Old 01-07-2021, 01:05 AM #1
krhayes79's Avatar
krhayes79 krhayes79 is offline
Real Name: Kelly
krhayes79 has a spectacular aura about krhayes79 has a spectacular aura about
krhayes79's Avatar
Real Name: Kelly
Dobinsons MRR/MRA Suspension Questions
Calling all Dobinsons MRR/MRA suspension owners for a little help/tips with my upcoming install Friday evening and Saturday morning. I appreciate every and all replies!
(I did search for these answers throughout the forum and I read through a lot of the Dobinsons threads but I was not really able to get the answers/pics I was specifically looking for)
First, I have to say a big THANK YOU to @Crikeymike for getting me all set up with my order and the help in my many questions on the quest for a successful new suspension set up.
I am looking for everyone else who has this set up to please provide some feedback on the following:
  1. Can you please provide pics & location you mounted your remote reservoirs - did you use the provided mounting hardware or did you have to come up with a different method? My concern is the long line from the shock to the resi and it rubbing or getting caught up somewhere. I also want to make sure I have easy access to adjust the settings.
  2. Any specific items for this MRR/MRA setup I should be on the lookout for when completing the install?
  3. What measurement did you use from the bottom (middle of the hole) of the shock to the lip of the seat to achieve your (x)" lift? I am planning for 3" and know it will settle after the initial install and drive before alignment. Did you have to make any adjustments after they settled?
  4. What settings are you running for your low speed, high speed, and rebound for daily driving and offroad driving?
  5. What alignment numbers should I be after with the Dobinsons UCAs? The target is for 3" lift in the front and 2" lift in the rear
I am fairly decent in the garage and have done all my own installs. However, this will be the first suspension project I have done and for me, knowledge is power. I do have buddies who will be there to help and support me, so I will have some experience in there with me.
I really appreciate the feedback and suggestions I look forward to reading!
Thank you!
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
krhayes79 is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 12:44 AM #2
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
Talking
Thank you!
I’m just coming for the free food.
Daikon is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 10:10 AM #3
Anand Anand is offline
Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough
  • Can you please provide pics & location you mounted your remote reservoirs - did you use the provided mounting hardware or did you have to come up with a different method? My concern is the long line from the shock to the resi and it rubbing or getting caught up somewhere. I also want to make sure I have easy access to adjust the settings.
Full disclosure, I don't have the MRAs, but I did help a good friend install his, so here's what I can offer
For the front resi's we used the included mount, some stainless hardware we had laying around (bolt, washer, washer, lock washer, nut) and found a pre-existing hole through the body "above" the shock tower. Essentially the resi's sit just above where the 3 14mm nuts are on the top hat. Installing the hardware for this bolt hole definitely required 2 people and some patience, partially because the passenger side was under his second battery and the drivers side is under the added tray to hold electrics.
For the rear resi's we used the included mount and sandwiched it between the bumpstop and the frame using one of the bumpstop bolts. He's running Durobumps bumpstops, which afforded plenty of "squish" while still tightening down fine. If the hoses for the resi's were about twice as long you could go for a more traditional mounting location like many other companies use.
  • Any specific items for this MRR/MRA setup I should be on the lookout for when completing the install?
Especially for the front, make sure you have the hose for the resi's going in the direction you want before you place everything into the upright; part of this goes along with us trying to find a location to mount the resi's and a lot of trial and error.
OH! The rear's, maybe we are just really inexperienced, but allowing them to extend while keeping them compressed enough to fit into the bottom mount was.... interesting. I think we ended up setting them to full soft to better facilitate this.
  • What measurement did you use from the bottom (middle of the hole) of the shock to the lip of the seat to achieve your (x)" lift? I am planning for 3" and know it will settle after the initial install and drive before alignment. Did you have to make any adjustments after they settled?
They came pre-assembled and weren't touched. That being said, they've been on my buddy's truck for a few months now and I don't think they settled much at all. For reference, he's running 352 springs with steel skids, dual batteries, aluminum full bumper, and a winch. In the rear his truck probably settled 1/2" with the initial springs (701V's), since then he has upgraded to 749V's with almost no settling.
  • What settings are you running for your low speed, high speed, and rebound for daily driving and offroad driving?
I know he played around with them a bit, but started from the Prado setting. I believe he went 2 clicks stiffer on both compressions. As of yet, he makes no adjustments for off-road driving
  • What alignment numbers should I be after with the Dobinsons UCAs? The target is for 3" lift in the front and 2" lift in the rear
Get as much caster as you can (3º-4º or more is great), everything else to factory
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
Anand is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 04:23 PM #4
krhayes79's Avatar
Real Name: Kelly
krhayes79's Avatar
Real Name: Kelly
Thank you for your response!
