Old 12-26-2020, 06:42 AM #16
Deuxdiesel Deuxdiesel is offline
Deuxdiesel will become famous soon enough Deuxdiesel will become famous soon enough
I've been using a plastic milk crate under my skid plate when I remove it. Not perfect height but pretty close. The stud solution seems like a good one, but with as much cutting oil and then anti-seize I have used so far, cleaning out the threads enough so lock-tite would hold the stud might be a challenge. Maybe a thin jamb nut holding the stud against the frame?
Deuxdiesel is offline   Reply With QuoteReply With Quote
Old 12-26-2020, 11:58 AM #17
Saker's Avatar
Saker Saker is online now
Saker is a name known to all Saker is a name known to all Saker is a name known to all Saker is a name known to all Saker is a name known to all Saker is a name known to all
Saker's Avatar
Originally Posted by AMLOR View Post
If recall correctly these were either 40 or 45 mm long, 10 x1.25 thread pitch. (these are the same size and pitch as the factory bolts...nothing else will fit. These were 318 stainless studs.
These are also occasionally used as exhaust studs, so look there as well.
The threaded area on the frame is deep enough to get the studs adjusted to the perfect length for your application. Just requires careful measurement and some patience the first time.
The nuts were serrated flange nuts of the same size and thread pitch.
Amlor
Did you use studs that are of equal length on both ends?
Once screwed in, did you use locktite, if so which one.... blue or red (red one requires heat to remove part)?
Once the studs were installed, did they protrude past the bottom of the skid or did you have to cut them?
Best Regards,
Saker
2021 T4R *MIDNIGHT BLACK METALLIC* TRD OFF ROAD PREMIUM 4X4| Sakerís Ebony Build | Sakerís Previous 2014 Midnight Build | Scuba Mod | LED LIGHT BAR INSTALL | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Saker is online now   Reply With QuoteReply With Quote
Old 12-26-2020, 12:07 PM #18
Saker's Avatar
Saker's Avatar
I would be in the same situation, maybe a healthy dose of brake cleaner or something like CRC Electric Parts Cleaner. That should chase all oil and never seize from the threads.
The jamb nut would work if there is enough space without interference of the skid.
Best Regards,
Saker
Old 12-26-2020, 09:34 PM #19
AMLOR AMLOR is offline
AMLOR will become famous soon enough
Yes they were the same length on both ends, though the ones on the non radiator side were screwed in somewhat deeper (as far as they would go) and they still protrude a bit beyond the top of the flange nut...maybe 3/16 inch max.
Radiator side is only one thread beyond the top of the nut.
Yes, I used BLUE loctite on the stud end into the frame.
AMLOR
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, Whiteline, C4 Fab, BPF, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, Metal Tech, StrongBox, Eibach Load-Leveler rears & TRD Pro front coils, CE Auto Elect., Blue Sea, SP9100, Cornfed, RCI skids, BajaRack "basket", RIG'd Ultraswing, REV Gear 4.88's
AMLOR is offline   Reply With QuoteReply With Quote
Old 12-26-2020, 11:04 PM #20
Saker's Avatar
Saker's Avatar
AMLOR
That leaves me to question, Would studs with unequal length threads work better by tightening them all the way in and cutting off the excess after measuring proper length needed?
Best Regards,
Saker
Old 12-27-2020, 09:13 AM #21
Better? I would think the more thread we can get into the frame mounting holes the better...less chance of them getting ripped out with aggressive off roading. The stock bolts were 40mm in length if I remember correctly...
Old 12-27-2020, 11:54 AM #22
Saker's Avatar
Saker's Avatar
I was trying to remember just how deep the frame threads are and being able to bottom out the studs against the stud shoulder.....
IIRC, Maximum bolt stud / strength is achieved when thread contact is equal in length to the diameter of the bolt / stud.
So, if you have, 2 times as much bolt threaded in, does it offer more strength?
I'm just trying to figure out the most secure way so the Loctited studs would not back out (tightened in all the way to the shoulder as intended) when removed by me or by the dealer.
Best Regards,
Saker
Old 12-27-2020, 11:58 AM #23
rageandlove's Avatar
rageandlove rageandlove is offline
rageandlove is a jewel in the rough rageandlove is a jewel in the rough rageandlove is a jewel in the rough rageandlove is a jewel in the rough
That's a good idea. $5.89 at Home Depot. Worth a try. Thanks!
rageandlove is offline   Reply With QuoteReply With Quote
Old 01-01-2021, 07:12 PM #24
batman900 batman900 is offline
batman900 is on a distinguished road
I highly recommend chasing threads all the way thru until the tap exits.
Definitely use tap magic or some type of lightweight oil, remove debris from tap and threaded hole with brake cleaner or something to flush with.
This is what I did on my 14' & recently on my 21'.
https://www.toyota-4runner.org/1798124-post58.html
Update, ordered a better tap from Amazon "uxcell" along with the Irwin handle and tap magic cutting fluid. Went through like butter using 1 hand. Put the long bolts in without any issue and applied the permatex. TY TY
batman900 is offline   Reply With QuoteReply With Quote
Old 01-01-2021, 08:15 PM #25
simonov's Avatar
simonov simonov is offline
simonov is on a distinguished road
simonov's Avatar
Can you supply a link?
McMaster-Carr
Nunc est bibendum.
simonov is offline   Reply With QuoteReply With Quote
Old 01-02-2021, 09:21 PM #26
OK, that didn't work. Not sure if milk crates come in different sizes, but all three sides were too tall.
Fortunately, I discovered the 1-gallon distilled water jugs I have in the garage for earthquake preparedness are almost the perfect height, so that's the new approach.
bolt , lot , oil , skid , trd
5th gen T4R front skid plate/filler plate, Fort Worth TX Chubbypanda Want to Buy/Trade 1 10-05-2019 08:06 PM
Trd skid plate (kdss) plus rci Control arm skid plates barcainho 5th gen T4Rs 12 12-06-2017 04:30 PM
SoCal - Aftermarket 4th Gen 4Runner Skid Plate + Filler Plate - $250 boxtree619 For Sale: T4R Items 2 02-04-2017 10:00 PM
WTB Plate rear bumper and lift skid plate ebrake92 Classifieds - buy & sell (no commercial ads please) 0 03-15-2011 01:24 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
