Old 01-04-2021, 05:35 PM #1
raaychill raaychill is offline
raaychill is on a distinguished road
Max Rear Springs with KDSS
Hi everyone,
I have been researching for months and I finally pulled the plug on buying a Fox coilover suspension set. My last debate at this point is whether I should add a 2" or 3" rear spring. I have a TRD ORP with KDSS. I keep reading mixed information on what the recommended max rear spring size is for KDSS.
I currently have a RTT (stays on) and ladder. It loads up pretty heavy when camping. I plan on eventually getting a spare tire carrier and rear bumper.
Please advise on your experiences. Thanks so much in advance!!
-Rachelle
raaychill is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 06:56 PM #2
comtn4x4's Avatar
comtn4x4 comtn4x4 is online now
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Hi Rachelle,
I unfortunately don't think there's a black and white answer to your question. And with your build progressing in stages like most of us do, your rear coil needs may be changing.
If I was forced to give an answer I would say you should run the same amount of lift in the rear as you do in the front. So if you're running 3" in the front do so in the rear. This is probably contrary to what most others would say, which would be to run 3" front and 2" rear so that it will look "level" as opposed to having it raked towards the front.
The upside of level is it looks great and if your rig stays loaded the same all the time this works well. The down side of level is that if you add a bunch of gear, water, food, etc. in the rear of the truck to head out you may end up with reverse rake which looks awful and reduces your departure angle.
If you have an inch of difference front to rear as the rig is stock then you can accommodate more added weight in the rig before your rake becomes reversed.
There are varying opinions about the rear coil being in excess of 2" in height. You should try to understand those before you get 3" lift coils if you go that route. There are also potential solutions to the 3" coil issue that you might want to consider if you go that route.
There's good information in these links that may help you understand the potential issue with a taller than 2" rear lift with KDSS
As far as my experiences go I have 3" Dobinson's coils in the rear that give me about 2.5" lift when unloaded and 2" when loaded. I also run the Sonoran Steel Trac Bar and the Blackgate Customs sway bar drop kit. This setup has worked very well for me
Dobinsons Coils for KDSS
New Sonoran Steel Product: KDSS High Articulation/Long Travel Trac/PanHard bar
Maximize your KDSS + extended travel shocks
KDSS Spacer Kit | Treaty Oak Offroad
Blackgate Customs
comtn4x4 is online now   Reply With QuoteReply With Quote
Old 01-04-2021, 09:27 PM #3
Originally Posted by comtn4x4 View Post
Hi Rachelle,
Blackgate Customs
Thanks so much for all your help!
kdss , max , plan , rear , spring
6112/5160 - Do I need rear springs/spacers, or can I reuse factory rear springs? darksparkz 5th gen T4Rs 8 09-29-2020 12:18 PM
FS: NEW Dobinsons Rear Springs C59-723, 1.25-1.5" lift, for KDSS; Sacramento CA; $170 str8flexed For Sale: Suspension/Wheels/Tires 3 09-26-2019 01:27 PM
KDSS Lean with Wheeler Springs but Driver side boyguan 5th gen T4Rs 7 03-07-2018 08:48 PM
Cost for shocks and springs with KDSS Dianna 5th gen T4Rs 18 10-22-2017 09:18 AM
FS: Imacculate 4Runner Trail w/ KDSS & Navigation, $36.5K Colorado Springs, CO TrailBum For Sale: Vehicles 12 12-13-2015 02:44 PM
