Old 01-11-2021, 09:40 PM #16
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
King Shocks QUESTION!
Originally Posted by Lukchut View Post
Hey Daytonaviolet, I remember seeing you on M3Forums back in the days. I ordered mine through a local vendor in SoCal on 10/22/2020. I am approaching 12 weeks. The status as of this morning was “Kings is having difficulties sourcing components to build the shocks”.
Hey was up .. your name sounds familiar. Yes I installed the fronts this weekend and still waiting for my rears. I may install my icon 2” springs prior to my rear shocks .. they say my rears might be here end of Jan
12 weeks wow .. I’ve been waiting 5mo for my gobi rack :-(
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 03:40 PM #17
kvincef kvincef is offline
kvincef is on a distinguished road
Originally Posted by vt100 View Post
that's exactly what I need to do with my King reservoirs. They are mounted horizontally now because of KDSS but it causes quite serious tire rubbing agains reservoirs at full lock.
But looking at your picture I'm wondering how you regrease bushings on your Total Chaos UCA? Looks like you need to remove the reservoirs and the mounting brackets every time you do the service?
i used to remove the resevoirs to regrease but i discovered i was able to loosen the UCA bolt without removing the resevoirs. standard offset Box end wrench fits. I loosen the KDSS line bracket and push it out of the way to give more space as well.
kvincef is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 05:53 PM #18
usdmej usdmej is offline
usdmej will become famous soon enough
Originally Posted by daytonaviolet View Post
how did the ride height adjustment go? did you have to remove/replace everytime you wanted to adjust? how many threads did you turn / how much lift did you end up with?
usdmej is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 07:34 PM #19
i was able to adjust mine on the truck. Used the curved tool King sells. It actually worked loll....unlike Fox coilovers on my previous truck.
Old 01-12-2021, 08:37 PM #20
i adjusted the height w/ the springs off the body as i swapped 550lb --> 600lbs springs. i also set the allen adjustment facing out so i can adjust the height later if needed. i believe you can adjust while on the truck, just let the A arm hang. i ended up with 6 turns on drivers side (1 turn for my weight) and 5 turns on passenger side.
strangely, with the trd pro bilsteins and CF 2".. my height was 23.75". now with the kings i'm at 23.5". but if stock is 20", am at really 3.5" over stock?
Old 11-09-2022, 12:29 AM #21
cumminsdieselfreak's Avatar
cumminsdieselfreak cumminsdieselfreak is offline
cumminsdieselfreak is on a distinguished road
Does anyone know if the KDSS coilovers/brackets will work on a non-kdss model?
2022 4Runner ORP: Elka 2.5 DC, SPC UCA, 285 Cooper Rugged Trek
cumminsdieselfreak is offline   Reply With QuoteReply With Quote
Old 03-21-2023, 05:12 PM #22
flippedcracker's Avatar
flippedcracker flippedcracker is offline
flippedcracker is on a distinguished road
This is the issue I'm having. I installed Kings over the weekend, but my passenger tire rubs on the reservoir when at full lock to the left. The driver side doesn't rub for some reason. I'm running the stock ORP rims still, with 285/70, so wondering if spacers would reduce the rub until I get different rims with a different offset.
flippedcracker is offline   Reply With QuoteReply With Quote
Old 03-21-2023, 10:54 PM #23
Yes you'd need spacers or wheels.
OR wheels have the least amount of offset so they're tucked in more than any of the 4runner wheels.
assembly , king , part , shock , shocks
5th gen king shocks dd210 For Sale: Suspension/Wheels/Tires 8 06-11-2020 10:24 PM
what king shocks vendors keep shocks in stock? chrissurfr 5th gen T4Rs 5 08-25-2018 02:27 PM
Question For Those With Rear King Shocks Kirk_B 3rd gen T4Rs 4 02-27-2017 04:21 PM
Question for those running King shocks on their 4th gen Rocket61 4th Gen T4Rs 0 05-16-2015 11:01 AM
