01-05-2021, 03:23 AM
#16
Real Name: BLACK TRD PRO
Plenty of pics in this thread. Post your LIFTED pix here!
I personally would stick with 285/70-17’s. Good all around performance, looks, availability, mpg won’t suffer too bad and no gear change or recalibrated speedometer required. If you have ORP or Pro wheels there is no need for a BMC
01-05-2021, 03:24 AM
#17
Originally Posted by Signal
Also will 285/70/17's fit on the ORP wheels?
Yes. Perfectly
01-05-2021, 02:07 PM
#18
Thanks guys, I am trying to find a picture of the 285-70-17s with a 3 inch lift, and I have another question. I live in the land of rocks flying into my windshield, what can I do to stop that there are 2 products and 1 is a bug and stone protector and the other is a hood protector, is there a big difference?
Here's what you're looking for. 285/70/17 tires on TRD Off-Road wheels, with a 3 inch lift.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
01-05-2021, 06:30 PM
#19
Thank you I now need to find 1 ORP wheel. for the rear bumper.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
01-05-2021, 09:20 PM
#20
Did you have to cut/trim your bumper?
The Build
01-06-2021, 04:16 AM
#21
How do you like the 285’s after running the 275’s for so long?
He did the high clearance mod, which, is not required for the 285’s. You may just need to do some minor front fender trimming.
01-06-2021, 12:09 PM
#22
I like the 285s quite a bit. A lot of my happiness stems from the fact that the KO2s, in retrospect, were not that good. My new tires seem to be better in every way, outside of road noise and gas mileage. No more steering wheel shake, not even a little bit (and it was bad, I just learned to live with it). I'm happy with the size, but may go to 285/75 the next time around.
And yes, my front bumper was trimmed for higher clearance, and it has the added benefit of being out of the way of my tires as well.
Build Thread
01-06-2021, 07:49 PM
#23
What tires did you go with, I am looking at Yokohamas Geolander M/T's 2003
The Build
01-06-2021, 08:04 PM
#24
I got a killer deal on some Ironman MTs. I had never heard of them before. But bought and installed they cost $100 from a family member in the tire business, so I figured I'd give them a try.
I like them a lot so far. Better in snow than KO2s. Seem to do fine on ice too. No steering wheel wobble. Only downside I've noticed is that they are louder.
Build Thread
01-06-2021, 09:07 PM
#25
Too much analysis paralysis in this thread. Get the 3" lift and UCAs, the wheels you want, the tires and tire size you want, and deal with the rest later. If you rub a bit then do a BMC and trim the bumper a bit. No one can give you an exact answer as each lift, UCA, tire, and truck is different. If you can't find someone on the coast to fab you a bumper then take it to shops in B'ham or Huntsville.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
