Old 01-04-2021, 02:02 PM #1
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
How do you swap Kings springs ?
Hey guys,
Has anyone tried swapping out Kings front struts springs to a different one ? Mine came with 550lbs and would like to replace it with 600lbs or even 650lbs. Reason being, I’ll be adding the C4 low pro bumper.
Okay so here’s my issue. I’ve tried the conventional spring compressor and as well as this amazon stand up spring compressor with no luck. The problem I’m having is that kings threaded body sits really close to the inner part of the coil.
When I tried the standard spring compressor, the clamps has two issues. First issue, the clamp itself hits the thread body and does not allow the clamp to sit fully. Second issue is the safety does not clear the king spring.
The amazon stand up compressor almost works. But the issue is the clamps designed to hold the springs is not the correct diameter. So when you try to compress it, the spring leans to an angle. Now at these angles the the clamps contact the kings thread body. I have a few deep scratches in the threads because of this angle issue. But fortunately, the damaged threads are much lower then the collar.
So I continued to search on what other tools can be used. Only other thing I’ve seen on some YouTube videos is this machine Barnick 7600. This tool looks very nice and has so much adjustability. But not sure I would use it enough for the price, $700.
I reached out to a few 4x4 shops in my area and they want $200+ to swap springs (hand carry struts). Really ?
So what I want to know, what do you guys do? how do you swap springs ? Do I pay the $200 to have a shop do it ?
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 02:40 PM #2
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
i have both the compressors you tried. neither of those would compress my ADS too. the 2.5" coilover springs are very close to the shock body.
then i got a pair of these
Amazon.com: Shankly Spring Compressor Tool (2 Pieces) - Heavy Duty Build, Ultra Rugged Coil Spring Compressor, Strong and Durable Spring Compressor with Safety Guard and Carrying Case: Automotive
the worked for my ADS
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 02:48 PM #3
awesome. may get these. do you have any pictures of your ADS coilovers? is it a threaded body design like kings?
Old 01-04-2021, 03:05 PM #4
rayofsi's Avatar
rayofsi's Avatar
yup, threaded like kings, icon, fox etc.
How do you swap Kings springs ?-img_20201214_122341-jpg
Old 01-04-2021, 03:11 PM #5
Thanks .. saw these pictures on Amazon also. I’m sold How do you swap Kings springs ?
Old 01-04-2021, 04:51 PM #6
thechickencow thechickencow is offline
thechickencow is on a distinguished road
How are you deciding the spring rate that you're going with? I've got a SSO bumper and winch up front trying to decide if the 550's are too light or not.
thechickencow is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 05:38 PM #7
there's a tread/database where many folks have inputted there setup which includes spring rate, number of turns of pre-load, type of bumper etc.. i'll update this post to include that thread.
but for of now, i have a friend who has kings non-non adjusters with 550lb spring rate and no preload. i weigh ~ 160lbs which is less then what a C4 winch bumper would weigh and we noticed the front ended dropped like 1" when i put my weight on the front end.
i know that 5 turns ~ 1" but i want to use as little pre-load as possible. so that's why i want to try 600lbs spring rates or higher.
how much does your SSO bumper weigh?
Old 01-04-2021, 06:28 PM #8
ax2021 ax2021 is offline
ax2021 will become famous soon enough ax2021 will become famous soon enough
I’ll say you should get at least 650lb springs. I’ve got 650lb , 0 preload an gave me 2.5” lift after brakein, stock weight, well accept SC which is ~60lb. Great ride on and off road.
ax2021 is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 09:04 PM #9
Thanks. I calculated that it’s roughly 150# of bumper plus winch (synthetic cable).
Old 01-04-2021, 10:11 PM #10
Harrisnc Harrisnc is offline
Harrisnc will become famous soon enough
Most of the shops near me have the Barnick compressor. I’ve paid as little as $75 and as much as $150 for switching springs or assembly of all new parts, all carrying them the parts. I could have bought my own compressor by now at those prices.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
Harrisnc is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 10:45 PM #11
Yes I was thinking same thing. I’ll try the Shankly first and see how it goes. Else, Barnick here i come.
Old 01-05-2021, 07:07 PM #12
Arrived today. Seems to fit well and clears the threaded body. One thing I noticed is the bolts does nothing clear the safety bar. I may have to drill them out.
Old 01-05-2021, 10:27 PM #13
rayofsi's Avatar
rayofsi's Avatar
make sure to grease them up before using them...
Old 01-06-2021, 01:45 AM #14
LOLSNOW LOLSNOW is offline
LOLSNOW will become famous soon enough LOLSNOW will become famous soon enough
If you live in SoCal near OC I have a Barnick compressor you can use
LOLSNOW is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 03:17 AM #15
Thanks but I’m in NorCal
compressor , issue , kings , spring , springs
Anyone Running Kings with Icon or SAW Rear Springs? Az4runnin 4th Gen T4Rs 17 11-20-2015 06:59 PM
Tacoma Swap - What rear springs? swanny 4th Gen T4Rs 11 09-28-2015 09:06 PM
LC Springs and Shock swap and Vibration achha64 3rd gen T4Rs 1 08-03-2014 11:06 AM
Help: FJ front springs swap, sizes? tony_4r 4th Gen T4Rs 4 07-11-2013 01:52 PM
Swap toytec springs on OME lift? Jester4kicks 4th Gen T4Rs 9 11-15-2011 09:24 PM
