Old 12-28-2020, 08:49 PM #16
aprops aprops is offline
aprops is on a distinguished road
Originally Posted by Bumbo View Post
Sounds like he is operating in 2WD as well so it does not sound like he has a Limited?
But yes, the limited has the option to unlock the center diff, which makes it like any other AWD vehicle and operates on-road or high traction surfaces just fine.
Locked center and it operates just like the rest of the 5th gen lineup in 4WD.
Clarification by the OP in the beginning would have been more productive.
Yes, sorry about that! I didn't realize that in this case SR5 vs Limited was important to differentiate!
aprops is offline   Reply With QuoteReply With Quote
Old 12-28-2020, 08:50 PM #17
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Originally Posted by SpeedyKevin View Post
Now now, we freak out and think its a blizzard when its 69F and its a heat wave when its 71F lol
Lets be realistic … its more like 55F to 85F before the freak-out ensues.
Old 12-28-2020, 09:20 PM #18
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
What’s a “tune up”? Definitely not gonna get optimal mileage if driving around in “HD”, that’s the worst one of all to be in. Make sure you press the eco button over and over to unlock super MPGs.
1000MPH is offline   Reply With QuoteReply With Quote
Old 12-28-2020, 09:47 PM #19
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Originally Posted by aprops View Post
Yes, I just have the SR5, not the Limited. I also wonder if the Limited gets better mpg with the AWD!
Ok. Misunderstood your 4wd knob markings.
delloro is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 10:18 AM #20
man i had high expectations for the comments in this thread. you guys are all too nice suddenly.
OP- when in 2wd the front diff and axles are still spinning so youre still dealing with that added resistance. although i'd expect 16-17 mpg outta stock 4runner, if not better. i think ours averaged 18 stock.
Old 12-29-2020, 11:14 AM #21
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
Yep, I just did the math. I filled up yesterday--the tank was close to empty but not quite. The tank is 23 gallons, and I got about 303 miles before filling up. So at best, if there were still a few gallons left, that's about 14mpg.
I have wondered if there's another issue going on--I agree with you!
Sorry but if you are dividing the miles you drove by the fuel tank's maximum capacity, you are doing it wrong.
You should divide how far you drove by the amount of fuel you put in to fill the tank. No WONDER you're getting only 14 mpg; your method of calculation is making it look like you are using a lot more fuel.
My 4R has at least 4 gallons left in the tank when the light comes on. That means only 19 gallons were used. In your example above that would result in almost 16 mpg, where your incorrect calculation using the whole tank is just over 13.
As far as the 4wd, !! Part time is NOT to be used on dry hard pavement! If it is dry pavement then 2wd is all you will ever need. 4wd is for slippery surfaces only.
Since you are new to p/t 4wd, go find a gravel road to exercise the 4wd.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 11:21 AM #22
enyce enyce is offline
enyce is on a distinguished road
I think I'm a little bummed out because this truck gets super low miles per gallon, and I wish that I could at least get awd out of the deal. But I should have researched the Limited version more, I guess! Because right now, I get maybe 13mpg and basically just have a really heavy 2wd vehicle! It's sure pretty though.
My '15 Trail gets 14 mpg between city and highway driving in NYC.
2015 4Runner Trail Non-KDSS Husky Floor Mats Falken Wildpeak A/T3W P265/70R17 AFe Drop in Air Filter So far stock... Loving it
enyce is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 11:31 AM #23
Finslayer83 Finslayer83 is offline
Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough
Easy: don’t engage 4H/4L on dry pavement.
You must be smashing the gas at every light.
I’ve got 250lbs of bumper and armor, 285’s, lift, etc and average 17mpg.
Finslayer83 is offline   Reply With QuoteReply With Quote
4wd , engage , steering , turn , wheel
Steering was tight... ASUMTNEER 3rd gen T4Rs 15 01-14-2019 08:00 PM
Grinding Sound DallasEng 3rd gen T4Rs 4 04-14-2015 11:26 PM
Tight steering after LBJ replacement Loki2043 3rd gen T4Rs 13 12-25-2012 09:04 PM
Buzzing sound when making tight turns nacho 3rd gen T4Rs 4 09-16-2011 12:22 AM
1990 4cyl steering makes a grinding sound when cranked. canadacrazy69 Classic T4Rs 5 01-20-2011 10:15 PM
