Old 12-27-2020, 05:43 PM #1
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
Fuel Pump “gurgling” noise - help please
Need help with Fuel Pump “gurgling” noise that I start hearing during my last camping\hunting with my family (truck currently has 82K on it)
Noise can be heard next to the rear left tire (engine idling), and definitely coming from the gas thank around fuel pump area. The noise can be described as gurgling, fluid with air bubbles moving through the pipe. I got under the truck and put my ear next to skid plate of gas tank-confirmed noise is coming from the fuel pump (at that point I had about ¾ of gas in the tank)
After coming home, I have pulled the gas tank skid plate, without skid plate the noise is essentially gone and only can be heard if I put my ear directly on the gas tank, and it is louder where the fuel pump is. (At that point I have about ¼ of the gas left). I have also open access panel (under rear left set) to fuel pump and I cannot hear any noise there, pump actually running very quiet there… and there is no noise from the gas tank fill-up neck with gas cap removed.
My question does anyone have any thoughts\idea if the noise I am hearing is normal or fuel pump is falling..? I know I may be asking too much… but can anyone get under the truck and put the ear on the skid plate next to fuel pump area and let me know what you are hearing?
I was planning long family trip real soon and that is why I am concerned.
Sorry for a long post and Thank you in advance!
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 12-27-2020, 05:51 PM #2
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
So the skid is amplifying the sound?
(BTW, You can amplify with a Styrofoam cup on your kitchen sink, and some transmissions, especially manuals and various other vibrating objects)
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 12-27-2020, 06:33 PM #3
progress4m's Avatar
progress4m's Avatar
That is definitely correct, without skid plate I can only hear it if I put my ear directly against the tank and the loudest part is where fuel pump is...
The sound doesn't sound normal to me, but maybe it was there for a very long time and I can hear it now because I did remove and reinstalled the skid (about month ago) after removing a small dent in it... so maybe the skid now is touching the tank amplifying the sound... and that is why I have asked if anyone can listen to their fuel pump... maybe I am lucky and it is "normal" sound for 4Runner fuel pump...?
Old 12-27-2020, 06:35 PM #4
CollinJ's Avatar
CollinJ CollinJ is offline
CollinJ will become famous soon enough CollinJ will become famous soon enough
CollinJ's Avatar
Have you checked to see if your VIN was included in the 5th Gen fuel pump recall from earlier this year? Could be related, or not but figured I would put it out there in case you hadn’t checked or were not aware.
2018 TRD ORP - Dobinsons IMS 3/2 lift, BFG KO2 285/70/17, LFD 7/8 roof rack, LFD Steel Skid, LFD Bump Out Sliders, TRD intake, Rago Molle Panels, Ellis Precision Shift knobs
CollinJ is offline   Reply With QuoteReply With Quote
Old 12-27-2020, 06:46 PM #5
progress4m's Avatar
progress4m's Avatar
I did check and since my 4Runner is 2013 it is not included... thx.
Old 12-27-2020, 07:39 PM #6
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
All modern cars recirculate the gas, that is, more gas is pumped to the engine compartment than is used. Any excess is returned to the gas tank by a return line. They do that to keep from having vapor lock. What you are hearing is probably the return fuel as it comes back to the gas tank. That would be normal.
fkheath is offline   Reply With QuoteReply With Quote
Old 12-27-2020, 07:50 PM #7
KSJ088 KSJ088 is offline
KSJ088 will become famous soon enough
Yep probably the EPA evap. I heard mine making a noise in the garage last week when I was going to mailbox. Never heard it before in the 2 years since new.
Take Off You Hoser
Boston Bruins #1 2018 TRD OR Super White, Few Mods: Tinted Frt windows,Eibachs Set @ 0.85 up Frt, , Cooper Discoverer ST/MAXX 275/70/17 Interior LED's, H9 Lo Beams, Anytime LED Fog lights, Led Backup lights, CF overlays above Glove Box, Steering Wheel & all Door Control Panels to match OEM CF Center Console, Pro Grill, Fangs, Bruins on Startup Screen.
KSJ088 is offline   Reply With QuoteReply With Quote
Old 12-27-2020, 08:43 PM #8
progress4m's Avatar
progress4m's Avatar
I believe you are referring to EVAP check (pressurizing parts of EVAP system) that 4Runner does occasionally after 5-6 hours being off…
What I am hearing is not that, the noise in my case is there all the time (when engine and fuel pump are running).
Old 12-27-2020, 08:43 PM #9
progress4m's Avatar
progress4m's Avatar
Thank you, I understand and was hoping that return fuel could be the culprit and would made that noise, just not sure why it is so loud now, do you hear it on your truck?
Old 12-28-2020, 02:31 PM #10
progress4m's Avatar
progress4m's Avatar
I would appreciate if anyone else can reply with their thoughts\experience on the noise I hear from the gas tank.
Old 12-29-2020, 12:25 AM #11
I have not heard it on my 4Runner, but then I have not been under the gas tank with the engine running. I have heard it on other cars, though.
Old 12-29-2020, 03:45 PM #12
progress4m's Avatar
progress4m's Avatar
Thank you for reply!
At this point, I am assuming (and hoping) that what I am hearing is normal… I have re-adjusted skid plate and now noise can only be heard under the truck with the ear next to the tank around the fuel pump area… and no noise next to truck.
Just as another detail on that noise: the “gurgling” starts a second or two after engine is started, so that delay makes the idea that the noise is generated by the fuel return line is even more plausible IMHO.
I will update this thread if anything changes on my end.
Old 12-29-2020, 07:52 PM #13
Greydog's Avatar
Greydog Greydog is offline
Greydog is on a distinguished road
Greydog's Avatar
I’ve heard this too, 2019 TRDORP, usually on hotter days for some reason. It’s sporatic though, not sure why. Everything else seems fine, doesn’t seem to be the fuel pump either.
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
Greydog is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 09:10 PM #14
progress4m's Avatar
progress4m's Avatar
Thank you for your input.
IMHO: Based on my case (and my current conclusion\experience) I would say it may be because your 4Runner skid plate is touching the tank on the hot days (since materials are expanded)-thus noise propagate itself sporadically and on hot day(s).
Old 07-10-2023, 01:44 PM #15
skyfarm1000 skyfarm1000 is offline
skyfarm1000 is on a distinguished road
Did you ever figure out if this noise was normal or not?
I just purchased a 2016 4runner a week ago and noticed a rapid bubbling/boiling sound coming from the gas tank.
skyfarm1000 is offline   Reply With QuoteReply With Quote
fuel , gas , noise , pump , tank
Gurgling noise behind dash Morphyne 4th Gen T4Rs 14 03-18-2021 11:21 PM
Strange noise coming from fuel pump??? Toskabg 5th gen T4Rs 3 09-09-2020 12:00 AM
noise - fuel pump? h&t 5th gen T4Rs 1 04-22-2014 10:27 PM
Noise in the back right around where fuel pump manicboy111 5th gen T4Rs 2 03-20-2013 01:00 AM
fuel pump noise t4rnoob 3rd gen T4Rs 5 04-17-2011 01:41 PM
