Old 01-03-2021, 02:12 PM #16
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Originally Posted by fkheath View Post
Another thing to check is where the front spring fits with the spring seat. If the spring is not exactly fitting in the seat, it will cause a clunk. This is especially common if you have replaced the front springs/shocks/struts.
Could you explain this a little more?
delloro is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 01:07 AM #17
jamoc jamoc is offline
Real Name: DeLo
jamoc is on a distinguished road
Real Name: DeLo
I had a clunk. Tightened front body mount bolts under carpets on both sides. 2 person job. Problem solved!!
jamoc is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 01:17 AM #18
DiscoCam DiscoCam is offline
DiscoCam is on a distinguished road
Solved.
Clunk is gone. It was the hood.
Just to recap:
- adjusted hood stops and greased them with silicone grease
- I had adjusted them before but without the grease (I feel like that made a difference)
- no clue why my front bilstein shock on that corner has a bushing that’s almost completely failed. Pretty much just highway driving and only 6k miles. Going to contact blistein about this to see what my options are. For now, I am back to stock front shocks.
Thanks for all the input everyone. This was driving me crazy
2023 4Runner TRD Off-Road Premium KDSS, Magnetic Gray
2021 GX460 Premium Atomic Silver
Previous:
2016 4Runner SR5 4WD Magnetic Gray
1996 FZJ80 Land Cruiser 3x Locked White
DiscoCam is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 08:05 AM #19
Mo's TE Mo's TE is offline
Mo's TE is on a distinguished road
Just to recap:
Just the 2 black bump stops??? Man this is a very easy solution, and attached is the part with all the info needed. Thanks for reporting back
Another Front End Clunk/Pop thread-screen-shot-2021-01-05-4-03-23-pm-jpg
Mo's TE is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 01:32 PM #20
That's all it was. I just adjusted it until the hood wouldn't close and then backed it off a bit. All the panel gaps with the grill and fenders remained the same.
It's amazing how bad the lower shock bushing can get without making any noise. Mine was torn all the way through. But was still silent. Maybe it's time for a dobinsons kit.
Previous:
Old 01-06-2021, 03:14 AM #21
The hunt continues
I adjusted the stops and greased them until it was difficult to close the hood. This did not work me, the metal on metal clunk is still there.
Old 01-06-2021, 11:40 AM #22
Just to recap:
don't torque the bottom bolt until the weight of the truck is on the tires. otherwise the bushing will preload/bind and it will tear. this is true of almost all OEM style bushings found in LCA's, UCA's, and the lower shock mounts.
Old 01-07-2021, 03:10 AM #23
Yes this is true. I did this for the bilsteins and the OEM shocks I just put back in
Previous:
Old 01-07-2021, 03:11 AM #24
@Mo's TE That's a bummer. But I don't think I had a metal/metal noise. Definitely more like a clunky bushing.
Previous:
Old 03-05-2021, 02:43 PM #25
Just wanted to update this thread, I ended up getting another set of 5100s for the front and installed them yesterday. Same factory springs, same 0.85" ride height setting. Everything torqued with all tires on the ground.
Truck just rolled 30k last week so I'm hoping this will last longer than the first set. Forgot how much of a difference the 5100s make over the factory shocks; drives so differently.
Edit: Got it aligned this morning and all is good. Definitely needs an alignment afterwards so make sure you do that. Camber was out of spec.
Previous:
bushings , end , feel , front , time
Different kind of clunk thread... 5T4Rsolo 5th gen T4Rs 15 02-08-2019 05:18 PM
Front end clunk what could it be? V8 4WD K_Labs 4th Gen T4Rs 49 12-01-2017 05:46 AM
Front end clunk 4racer 3rd gen T4Rs 8 07-08-2016 06:52 AM
Another clunk thread bolantej 3rd gen T4Rs 4 05-01-2012 03:32 PM
Where is the huge thread about the drive shaft clunk? TeryT 4th Gen T4Rs 5 02-25-2010 01:32 AM
