01-05-2021, 11:47 PM
King Shocks QUESTION!
I have a 2021 4runner with KDSS. I'm able to get my hands on a set of King front coilover shocks that are NON-KDSS.
Are there minimal modifications to make this fit or is this an entirely different shock assembly not just reservoir mounts or brackets etc. in differences. Please let me know!! The part # is 25001-278.
01-06-2021, 12:43 AM
Could be wrong, but I always thought it’s the orientation of the reservoirs
Kdss
Non-kdss
01-06-2021, 10:48 AM
my icon reservoirs had to be mounted using the non-existant threaded swaybar mounts. the holes for the sway bar mount are there but they are just holes, no threads. I drilled them out abit bigger and used rivnuts.
you also have to cut off a bracket covering the KDSS lines on one side, not a big deal because it gets covered reservoir bracket afterwards.
01-06-2021, 11:34 AM
yup just the resi mount is different. maybe different fittings on the resi too
01-06-2021, 12:53 PM
bracket, hose length, and fitting
01-06-2021, 02:44 PM
Thank you guys for all your responses! I will wait to order the correct ones then; sounds like it's too much hassle to fabricate to make it work.
01-06-2021, 09:18 PM
SDHQ had mine in stock for KDSS fyi. some places do have them in stock.
01-07-2021, 01:19 PM
They were one of the dozen shops that I contacted that had a false inventory..
Then they tried to put me on Fox and Icon stuff and also said the fox rears weren't available so I was like wtf why mention it then.
01-07-2021, 01:34 PM
Did you call Accutune?
01-07-2021, 01:48 PM
think most shops are out of stock on king shocks and backorder is over 12 weeks from what i last read on some other forums.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
01-07-2021, 05:16 PM
I ordered during Black Friday and have been waiting since. I also saw a few places that have them in stock, but it’s hundreds of dollars more.
01-07-2021, 08:11 PM
Some places that I called said 4-6 months!
I sure did..no one has them in stock for KDSS 4Runners..
01-08-2021, 02:04 AM
good luck with the search! i'm running ads Shocks, but have king secondary shocks. Has me thinking to go full king shocks.. but i want 3.0s lol
01-08-2021, 03:40 AM
that's exactly what I need to do with my King reservoirs. They are mounted horizontally now because of KDSS but it causes quite serious tire rubbing agains reservoirs at full lock.
But looking at your picture I'm wondering how you regrease bushings on your Total Chaos UCA? Looks like you need to remove the reservoirs and the mounting brackets every time you do the service?
2018, TRD Offroad, KDSS, 2.5" Kings w/ reservoirs, TC UCA, Toytec Superflex 2.5", 285/70R17 LT Falken Wildpeaks, BMC, 4x4 labs sliders, Gobi rack/ladder
01-08-2021, 02:15 PM
Hey Daytonaviolet, I remember seeing you on M3Forums back in the days. I ordered mine through a local vendor in SoCal on 10/22/2020. I am approaching 12 weeks. The status as of this morning was “Kings is having difficulties sourcing components to build the shocks”.
