Old 01-06-2021, 12:58 PM #16
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
Originally Posted by Eldirector View Post
Happy New Year to all and thanks again for all of your input and advice. I was able to install a 100 watt Renogy panel with a Victron 75/15 BT mppt and modified the brackets to bolt directly to me removable rack portion locations. The cables were a simple run down the side of the headliner as one tucks perfectly into an existing crevice that runs the length downward into the engine bay and I wired tied them to together. I did order the KC Hide a wire kit, but I didn't want to wait so I'll see if I install when it arrives.
I don't fully understand all the data coming into the Victron, but I do know that it is charging and cycles through the different phases: Float, Absorption and Bulk. I think that I know the answer to this one, but do I also need when of them "charge booster" diodes as well or as I believe doesn't this set up work around that?
Make sure you set the charge settings on the controller per your battery manufactures spec.
blksubykid is offline   Reply With QuoteReply With Quote
Old 01-07-2021, 01:13 AM #17
keph13 keph13 is offline
keph13 is on a distinguished road
FYI anyone doing this should look up gauge requirements - 10awg is way overkill for 100w - you only need 14 (since it's <10amps). The math works the same as in-house wiring. Also why I ran my two panels in series - they're nominally 12v panels, so that's 24v at 200w = 8 amps max, so 14awg is fine (and the whole setup puts out more like 50 volts in the sun - why you need a solar charger).
Not only are higher gauge cables a waste of money, if you end up running them through the headliner and around corners, the smaller gauge the easier time you'll have installing.
2010 4Runner SR5 4x4
keph13 is offline   Reply With QuoteReply With Quote
Old 09-28-2021, 06:10 PM #18
Titanpat57's Avatar
Titanpat57 Titanpat57 is offline
Real Name: Patrick
Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough
Titanpat57's Avatar
Real Name: Patrick
I've had a 100 watt Reneogy panel on my rack, with a 10 amp MPPT controller running my Dometic fridge that lives in the truck for 9-10 months out of the year. I've been running the same Northstar AGM group 31 for 5 years now.
No issues.
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
Titanpat57 is offline   Reply With QuoteReply With Quote
battery , install , panel , solar , trickle
OBD-II reader that doesn't drain battery if permanently connected? repo 3rd gen T4Rs 7 05-27-2019 08:13 PM
Trickle Charger on Dual Battery Setup Havik 5th gen T4Rs 11 03-29-2019 12:05 PM
AGM battery charge controller MikeYQM 5th gen T4Rs 41 11-25-2018 12:37 AM
Battery draining constantly + wipers permanently running Maui Cruiser Classic T4Rs 2 03-28-2016 06:26 PM
Low battery charge tjtowner 4th Gen T4Rs 6 12-15-2011 04:19 PM
