Old 01-07-2021, 04:01 PM #1
EmotionCRZ EmotionCRZ is offline
EmotionCRZ will become famous soon enough
XM Antenna no reception?
Hi,
Has anyone had their XM antenna randomly die? I tried refreshing the signal many times with no luck.
EmotionCRZ is offline   Reply With QuoteReply With Quote
Old 01-07-2021, 04:49 PM #2
GG5thGen's Avatar
GG5thGen GG5thGen is offline
GG5thGen will become famous soon enough
GG5thGen's Avatar
I have never had that problem with any of my cars. Are you sure there isn't a glitch with your service?
GG5thGen is offline   Reply With QuoteReply With Quote
Old 01-07-2021, 05:24 PM #3
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Radio Message "check antenna"
XM not working
XM Not Working After Airbag Recall Work
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 12:57 PM #4
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by EmotionCRZ View Post
Hi,
As a long time electronics professional, I have learned that this kind of problem is often caused by poor connections.
Thus the first step is to unplug and replug the antenna connectors on the back of the radio. Often, just the remove and insert on the connector pins is enough to wipe off any corrosion. If you can get to them, do the same for ny connectors between the radio and the antenna.
If that doesn't work, use a the contact cleaner Caig Deoxit D5 on the contact pins. DO NOT use any other brand of contact cleaner other than D5 for they often damage the connector.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 05:09 PM #5
UPDATE:
Replaced the XM Antenna. It was very loose and the screw holding the antenna to the roof was rusted. I took the old antenna apart, some water was inside the antenna assembly. Went to a new car wash recently, with a very high power dryer, thinking that might of loosed the antenna, and then it snowed the next day. Will check the antenna bolt to make sure it doesn't loosen up every year or so. New antenna works perfectly.
Old 01-09-2021, 01:42 PM #6
UPDATE:
Glad you found the problem and got it fixed.
antenna , die , refreshing , signal , times
Diversity antenna- reception fix for aftermarket hu Mafster Engines / Suspension / Wheels / Tires / Audio / Accessories 54 12-05-2018 11:15 PM
Disconnect antenna amp better reception than when connected? Huh? rpm215 4th Gen T4Rs 6 07-31-2018 12:33 AM
FM reception\ antenna plugs on AVN 5510 question. progress4m Engines / Suspension / Wheels / Tires / Audio / Accessories 7 07-06-2011 05:41 PM
Better AM Antenna Reception? spooner 4th Gen T4Rs 1 07-03-2007 04:26 PM
Antenna reception wth Scion Changer Bernie Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-30-2004 12:45 AM
