Old 01-11-2021, 08:23 PM #1
gordonf gordonf is offline
gordonf is on a distinguished road
Why negative offset causing more rubbing?
Posting in 5h gen forum as my question is in particular about TRD OR vs TRD PRO wheels for this gen.
So, TRD PRO wheels have more negative offset rather than regular TRD wheels.
Negative offset means wheel is pushing out of well.
So why pushing wheel out of well means more rubbing?
Is not it opposite - so the wheel touches less things in the well?
Thanks for the explanation!
gordonf is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 08:49 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
It would move wheel away from suspension but when making lock-to-lock turns it may cause some contact with with wheel well either front or rear I think is what happens.
Old 01-11-2021, 08:57 PM #3
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Yep, it brings the leading edge/corner of the wheel/tire closer to the bumper when maximum steering input is applied. Can also bring it closer to the body mount too.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 09:57 PM #4
A-ha, so outer well hole has less diameter than in the middle of the well?
That explains things.
I eventually want to put 285s on TRD PRO wheels but I strictly do not want to touch body mounts (cutting/pushing fender liners, pushing mudguards is OK).
If it will not be possible, around 1-1.5" lift will be also possible.
Old 01-11-2021, 10:08 PM #5
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
It's not really the wheel well that changes from inboard to outboard.
Think of it this way. The pivot point of steering is fixed for the wheel. When you widen the wheel or push it further away from the pivot point and turn it, it has a wider arc. Short vs. long arm. It pushes the outer edge corner of the tire further outboard, but when turned that translates into more forward/aft displacement.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 10:42 PM #6
RedSled's Avatar
RedSled RedSled is offline
RedSled has a spectacular aura about RedSled has a spectacular aura about
RedSled's Avatar
This may help as a visual.
Why negative offset causing more rubbing?-fd0bb7ca-965d-4e16-b247-c2110c527302-jpeg
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
RedSled is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 10:50 PM #7
TEujunga's Avatar
TEujunga TEujunga is offline
TEujunga has a spectacular aura about TEujunga has a spectacular aura about
TEujunga's Avatar
It's called "scrub radius." Moving the wheel outboard of the steering centerline results in a negative scrub radius, which can cause the tire to rub on the fender. Here's another image:
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
TEujunga is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 11:07 PM #8
Last image is precious!
Now it absolutely explains the reason.
Looks like lift will not help there too much, so may be I'll stuck with 275 tires then, it's a pity there is not a lot of C-loads there not talking about SL ones .
Old 01-12-2021, 12:17 AM #9
ElJefe's Avatar
ElJefe ElJefe is offline
Real Name: Jeff
ElJefe will become famous soon enough
ElJefe's Avatar
Real Name: Jeff
I thought the same thing about negative giving me more space. Thanks for this as that explains a lot!
2018 SR5 Premium | Dobinsons 3"/2" - F300/549 R325/705 | Dirt King Tube UCA | HIKEit Throttle Controller | Prinsu 3/4 Rack | Xenon Depot High Beams | Boslla B4 Series LED Low Beams | Lensun Hood Solar Panel | Rockpals Powerstation & Fridge
4Runner Mod Inspiration: https://trail4runner.com/
ElJefe is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 02:36 AM #10
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
Here is my Pro with 1.6" Eibach springs in front and 1" in rear with 285's. Zero rubbing while turning. Haven’t had heavy off road yet.
2022 4 Runner SR5 Premium--For Sale:ConsoleVault safe, HikeIt throttle controller
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 02:58 AM #11
Thanks for the input, this is interesting!
Besides lift - did you do any mods? Like fender liner mod?
Old 01-12-2021, 06:11 AM #12
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Mine is basically the same as DallasTRDPro including tires, except I am running 1.5/1” Cornfed spacers on my Pro. No mods or rubbing with 285’s. Still have my front mud flaps. On the Pro the combination of the wheel width and offset along with the port fender mod creates no rub and very minor rub in maximum articulation conditions off road. Center of hub to front arch = 22.5”, rear = 23.25”. Go 285’s. You won’t regret it.
Why negative offset causing more rubbing?-50e25bfb-5d9e-488c-9d90-2fa94e80a45e-jpg
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 09:10 AM #13
Looks really great and sounds very promising!
You mentioned very minor rub offroad - what place is it rubbing?
Old 01-12-2021, 03:19 PM #14
I will also say when I had spacers on the TRD wheels it rubbed like crazy. Plus I like the tires tucked a little more on a 4R.
Old 01-13-2021, 06:58 PM #15
I did a 128 mile Offroad trip a few weeks ago and there would be a very slight scuff once in awhile on the front inner fender liner.
negative , offset , trd , wheel , wheels
Negative Offset Wheels w/ 285s Co4runnin 5th gen T4Rs 19 04-10-2023 11:39 PM
Wheels with negative offset Chilow 5th gen T4Rs 1 05-14-2020 12:59 PM
Wheel offset vs rubbing 4Runner4Leon 3rd gen T4Rs 2 12-01-2019 07:37 PM
2019 T4R PRO W/ Negative Offset Wheels Bm3r1 5th gen T4Rs 4 01-26-2019 09:07 AM
Konig Countersteer X aggressive < 4 backspace, negative 20 offset QSVeilside Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-13-2012 01:34 AM
