Old 01-11-2021, 05:10 AM #1
smpsmp smpsmp is offline
smpsmp is on a distinguished road
Odd Shift Lock Issue
So I've run into this twice in the last month or so. Each time it was kind of similar scenario of not driving far, and then stopping quick and running in somewhere. Basically each time, pulled into a parking spot, put it in park and set the parking brake, turned car off, and got out. All normal.
When I got back in I started up with no issues, but noticed the shifter was locked into park. Attempted to just rock the car quick, and nothing. Each time had to use the override to unlock it. Not a fuse, as I double checked just in case, but it was two random incidents separated by weeks. Also noticed the brake lights were working since each time it was at night.
Anyone have any ideas on what might have randomly sparked this? Maybe put it in park too quick and something just caught up wrong on the shift lock control? Wasn't sure if they go bad slowly or more of an instant fail.
Thanks for any help.
smpsmp is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 11:01 AM #2
fkheath fkheath is online now
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
Are you sure it is the shift lock and not the parking pawl in the transmission? Try changing the sequence when you stop by applying the parking brake BEFORE you shift the transmission into park. That gives less stress on the parking pawl, making it easier to shift out of part when you start up again.
fkheath is online now   Reply With QuoteReply With Quote
Old 01-11-2021, 12:27 PM #3
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
check your brake light fuse
jhguth is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 08:00 PM #4
I've thought about the parking brake, but its not that its hard to shift out of park, it literally is locked (like trying to shift when the car is turned off locked up).
Checked the brake light fuse, its all good. Each time it happened the brake lights were working.
Old 01-11-2021, 08:11 PM #5
next thing to check would be switch on the brake pedal
Old 01-11-2021, 08:24 PM #6
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Chances are high that it is the shift lock solenoid which prevents you from shifting out of park.
The switch on the brake pedal activates this solenoid.
With the key on or running, press the brake pedal multiple times and it may engage the solenoid.
Had to do this many mornings until I could fix it.
seatia is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 09:06 PM #7
Shadytype Shadytype is offline
Shadytype is on a distinguished road
Your story doesnt say anyrhing about you pressing on the brake pedal to shift the car out of park. This is required.
Assuming you are doing this as it is not every time.
I agree with the pawl reccomendation for the trans. Esp if on an incline, which would make sense why you are engaging the parking brake.
Definetly pbrake first, then park. That solenoid isnt too strong to retract against a weighted transmission.
Shadytype is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 09:35 PM #8
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
Just a note... That may help.
My '02 4R was backed into, hard.
No real damage due to protection, but something happened where I could not shift out of park.
I forgot exactly what I did 17 years ago, but more or less zip-tied the little override lever next to the shifter, up.
Only thing is, it can be shifted into gear without your foot on the brake.
At the time, I remember thinking this was something like the Ford fuel cutoffs, where suspects would back into the police cruisers and disable them by tripping the cutoff.
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 09:43 PM #9
MAXISTYLES's Avatar
MAXISTYLES MAXISTYLES is offline
MAXISTYLES will become famous soon enough
MAXISTYLES's Avatar
I would put the parking brake prior to putting it in park, not the other way around as you mentioned.
MAXISTYLES is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 12:05 AM #10
Does anyone know the part number for the shift lock solenoid? I could only find the shift interlock solenoid (part inside the ignition), but nothing for a solenoid under the center console besides the shift lock control computer.
shadytype, I press the brake pedal when shifting.
Old 01-12-2021, 12:48 AM #11
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
What year your is your 4Runner? Some folks with 4Runners (a few years old) that live in snow country have had problems with the shift selector switch (on the side of the transmission) causing hard shifter movement and wrong gear indications; which result in issues similar to the ones you describe. The switch assembly gets corroded from road salt and grime, in part because it's not sealed. There are threads on this you can search for, including one member that removed his and cleaned it (not an easy job) for a temp repair.
Old 01-12-2021, 01:23 AM #12
fly, it's a 2017. Gets the normal salt treatment in the winter thanks to Penndot.
Old 01-12-2021, 03:52 AM #13
flyrv9's Avatar
flyrv9's Avatar
Some folks are reporting a P0705 code with a bad neutral safety switch. I can't find the thread that had the pics (it may have disappeared thanks to the photobucket issue. Googling Toyota 4Runner neutral safety sw should give you some pics. It's on the passenger side of the transmission.
noticed , park , quick , shift , time
shift lock smoa1980 4th Gen T4Rs 5 04-14-2024 04:47 PM
Does this sound like the Shift Lock ECU? OzarkCreeker Classic T4Rs 7 05-08-2022 12:35 AM
Shift Lock Question wethernt 3rd gen T4Rs 1 03-31-2015 02:14 PM
Shift Lock mjtien 4th Gen T4Rs 2 05-27-2012 04:59 PM
