Originally Posted by Jeremy556
Lug nuts tight? (I'm sure you covered this, but just to check) Wheel lug holes wallowed out? Using correct type of lugnuts?
Grab the outer tie rod and see if there's any play in the ball joint in the inner tie rod end.
All bolts tightened to spec, especially LCA cam bolts? Has alignment cams moved (paint mark them)?
I will check all of this and report back, Thank you!
