultimately fail and also get depleted]
Also, manufacturers' vehicles get tested for mpg, and whatever oil they used for the testing MUST be the only oil recommended in the owners' manual.
But don't take my word for it, check out this EPA document. It's old but still applicable, sorry I don't have any updates:
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
5w20 , 5w30 , oil , vehicles , viscosity
Interesting view on oil viscosity captainnemojr Maintenance/Detailing 4 06-02-2010 01:15 AM
Gear oil viscosity f/r diff ? 2k3T4R Maintenance/Detailing 3 06-10-2007 03:13 PM
Oil change with mixed viscosity 1runner Maintenance/Detailing 5 02-11-2007 07:30 PM
What viscosity Larry Maintenance/Detailing 3 06-10-2005 01:38 PM
Oil Change and which viscosity? sire Maintenance/Detailing 13 02-16-2005 11:59 AM
