Old 01-05-2021, 03:23 AM #16
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Plenty of pics in this thread. Post your LIFTED pix here!
I personally would stick with 285/70-17’s. Good all around performance, looks, availability, mpg won’t suffer too bad and no gear change or recalibrated speedometer required. If you have ORP or Pro wheels there is no need for a BMC
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 03:24 AM #17
Originally Posted by Signal View Post
Also will 285/70/17's fit on the ORP wheels?
Yes. Perfectly
Old 01-05-2021, 02:07 PM #18
ryguytheman's Avatar
ryguytheman ryguytheman is offline
ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice
Thanks guys, I am trying to find a picture of the 285-70-17s with a 3 inch lift, and I have another question. I live in the land of rocks flying into my windshield, what can I do to stop that there are 2 products and 1 is a bug and stone protector and the other is a hood protector, is there a big difference?
Here's what you're looking for. 285/70/17 tires on TRD Off-Road wheels, with a 3 inch lift.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
ryguytheman is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 06:30 PM #19
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
Thank you I now need to find 1 ORP wheel. for the rear bumper.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 09:20 PM #20
Did you have to cut/trim your bumper?
The Build
Old 01-06-2021, 04:16 AM #21
How do you like the 285’s after running the 275’s for so long?
He did the high clearance mod, which, is not required for the 285’s. You may just need to do some minor front fender trimming.
Old 01-06-2021, 12:09 PM #22
I like the 285s quite a bit. A lot of my happiness stems from the fact that the KO2s, in retrospect, were not that good. My new tires seem to be better in every way, outside of road noise and gas mileage. No more steering wheel shake, not even a little bit (and it was bad, I just learned to live with it). I'm happy with the size, but may go to 285/75 the next time around.
And yes, my front bumper was trimmed for higher clearance, and it has the added benefit of being out of the way of my tires as well.
Build Thread
Old 01-06-2021, 07:49 PM #23
What tires did you go with, I am looking at Yokohamas Geolander M/T's 2003
The Build
Old 01-06-2021, 08:04 PM #24
I got a killer deal on some Ironman MTs. I had never heard of them before. But bought and installed they cost $100 from a family member in the tire business, so I figured I'd give them a try.
I like them a lot so far. Better in snow than KO2s. Seem to do fine on ice too. No steering wheel wobble. Only downside I've noticed is that they are louder.
Build Thread
Old 01-06-2021, 09:07 PM #25
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Too much analysis paralysis in this thread. Get the 3" lift and UCAs, the wheels you want, the tires and tire size you want, and deal with the rest later. If you rub a bit then do a BMC and trim the bumper a bit. No one can give you an exact answer as each lift, UCA, tire, and truck is different. If you can't find someone on the coast to fab you a bumper then take it to shops in B'ham or Huntsville.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
lift , rubbing , things , tires , weld
BEFORE Up-sizing your tires...read this! Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 43 08-23-2021 10:28 AM
Aged Tires: A Driving Hazard? (MUST READ) Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 31 08-01-2021 02:45 PM
PLEASE READ - 4th gen section/thread clean up & consolidation - PLEASE READ zopperman 4th Gen T4Rs 75 11-25-2019 08:28 PM
Talking Tires with Discount Tire|Google+ Hangouts Discount Tire Off Topic 0 08-17-2015 07:14 PM
In The Market For Tires? Read this FIRST... Mindomission 3rd gen T4Rs 12 12-20-2014 11:36 PM
