Old 12-30-2020, 07:40 PM #1
BADCLOWN's Avatar
BADCLOWN BADCLOWN is offline
BADCLOWN is on a distinguished road
BADCLOWN's Avatar
Best 1.5-2 inch lift kit?
Who makes the best 1.5-2 inch body lift or shock spacer kit for 5th gen?
I’ve got a 2017 TRDP, factory tires are on the back half of their life. When replaced, I want to do a bigger tire and a lift. Looking for personal experiences and opinions.
2017 Toyota 4Runner TRD Pro Cement Gray - OE blackout badges, Innovativ HIDs, OE LED fogs, AJT, black TRD shifter, 33inch light bar, K&N, CanvasBack, Toytec 2 inch lift, 34 inch tires, 2021 TRDP wheels, URD
BADCLOWN is offline   Reply With QuoteReply With Quote
Old 12-30-2020, 09:21 PM #2
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Depends on what you want to do/trips you take with the car! Also wheel offset is an important factor when considering larger tires as lifting an IFS doesn't necessarily clear a tire (will reduce the frequency of rubbing but will still rub when full compressed).
Imho the absolute best off the shelf wide budget shock would be the Bilstein 8112s. Beyond that would be custom valved shocks from any of the big names like King, ADS, Fox, Radflo etc.
For simple trips and nothing too crazy in the desert, Dobinson IMS or Bilstein 6112s are of great value. IMS are progressive and Bilstein are digressive valved. The IMS can be more precisely adjusted for height compared to the 6112s so that may be something to consider.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 10:35 AM #3
BADCLOWN's Avatar
BADCLOWN's Avatar
I don’t off-road my 4R, I just simply want to do a minor lift to allow for some bigger tires. Will be utilizing the stock TRDP wheels and maybe throw on some 1.25 spidertrax.
Not looking to replace shocks that’s why I’m wondering who makes the most dependable body lift or shock spacer kits that get 1.5-2 inches of lift
Old 12-31-2020, 11:48 AM #4
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I recommend Toytec for the body lift and shock spacers, but they’re not recommended (by Toytec) if you have a TRD Pro. TRD Off Road Premium - ok. I don’t know why they say not to use the spacers with a TRD Pro. You can ask them. They were very helpful when I had questions about my 3” lift kit.
On my 4th gen, I’ve had the 1.25” spidertrax and both the Toytec 1” body lift kit and their shock spacer kits. I have since replaced the shock spacer kits with the Toytec/Bilstein 5100 3” lift kit (2” in the rear) because my stock coils were old and tired.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 11:58 AM #5
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
Burtman Industries
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 01:13 PM #6
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
What is "best" is a matter of opinion. In my definition of "best", it would be something that is simple, inexpensive, and gets the job done. Thus I put the Rough Country leveling kit (2in Suspension Lift Kit for 2010-2019 Toyota 4-Runner 4wd | Rough Country(R)) on my '18 4Runner SR5. They also make a version for the 4Runner with the X-reas suspension (2in Suspension Lift Kit for 10-19 Toyota 4-Runner 4wd X-REAS Models [767] | Rough Country(R)).
fkheath is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 06:38 PM #7
BADCLOWN's Avatar
BADCLOWN's Avatar
Im assuming the TRDP has the X-REAS suspension? I honestly have never heard of the suspension being called that nor know what it is
Old 12-31-2020, 07:19 PM #8
Only the limited trim has XREAS. It's some hydraulic set up that helps with body roll.
Toyota 4-Runner X-REAS Shocks - Shockwarehouse.com
Old 02-18-2021, 11:35 PM #9
BADCLOWN's Avatar
BADCLOWN's Avatar
I can’t seem to find anyone else that makes a 2 inch lift like rough country. Any other businesses out there?
Old 02-19-2021, 08:56 AM #10
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
I'd avoid a body lift. With how inexpensive spacer kits are it makes zero sense to mess with a body lift. Cornfed Suspension has simple spacer kits that will work fine for what you need. (@2016 4Runner SR5 is a dealer on here and is great to work with). Rough country is a cheaper brand, but I'd imagine they can't mess up an aluminum spacer kit. Avoid their shocks or anything as they are poor quality.
Otherwise, try to find one of the Bilstein 6112 kits.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 11:21 AM #11
Captain Planet's Avatar
Captain Planet Captain Planet is offline
Captain Planet will become famous soon enough
I went with Dobinson, couldn't be happier.
Captain Planet is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 11:33 AM #12
Muskrat14's Avatar
Muskrat14 Muskrat14 is offline
Real Name: Dave
Muskrat14 will become famous soon enough
Muskrat14's Avatar
Real Name: Dave
Thought a spacer lot and body lift were the same thing.
I went with a Daystar kit. 2.5” front and 1” rear. Kept stock front coils n rear shocks.
I wasn’t looking for max articulation from a true suspension lift. I just wanted more height so I was dragging axle housing n skid plates all the time.
Looks great and works well. Also allowed me to run 285’s w stock wheels.
My struts n shocks now need replaced. I’ll probably keep the spacers in the rear n go w taller Bilsteins n do the Bilsteins up front t w the adjustable spring height.
Muskrat14 is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 11:51 AM #13
Not at all. Spaces go between the springs/struts and their mount. The result is the suspension is pushed down which raises the rest of the vehicle, i.e. anything not part of the suspension is raised -- frame, body, etc. -- as well as anything attached to the frame/body, such as engine, transmission, transfer case.
A body lift moves the body only above the frame. The frame is NOT raised, and anything attached to the frame is not raised. This can only be done on a vehicle that has "body on frame" construction, such as the 4Runner. A vehicle with a unibody construction, like most cars, cannot have this done because there is no separate frame.
Old 02-19-2021, 12:24 PM #14
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Here is a front suspension spacer.
Don't know the brand, it was on the truck when I bought it. 285/70R17 fits nicely. Don't know the specs of the aftermarket wheels as they were on there too.
I'm sure there is a spacer on the rear spring too, but it's hidden if it's there.
When the shocks need replacing I will go with longer shocks/springs as my drive from home is not paved, seldom graded, and I do occasionally go mild to mid offroading.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 03:36 PM #15
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
I did the Burtman Industries 1.5/1” UHMW Cornfed spacer lift on my Pro. I started with 275’s, but I am now running 285’s. Inexpensive and they have worked great on and off road for two years now.
Best 1.5-2 inch lift kit?-7ac02ce3-1760-45cc-9db1-0b4589afb323-jpg
TRD PANTHER is offline   Reply With QuoteReply With Quote
1.5-2 , inch , kit , lift , personal
Do you regret your two inch lift? How about your 3 inch lift? slide531 5th gen T4Rs 55 03-01-2019 05:42 PM
2 inch Front lift w/ no rear lift eastlakeqb4 4th Gen T4Rs 8 04-14-2015 08:18 AM
3 inch coil lift + 3 inch body lift coltonbaxter31 3rd gen T4Rs 7 02-18-2015 06:32 PM
do I need anything if I add a 1 or 1.5 inch body lift to a 3 inch ome susp lift? grant1413 3rd gen T4Rs 4 04-09-2012 01:22 PM
One inch leveling lift using ½ inch spacer (Pics) Even Steven Off-Roading 22 05-25-2008 01:02 PM
