Old 04-23-2021, 02:23 PM #31
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
How do you swap Kings springs ?
Originally Posted by 4RunnerAquasport View Post
Just an FYI for everyone debating spring rates and heavy armor.
Your nitrogen pressure needs to be at the right levels, as well as the proper spring rate for your personal driving comfort. A 650 lb spring will give you the ride height you desire, but may be a little stiff. There are compromises with every aspect of this, unfortunately.
I've had these shocks shipped with little or no pressure at all, and they should be around 150 psi. Which doesn't affect ride height too much, but will give you a proper functioning cycle of the shock under load.
With 300+ lbs on the front of my 5th gen with bumper, winch, skid plates, dual batteries, arb comp, and heavy cable, I was worried about 600 lb springs carrying the load, but it does quite well at my desired ride height.
I rebuilt my shocks fall of 2019 and discovered that my nitrogen pressures were quite low. Now at the right pressure, the truck is that much more capable of handling the rough stuff, even with all the added bulk. I had experienced the spring bottoming out when pushing too hard in the past.
Here is a pic of the nitrogen rig I built for checking and dispensing the proper pressures that King recommends. This will apply to the other brands of performance shocks as well. You have to use a no loss chuck because a standard tire guage will not give you an accurate reading and you will lose quite a bit of pressure using one.
So with 300lbs + of weight, your only running 600# springs?
I only have C4 low pro winch bumper, gobi rack and sliders with 600# springs with 11turn preload. I was thinking of trying out 650 or 700 so I can reduce preload.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 04-23-2021, 08:57 PM #32
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Yes Sir 600# springs. My ride height may not be to your liking though. I went through hub to fender measurements with Filthy Motorsports and Ben said I was within the range of what he recommends. I could probably go with a 650, but I like how it's been driving now for years. The proper nitrogen pressures made a big difference too.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 04-23-2021, 10:06 PM #33
My kings are only ~ 3mo old. Hopefully the nitrogen levels are correct.
What is your h2f measurements?
Old 04-24-2021, 01:16 AM #34
you gotta remember people are building these. so there are gonna be faulty ones straight from king.
ive seen fresh outta the box coilovers with issues worse than the n2 pressure.
Old 04-24-2021, 11:25 AM #35
What is your fender to hub measurements?
Old 04-24-2021, 01:30 PM #36
idk man. lol
Old 04-24-2021, 08:01 PM #37
Real Name: Brett
Real Name: Brett
Unfortunately I'm on the road working and away from my truck for the next week.
I've seen these shocks ship with no pressure at all.
I think some carriers have restrictions on this,
Old 04-25-2021, 09:48 AM #38
center of hub to fender is 23.5"
I need secondary shocks. i was on the bump stops a lot in Baja and my wheel wells show it. Tires were full stuffed lol. Shocks were being overworked pretty good.
back end with kings and king hydro bumps worked flawlessley though. I also ran the toytec HD 2." springs due to the extra weight we brought for a week of camping.
Old 04-28-2021, 04:36 AM #39
Andrew.P Andrew.P is offline
Andrew.P is on a distinguished road
Originally Posted by DougR View Post
I made a spring compressor out of all thread rod, scrap aluminum and scrap steel. It uses a 4Runner screw jack to compress the spring. It doesn't scratch powder coating on the spring.
Could you upload a bigger picture?
Andrew.P is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 09:14 AM #40
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Heavy plus on not over springing. I'm just under 300 lbs over stock in the front with winch, alum winch bumper, compressor and second battery. Just like most folks I thought for sure I needed to stick with 700lb springs for my KING setup. However, I'm running 650 and have almost zero preload getting me up to a little over 2.5" of lift. The ride is absolutely perfect.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 03:19 PM #41
vipers28 vipers28 is offline
vipers28 is on a distinguished road
King recommends 150psi of nitrogen and depending on your driving style & terrain, frequency of checking nitrogen levels.
vipers28 is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 03:44 PM #42
thanks.. i'll most likely move up from 600# to 650# also.
Old 04-28-2021, 08:00 PM #43
PK930's Avatar
PK930 PK930 is offline
PK930 will become famous soon enough
PK930's Avatar
What Accutune has to say
Something, something, something.
PK930 is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 11:36 AM #44
Originally Posted by PK930 View Post
That was a good read. So I should be either 600# or 650# according to accutuneoffroad. My C4 low pro winch bumper is made of steel. I also have the high clearance bits as well. Others items : gobi rack, rsg sliders, winch, skid, bumper light bar, gobi light bar
Which one should I choose ?
compressor , issue , kings , spring , springs
Anyone Running Kings with Icon or SAW Rear Springs? Az4runnin 4th Gen T4Rs 17 11-20-2015 06:59 PM
Tacoma Swap - What rear springs? swanny 4th Gen T4Rs 11 09-28-2015 09:06 PM
LC Springs and Shock swap and Vibration achha64 3rd gen T4Rs 1 08-03-2014 11:06 AM
Help: FJ front springs swap, sizes? tony_4r 4th Gen T4Rs 4 07-11-2013 01:52 PM
Swap toytec springs on OME lift? Jester4kicks 4th Gen T4Rs 9 11-15-2011 09:24 PM
