Old 01-09-2021, 12:44 PM #1
Paragon1's Avatar
Paragon1 Paragon1 is offline
Paragon1 has a spectacular aura about Paragon1 has a spectacular aura about
Paragon1's Avatar
Head Scratcher... ALT-S fuse mod
Strange charging issue noticed after installing ALT-S fuse mod to cover AGM battery. Huge thanks to @4RunnerAquasport for the help so far but now its time to subject myself to 4Runner webMD diagnoses.
Replaced Battery today under warranty. Stock fuse shows the following. Pics are with the vehicle off, idle, and internal display idle voltage respectively.
When i installed the ALT-S fuse mod (from Dirty Parts), the internal display shows charging at ~14.2/14.3 volts. But the battery is showing 16 Volts at the terminals at idle. Thinking that cant be good, despite the mighty 4Runner operating without issue at those levels for a 20mi round trip at least.
Any ideas what can cause the disparity? Is 16v too high for an optima battery? Could the tune associated with being supercharged have changed something? Could it be the two amps drawing from the battery are causing the system to increase output? Also blew the 120amp fuse and a couple others last spring, (dealer replaced everything)
Lots of confusion happening at the moment. This isn't how i like spending my saturdays.
2021 JGC Trailhawk (waiting for the 6th Gen 4R
2015 Silver TE: (SOLD) KDSS, ICON stg 2, Magnuson, Victory Blitz sliders, Fuel Blitz DDT 18x9 w/ -12o/s, 275/65/18 Nitto TGG2, ARB skids, Spidertrax spacers, Alpharex Luxx, Rigid 40” Stealth LED bar & 360 fogs, Switch Pro 9100 w/ Mount Tray, KC Flex Dual Ditch Lights, KC Cyclone Rock Lights, LED interior, SSS hybrid winch bumper, 30" Rough Country single row LED, Alpine ILX-F308/R line speakers, 8" Alpine Powered Sub. Prinsu Full no-drill roof rack.
Paragon1 is offline   Reply With QuoteReply With Quote
Old 01-09-2021, 12:47 PM #2
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Your multi meter might be off. More investigation needed.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 01-09-2021, 01:00 PM #3
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
16V is definitely too high for any 12 volt lead acid battery, AGM or not. You are over charging your battery and that is why it failed and you had to replace it. The reason for the over voltage? Could be the fuse mod or the voltage regulator in the alternator. I would first remove the fuse mod and see what your voltages are. If they are still high, that would indicate the voltage regulator has been damaged.
The different voltage readings is probably due to the different places that are used for the indicators and probably not the meter itself.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-09-2021, 01:02 PM #4
Real Name: Brett
Real Name: Brett
This is after my truck idled a charge for 20 minutes, now at rest. Your meter may be off by a volt or more.
Head Scratcher... ALT-S fuse mod-20210109_115052~3-jpg
Old 01-09-2021, 01:13 PM #5
Beneaththewheel Beneaththewheel is offline
Beneaththewheel is on a distinguished road
Could be
Beneaththewheel is offline   Reply With QuoteReply With Quote
Old 01-09-2021, 02:10 PM #6
Paragon1's Avatar
Paragon1's Avatar
All voltages shown in the photos are with stock fuses. I’ll be getting a different meter on it this evening. My thoughts are I either have a faulty meter, or the voltage regulator was somehow damaged when I blew the 120a fuse. Reason I suspect the latter is because it shorted in the lead from the alternator cable to the fuse box. I had disconnected the battery but the cables came up and made contact and I didn’t catch it.
Old 01-10-2021, 12:07 AM #7
Paragon1's Avatar
Paragon1's Avatar
Problem solved, I have a bad meter, tried two others that showed a 1.5vt difference from the one I own.
Love this forum, Thanks for the help!
Old 01-10-2021, 10:47 AM #8
Real Name: Brett
Real Name: Brett
Cool!! I'm not right very often lol. It's good to know I have half a brain left.
Old 01-10-2021, 01:01 PM #9
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
I may be mistaken, but the meter shown in the opening post looks like the $5 variety available at Harbor Freight. I have a collection of those and have found they all read much higher than higher quality meters.
I sometimes carry one around in the vehicle I'm driving. While not accurate, they'll at least let me know if a circuit is dead.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 12:46 PM #10
Slvr5Spd Slvr5Spd is offline
Slvr5Spd is on a distinguished road
How many of yall have done this ALT-S mod? is it worth it? it's only $5. What are the long term benefits? I first heard about this on another FB Page for the T9 stereo.
Slvr5Spd is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 01:01 PM #11
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
already many long discussions:
"Voltage Booster" for 31M AGM Battery
jhguth is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 01:02 PM #12
Is this dirtyparts replacement fused as well?
If not...I hope that circuit never exceeds 7.5A
Old 01-11-2021, 04:38 PM #13
Paragon1's Avatar
Paragon1's Avatar
Yes. It has a 7.5A fuse.
Old 01-11-2021, 04:40 PM #14
Paragon1's Avatar
Paragon1's Avatar
Yeah I’ve never really had to mess with circuits to this level of accuracy. I went full retard anyway and dropped $95 on a “good” one, at least it works, hopefully it’ll be used for more than just car mods haha
alt-s , battery , fuse , idle , mod
Slight miss, a real head-scratcher!! Ggradtech 3rd gen T4Rs 20 03-20-2018 04:26 PM
15 MPG to 8 MPG Head Scratcher 89FourRunner Classic T4Rs 4 01-07-2018 02:28 PM
98 4 Runner Head Fuse??? rhartman911 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 02-13-2017 09:13 AM
Head scratcher - Oil on passenger floor NegroTundra 3rd gen T4Rs 13 01-06-2017 09:35 PM
Engine Idle pulsing randomly - head scratcher popageorgio Classic T4Rs 31 01-21-2011 03:37 AM
