Old 01-02-2021, 01:24 PM #1
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
I think I have over read and Over google wheeles and Tires
So, I have a 3 inch lift sitting in the garage with some UCA's to go on also. I have been reading about wheels and tires and I think I am going to go with 285/70.17's since there is no rubbing. I would like to go bigger but I can't find a shop to do a body mount chop, all the shops around here only lift half the rucks and call it a day. I looked at getting a Coastal front bumper but no one will weld it and said they can just order me one. So..... What's the biggest I can go with the lift and have minimal rubbing until I get the grinder out and start hacking away at things. I was going after the T4Rhhhhhh build look. if that helps.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 01-02-2021, 02:02 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
What is your goal? For the "looks" of big tires, high off the ground? To do extreme off road outside Moab, Utah? Or is your goal just to do some off road trails? Gotta know what your goal is to decide what to put on your 4Runner.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-02-2021, 02:06 PM #3
T4R416 T4R416 is offline
T4R416 will become famous soon enough
Not really to be honest.. it seems like he’s going for the “looks” which a lot of people do and will never really put it to “intended use” but that’s what they like... so he just wants to know biggest tires he can fit in without having to BMC.. whether he’s mall crawling or heading to Mount Everest is really irrelevant .. ;)
T4R416 is offline   Reply With QuoteReply With Quote
Old 01-02-2021, 03:36 PM #4
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I have 285/70/17's and basically a 3" front 2" rear lift and JBA UCA's. 17x8.5 0 offset wheels. They rubbed the body mount. So I chopped it and re-did the mounts with a kit I bought on ebay I think. When it arrived I realized I could have very easily made my own with the press and brake at work but whatever it was easy. So don't think just because someone out there had no rubbing you won't either. Depends on your wheel choice, some tires are larger in the same size than others, and don't forget the alignment can put the tires closer to the fenders too depending on how the tech adjusts it. Lots of variables and it snowballs quick if you want it right.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 01-03-2021, 02:07 AM #5
IMoab woul dbe nice, maybe in 2022. 2021 will be casual off roading in TN anf GA.
The Build
Old 01-03-2021, 09:55 AM #6
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Check out Southern Style Offroad in Baton Rouge. I met Kevin the owner briefly at the 19' ATR, nice guy. They might be able to give you a good plan on how to proceed.
Might be a little far to actually have them do the work, but they know Toyotas.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 01-03-2021, 10:03 PM #7
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
OP with 285's you can presume you will rub. Maybe you won't, but most do, so just expect it.
Get a good BMC done and be done with the drama.
It's the cost of admission.
delloro is offline   Reply With QuoteReply With Quote
Old 01-03-2021, 11:52 PM #8
spartacus's Avatar
spartacus's Avatar
Another option, after market uca's that can provide more caster.
Old 01-04-2021, 06:36 PM #9
If I do the BMC can I go bigger then? say 305 or 285/75's?
The Build
Old 01-04-2021, 06:38 PM #10
I have Dirk king UCAs to go with the OME lift.
The Build
Old 01-04-2021, 06:47 PM #11
ryguytheman's Avatar
ryguytheman ryguytheman is offline
ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice
Not without other adjustments. You will rub other areas apart from the body mount at that size. It will take some time to locate and adjust those areas.
This photo is from a member of this site, who had to trim inside his fenders a decent amount to fit 285/75 tires.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
ryguytheman is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 06:53 PM #12
delloro's Avatar
delloro's Avatar
Going bigger than 33's involves real bodywork, as posted above. Gearing will suffer too.
It can be done, it ju$t require$ $ome $pecial ajdu$tment$.
Old 01-04-2021, 07:17 PM #13
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Honestly, if you are going to pay someone to do the BMC, you might as well have them hammer back your pinch welds at the same time, and trim back the lower front fender mount area (like in that picture), and trim your front bumper at the same time.
It will cost you less in time and money, and give you the options of running bigger than 33's in the future (depending on suspension and alignment).
Thats what I did.
Old 01-04-2021, 09:17 PM #14
Thanks guys, I am trying to find a picture of the 285-70-17s with a 3 inch lift, and I have another question. I live in the land of rocks flying into my windshield, what can I do to stop that there are 2 products and 1 is a bug and stone protector and the other is a hood protector, is there a big difference?
The Build
Old 01-04-2021, 10:03 PM #15
Also will 285/70/17's fit on the ORP wheels?
The Build
lift , rubbing , things , tires , weld
BEFORE Up-sizing your tires...read this! Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 43 08-23-2021 10:28 AM
Aged Tires: A Driving Hazard? (MUST READ) Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 31 08-01-2021 02:45 PM
PLEASE READ - 4th gen section/thread clean up & consolidation - PLEASE READ zopperman 4th Gen T4Rs 75 11-25-2019 08:28 PM
Talking Tires with Discount Tire|Google+ Hangouts Discount Tire Off Topic 0 08-17-2015 07:14 PM
In The Market For Tires? Read this FIRST... Mindomission 3rd gen T4Rs 12 12-20-2014 11:36 PM
