Real Name: Kirk
Real Name: Kirk
Originally Posted by Sp00ner
Anyone running the mounting pins with the BajaRack TRD rack mounts? The mounts worked out super well for me over the summer, though getting the traxs on and off is a complete pain in the ass with the wingnuts the mounting plates come with.
Emailed BajaRack but they couldn't tell me if they'd fit the existing holes.
If you want to dump the wingnuts and cotter pins try this:
"Comfort-Grip threaded through hole knobs"
These are available from McMaster -Carr and are about $4.00 each.
For the 3/8 bolt the kit comes with, use part number: 5532T35.
FWIW, the XBULL trax have their mounting holes closer together and toward the middle of the trax, not out on the ends. I will simply drill and thread two new holes in the BajaRack mounting plate. Since they don't "nest" as tightly as the MaxTrax I will be using longer bolts and these knobs to make the mounting easier to deal with.
Good Luck!
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
