Old 01-03-2021, 04:39 PM #1
Paragon1's Avatar
Paragon1 Paragon1 is offline
Paragon1 will become famous soon enough Paragon1 will become famous soon enough
Paragon1's Avatar
DC Power Alternator / Antigravity Battery. Question about wiring/charging
So after my powered sub install my woefully underpowered stock alternator cant keep up. Elected to get DC power alternator, and as luck would have it, I discovered antigravity batteries after making the purchase. So after a bit of scotch, one purchase became two. Alternator is here, still waiting on the battery.
I have two questions for you electronically inclined individuals out there.
First, I've only seen a single install thread for the alternator, is it really necessary to upgrade the cables to/from the alternator & battery?
Second, does anyone have experience with high output alternators charging Lithium Ion batteries?
Worse case i can imagine is that i'll have to sell the alternator since Lithium batteries charge better. And the reason i went with AG is because they never deplete to the point you cant start the vehicle, you can monitor their health via phone app, and their also extremely light (45lbs lighter than the stock battery in my RS5).
I've sent inquiries to both vendors but the holidays have delayed their responses past my ability to wait so i'm putting myself at the mercy of the forum. Any info would be appreciated. - Cheers
2015 Silver TE: KDSS, ICON stg 2, Magnuson, Victory Blitz sliders, Fuel Blitz DDT 18x9 w/ -12o/s, 275/65/18 Nitto TGG2, ARB skids, Spidertrax spacers, Alpharex Luxx, Rigid 40 Stealth LED bar & 360 fogs, Switch Pro 9100 w/ Mount Tray, KC Flex Dual Ditch Lights, KC Cyclone Rock Lights, LED interior, SSS hybrid winch bumper, 30" Rough Country single row LED, Alpine ILX-F308/R line speakers, 8" Alpine Powered Sub. Prinsu Full no-drill roof rack.
2015 Audi RS5, Suzuka Grey, stock, 11,500miles
Paragon1 is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 12:57 AM #2
fkheath fkheath is offline
fkheath has a spectacular aura about fkheath has a spectacular aura about
Why not get one of those really large capacitors for car power amplifiers? A quick look on Amazon shows that you can get them up to 10 Farads. Be sure to mount as close to the amp as possible and use the largest wire that will fit in the receptacles. That should solve your problem.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 02:20 AM #3
Captain Planet's Avatar
Captain Planet Captain Planet is online now
Captain Planet will become famous soon enough
Mounting an actual 10f capacitor under the hood sounds like a good way to die.
Captain Planet is online now   Reply With QuoteReply With Quote
Old 01-04-2021, 09:39 AM #4
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special has a spectacular aura about Nobody Special has a spectacular aura about Nobody Special has a spectacular aura about
OP, don't rip out the OEM stuff, Just augment it with 4AWG.
You can follow the route of OEM cables and secure to OEM in some manner.
How many amps is the alternator rated for at idle and speed?
How many watts is/are your amp/s?
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 09:39 AM #5
People still use caps?
Old 01-04-2021, 10:26 AM #6
jhguth jhguth is offline
jhguth is a name known to all jhguth is a name known to all jhguth is a name known to all jhguth is a name known to all jhguth is a name known to all jhguth is a name known to all
caps are how you protect against voltage drops during hard hits, i don't see a reason how/why that would have changed
jhguth is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 10:41 AM #7
I am well aware. But mostly I see a second battery, usually Lithium, these days.
A cap stores power to an extent, but it does not function in the same way as a battery.
They are usually band-aids to "failing" electrical systems which also has an effect on the main battery, shortening its life.
Since capacitors have to charge, discharge and then charge again, they will supply uneven voltage to your amps which is not a good thing.
Amp life is also shortened.
Old 01-04-2021, 10:48 AM #8
Paragon1's Avatar
Paragon1's Avatar
Cant remember the wattage on the main amp but I think it’s 200, the powered sub specs are: 32Hz-150Hz frequency response, Power Rating: 120W RMS. RCA (0.1-4V) / Speaker Input (1.5-30V/auto sensing).
