01-08-2021, 03:44 AM
Tire balancing issues
Recently installed a set of bfg ta ko2 E rated 10 ply tires on stock wheels.
I think I didn’t get a very good tire balancing job on the installation. My truck was wobbling/shaking slightly on highway at 100km/h speed.
Then, after the first off road trip of my new tires, 100km/h speed shaking is gone, now it’s shaking at about at 61-63km/h speed.
I am not sure what made this change, maybe the tire balancing weights/ bricks fell off, or there are some muds stuck in wheel.
Is it worth to spend $ to re balance my tires?
I heard that off road tires are difficult to be balanced perfectly, and once get balanced, they will go out off balance again after next adventure.
Do you guys have this similar issue on your tires?
What do you think about this type of slight vibrations on off-road vehicles?
Thanks in advance!
Reason: My English is bad
01-08-2021, 06:55 AM
Real Name: Special Ed
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
01-08-2021, 10:48 AM
I'm going thru this right now on K02 C rated tires. On my 4th balance right now and I'm only at 1500mi on these things. Discount does have the Road Force balance if you want to try that.
Going today to balance the front again and hoping for the best.
I've read most people have this issue with C rated K02's vs the E rated. Either way I hope you getting it resolved
00-JZX100
10-Trail Ed.
01-08-2021, 11:03 AM
I’ve had no balancing issues with the E load Grabber ATX since day one. It’s been roughly 1300 miles and they’ve remained balanced even after some very rocky trails. Nothing but smooth riding all the way up to 85 mph.
2017 SW SR5
I would double check tire pressure first. E rate tire pressure should be around 40-45 PSI. I had 32 PSI for almost 2 years and the steering wheel would shake at on ramp speed.
Then I would rotate tires back to front to see if it makes a difference. While you are on it, check if mud got stuck inside the wheels.
01-08-2021, 11:51 AM
I couldn't get rid of the steering wheel shake until I ditched the KO2s.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
01-08-2021, 12:08 PM
Originally Posted by Nobody Special
I second this...at our shop we roadforce everything under a 35in tire.
2012 Salsa Red Trail with KDSS
5100's with lift,285/70/17 Duratracs,some extra wattage and speakers in the stereo system.
2003 Chevy Tahoe 4x4 - 20in Rep's, lowered and loud 4x4
2002 Ford Crown Vic Sport - new project
01-08-2021, 12:23 PM
It's worth repeating, Roadforce balancing is important and making sure the lug centric adapter is used on the balancing machine with oem wheels.
I recently had C rated K02's mounted and just naively trusted a random tire shop chain and of course, they had neither and had a pretty noticeable 60mph vibration through the steering wheel. I didn't waste any more time and had a Toyota dealer with both items in place correct it and they confirmed they were way off. 100% resolved afterwards.
2018 TRD OR - Classic Silver
01-08-2021, 12:39 PM
I've had no problems with my BFG KO2 E rated tires.
Most of the tire dealers I have dealt with have a lifetime balance warranty, so a rebalance should not cost you anything.
Check the lug nuts to be sure they are tight. The Toyota 4runner uses those weird lug nuts with washers built in, so they must all be tight and the wheel must be centered on the hub when you tighten the lug nuts.
01-09-2021, 07:48 PM
Yes you definately want to have the tires Road Force Balanced. But the most important thing is the operator of the RFB machine must KNOW how to use it properly. I have been to multiple tire shops that had the RF, but the punk ass kids running the machine couldn't give 2 fuks about how the tires were balanced. I run the OEM size BFG KO2's, Load range C (6 ply) with 39 lbs air (front & rear) & it is as smooth going down the Hiway as the OEM Bridgestone "P" rated tires.
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
01-09-2021, 08:19 PM
Road force balancing is mandatory. If you run on the tires too long with the high speed shake issue going on, they will wear uneven and it is near impossible to clean up. If they don't clean up with road force balancing, demand new tires.
01-09-2021, 08:52 PM
It also puts your bushings through hell.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
01-05-2022, 06:26 PM
Adding another data point:
I got my C rated K02's at Costco. This includes lifetime rotation and rebalance. The last two times I had them rotated/balanced, I got the telltale steering wheel shake at 55-60MPH. I went back to Costco, they balanced them a second time and all was good after that.
I've been using this particular Costco for tires for many many years now, on 5 or 6 different vehicles. I've never had any issues with them at all. They've always done a good job on the install. I've never had any balance issues until I got my K02's rebalanced.
Current: 2017 TRD Off Road with KDSS
Previous: 2003 Sport Edition AWD
Before That: 1993 Pickup, SR5 V6 5MT Extended Cab 4WD
01-05-2022, 09:26 PM
I am on my 2nd set of K02 tires, one set E and one set C. I have not had any balance problems with either set. Both sets were mounted and balanced by the Toyota dealer. If you tighten one lug nut too tight before tightening the others you can warp things and cause balance problems. Be very careful. I have ran anywhere from 30 to 40 psi on the E tires and it remained balanced at any psi. I replaced the E tires with C tires when the E tires wore out.
01-05-2022, 09:34 PM
I agree. I bought some new C rated KO2 last June and they have been smooth sailing. I would try balancing them one more time but if you still have problems then I would ask for new ones. Sometime a tire just doesn’t get molded right.