We will def find the mounting locations before installing the strut, that is a great tip! Would it be possible to get a pic of where the resi's are mounted front and rear?
Appreciate the help!
Old 01-08-2021, 07:07 PM #5
Actually, yes... I'll take some pics this evening, I'll be seeing the truck then
Old 01-09-2021, 09:14 PM #6
krhayes79's Avatar
Real Name: Kelly
krhayes79's Avatar
Real Name: Kelly
Hi There, were you able to get the pics? We are ready to mount the fronts.
Old 01-10-2021, 11:13 AM #7
For people in the future that need it also... Here are a few pictures of my buddy's resi locations
Front:
Rear:
Old 01-11-2021, 10:52 AM #8
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Front:
The way those fronts resi's are installed, they're extremely likely to get hit with the UCA on full up travel. It's not recommended to be mounted there for that reason, plus you're limiting/blocking access to adjust the rebound adjuster on the top of the strut.
The resi needs to be forward or rearward of the strut tower, out of the way of all moving parts (like the UCA's) and the tires that can turn in towards it.
https://exitoffroad.com/wp-content/u...ting-Guide.pdf
I suggest you do a full suspension travel test and check it out. IF that resi gets loose, you could destroy it, and the hose, and if that happens, you'll need a full dismantle of them to clean and replace the oil and parts that got damaged.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 02:41 PM #9
Thanks for that info Mike, I'll pass it along to the owner of the truck!
Old 01-11-2021, 03:32 PM #10
TaNk007 TaNk007 is offline
Real Name: 2017 TRD PRO
TaNk007 will become famous soon enough
Here is mine on 2017 TRD Pro
Damping control settings are awesome, Settings are preferred how you like your ride quality to be. I'm 4+ clicks Positive and love it there. about 400+ miles on this suspension now ( went snow wheeling and mild off-road ) not a single issue in rubbing
Dobinsons MRR/MRA Suspension Questions-20210111_112800-jpg  Dobinsons MRR/MRA Suspension Questions-20210111_112814-jpg  Dobinsons MRR/MRA Suspension Questions-20210111_112827-jpg  Dobinsons MRR/MRA Suspension Questions-20210111_112832-jpg  Dobinsons MRR/MRA Suspension Questions-20210111_112847-jpg  Dobinsons MRR/MRA Suspension Questions-20210111_112854-jpg
TaNk007 is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 01:28 PM #11
krhayes79's Avatar
Real Name: Kelly
krhayes79's Avatar
Real Name: Kelly
I really like your front resi mounting position. Did you use existing holes or did you have to drill holes in the frame? How about the rears? from what I can tell, those are not pre-existing holes.
Appreciate you sending pics!
Old 01-13-2021, 11:53 AM #12
the front went into existing holes and rear one existing and one I drilled a hole and added rivnut
Old 08-15-2021, 03:45 AM #13
joshik joshik is offline
joshik will become famous soon enough
Hey TaNk007
How is that rear mounting location doing for ya? No problems with tires rubbing it? My bro has the Fox 2.5 dsc and the resis are sorta in the same place... maybe sticks out a little further from the frame and further back and his tire rubs when the tire is stuffed. Yours looks like it would be ok.
I finally got my rear springs this week and got to installing the rear setup tonight. The pass side supplied mounting worked like a charm but the driver side sucks balls. The pictures on Exit and Dob page are nothing like the 4th gen... at least for my 4th gen. The existing holes in the frame with the mount cause the resi to hit a bracket on the frame and the gas tank. If you push it back the resi goes into the spring. I've been trying to tweak it by drilling new holes but gave up for tonight.
I like how you mounted them. Might got that route.
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 09-08-2021, 01:38 PM #14
Originally Posted by joshik View Post
Hey TaNk007
Hey, no rubbing issues I went to 285 and it still clears fine
dobinsons , install , lift , set , suspension
Dobinsons 5th Gen T4R Suspension options - from Exit Offroad Crikeymike 5th gen T4Rs 3368 05-08-2024 02:17 PM
Dobinsons Suspension - 4th Gen Options Crikeymike 4th Gen T4Rs 1242 05-06-2024 01:56 PM
X-REAS VS Dobinsons suspension Nape4 4th Gen T4Rs 1 07-07-2020 01:11 PM
Dobinsons Suspension Lift Installed ProfessorP 5th gen T4Rs 19 07-31-2019 11:50 PM