Here’s the DC Power alternator output, I don’t know how this compares to stock:
Old 01-04-2021, 11:20 AM #9
Dude, you have less than 1,500 watts total, right? No typos there?
Something does not seem right. Like a bad ground somewhere.
Did you ever have your old batt/alt tested?
Just a ROUGH estimate as power is dynamic, not static, a single 1,500 watt amp/system would need 65 amps for music. (You are not pulling all 1500 from the amp every minute)
If you are listening at SPL comp levels drawing all 1,500 watts, that increases to say ~215 amps.
Do you have your amp model numbers?
Old 01-04-2021, 11:26 AM #10
FYI, I am going to be installing some larger amps, and the FIRST thing I am doing is "The Big Three". Actually, I would be doing it regardless of audio system.
IF IF IF I push current limits, then I will upgrade the alt/battery.
Toyota is going to use the bare minimum they can get away with.
They are not building cars like they used to, where everything was beefy.
They build with the average user in mind.
I am pretty sure the stock alts are either 100 or 130 depending on model/options.
Old 01-04-2021, 11:43 AM #11
I said to mount the cap as close to the amp as possible, Amps are never mounted in the engine compartment, but usually under a seat or in the cargo/trunk area.
The reason Paragon1 thinks he needs a bigger alternator is because when the hard bass hits (drums, bass guitar, etc), the amp draws a huge current for a short period of time. The large cap provides that current, as long as you use a large, short wire (near the amp) to connect them.
A good battery can also provide that current, but due to the long distance from the car battery to the amp, there is inevitably a voltage drop, causing lights to dim and other associated electrical problems (same reason the lights dim when you start the engine).
Old 01-04-2021, 12:16 PM #12
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi has a spectacular aura about rayofsi has a spectacular aura about
rayofsi's Avatar
i don't know if i'm reading right. but Antigravity batteries have like half the reserves, maybe even less then you have in an agm battery like odyssey?
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - JBA UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 03:42 PM #13
Paragon1's Avatar
Paragon1's Avatar
I replaced the stock battery with an optima last year, and I had to use my jump starter this morning actually. It was only 38 last night, and my 4R lives in the garage. Pretty sure it’s the alternator as I can’t even run music for more than 30min (not full volume) without killing it. Amp is an alpine S-A32F 55 watts RMS x 4 at 4 ohms (80 watts RMS x 4 at 2 ohms)
Old 01-04-2021, 07:32 PM #14
Originally Posted by Paragon1 View Post
I replaced the stock battery with an optima last year, and I had to use my jump starter this morning actually. It was only 38 last night, and my 4R lives in the garage. Pretty sure its the alternator as I cant even run music for more than 30min (not full volume) without killing it. Amp is an alpine S-A32F 55 watts RMS x 4 at 4 ohms (80 watts RMS x 4 at 2 ohms)
Easy to test the alternator. Just measure the voltage across the battery with the engine running. If it is about 14 volts the alternator is good. Thus you may have a battery (or connection) problem.
Old 01-04-2021, 07:41 PM #15
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold
Bumbo's Avatar
The trends have changed... these days its better to just use LiFePO4 cells.
Headway is a good cheap alternate that gets you a lot more value and capacity than caps. Benefits of a battery with the low resistance discharge potential of caps.
Melting metal with Batteries - YouTube
USED HEADWAY 38120 HP 3.2V 8AH LIFEPO4 BATTERY – Battery Hookup
alternator , batteries , battery , power , purchase
Charging Issue with New Battery and Alternator gamefreakgc 3rd gen T4Rs 58 01-22-2020 06:14 PM
Goal Zero or any portable Battery Outlet Charging Question HauKrazee 5th gen T4Rs 6 09-22-2019 07:59 PM
Charging a LiFePO4 house battery from alternator 4RExplorer 5th gen T4Rs 7 05-14-2019 09:39 PM
4.7 Alternator not charging help PLZ! Need ideas. swapmeet 4th Gen T4Rs 17 03-31-2015 11:34 AM
PLZ HELP! Battery not charging, alternator tests good. swapmeet 4th Gen T4Rs 7 03-15-2015 07:54 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
