Old 01-06-2021, 03:18 AM #16
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Originally Posted by rayofsi View Post
make sure to grease them up before using them...
Is bearing grease okay
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 03:25 AM #17
MicrowaveOven MicrowaveOven is offline
MicrowaveOven is on a distinguished road
So TIL you need a spring compressor to change springs on coil overs...
Sent from my iPhone using Tapatalk Pro
MicrowaveOven is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 05:17 AM #18
perf0rmance perf0rmance is offline
perf0rmance will become famous soon enough
Originally Posted by daytonaviolet View Post
Arrived today. Seems to fit well and clears the threaded body. One thing I noticed is the bolts does nothing clear the safety bar. I may have to drill them out.
Let me know how this goes - I've been looking for a solution as well. I'm hoping to be able to adjust them whilst installed... well, because I already installed mine hahaha. I've got 600lb springs FYI - you're welcome to swing by and see if you like the height.
Weight-wise, I've only got a single compressor under the hood and the 600's feel nice and plush with street driving. I'm 4-5 clicks from the softest setting.
perf0rmance is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 11:04 AM #19
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
pretty sure any grease is ok. they come with a light amount of it, and most reviews say it'll only mess up if its not greased enough. full disassembly and grease, not just the visible threads.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 12:00 AM #20
I used the same grease for my UCA, lithium grease
Old 01-15-2021, 01:11 PM #21
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
Works on my King spring every time, zero issues.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 02:29 PM #22
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Spring Compressor
I made a spring compressor out of all thread rod, scrap aluminum and scrap steel. It uses a 4Runner screw jack to compress the spring. It doesn't scratch powder coating on the spring.
How do you swap Kings springs ?-img_2030-png
DougR is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 02:35 PM #23
Jono.ful's Avatar
Jono.ful's Avatar
Originally Posted by DougR View Post
I made a spring compressor out of all thread rod, scrap aluminum and steel. It uses a 4Runner screw jack to compress the spring.
That's pretty slick!
Old 01-17-2021, 04:01 PM #24
Which brand? I tried a set similar and the depth of the arms were too long. I hit the threaded body before grabbing the coil.
And even if I could clear the threaded body, the safety also didn’t clear
Old 01-17-2021, 04:03 PM #25
Very nice
Old 01-17-2021, 05:40 PM #26
Jono.ful's Avatar
Jono.ful's Avatar
Looks like the same ones, mine are pro point - which is just a white label store brand (like harbor freight). The safety pins do take a bit to engage, I honestly don't bother with them. If you alternate between sides, and only tighten each one a bit a time they stay fairly straight and centered. I don't have any issues with hitting the threads however.
Old 01-17-2021, 07:23 PM #27
Saker's Avatar
Saker Saker is offline
Saker's Avatar
I like, you could rent that one out!
Best Regards,
Saker
Old 01-29-2021, 05:25 PM #28
Jeff_DML Jeff_DML is offline
Jeff_DML will become famous soon enough Jeff_DML will become famous soon enough
I had the same issue with 3 different brand of spring compressors. Yeah people said don't worry about it and just crank them down. I figured it wasn't worth safety issue to save some money plus was planning to take it in for alignment anyways.
Glad you eventually found a compressor that worked properly
2018 SR5P+3rd row, 285 KO2, 5100+Dobinsons 300/505
Jeff_DML is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 04:43 AM #29
Sorry for the late update. But yes, the Shankley compressor worked perfectly. No damage to the threaded body or coils.
Old 04-20-2021, 08:03 AM #30
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Just an FYI for everyone debating spring rates and heavy armor.
Your nitrogen pressure needs to be at the right levels, as well as the proper spring rate for your personal driving comfort. A 650 lb spring will give you the ride height you desire, but may be a little stiff. There are compromises with every aspect of this, unfortunately.
I've had these shocks shipped with little or no pressure at all, and they should be around 150 psi. Which doesn't affect ride height too much, but will give you a proper functioning cycle of the shock under load.
With 300+ lbs on the front of my 5th gen with bumper, winch, skid plates, dual batteries, arb comp, and heavy cable, I was worried about 600 lb springs carrying the load, but it does quite well at my desired ride height.
I rebuilt my shocks fall of 2019 and discovered that my nitrogen pressures were quite low. Now at the right pressure, the truck is that much more capable of handling the rough stuff, even with all the added bulk. I had experienced the spring bottoming out when pushing too hard in the past.
Here is a pic of the nitrogen rig I built for checking and dispensing the proper pressures that King recommends. This will apply to the other brands of performance shocks as well. You have to use a no loss chuck because a standard tire guage will not give you an accurate reading and you will lose quite a bit of pressure using one.
How do you swap Kings springs ?-20200406_202240-copy-jpg
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
compressor , issue , kings , spring , springs
Anyone Running Kings with Icon or SAW Rear Springs? Az4runnin 4th Gen T4Rs 17 11-20-2015 06:59 PM
Tacoma Swap - What rear springs? swanny 4th Gen T4Rs 11 09-28-2015 09:06 PM
LC Springs and Shock swap and Vibration achha64 3rd gen T4Rs 1 08-03-2014 11:06 AM
Help: FJ front springs swap, sizes? tony_4r 4th Gen T4Rs 4 07-11-2013 01:52 PM
Swap toytec springs on OME lift? Jester4kicks 4th Gen T4Rs 9 11-15-2011 09:24 PM
