01-12-2021, 10:20 AM
Diode Dynamics SS3 LED Fog Light
Anyone here get these sets for their rig? I just received mine and have yet to install it. Just wondering if you had any issue re-aiming the lights? The brackets that came with it doesn't seem to give much play to adjust up or down.
01-12-2021, 10:28 AM
Real Name: Bird Dog Overland
Have them on mine. The Pro model. I suggest angling them down in the housing prior to install. These things are bright, so don't be worried about angling them down too much. Love mine and I think you'll be very happy with yours.
01-12-2021, 10:29 AM
fog lights. not sure how much aiming you need. usually just down a bit..
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
01-12-2021, 10:30 AM
Installed mine a few weeks ago in about 15min. Easy peasy.
Actually had to adjust mine up a bit. So far no one is flashing me yet.
00-JZX100
10-Trail Ed.
01-12-2021, 11:41 AM
OK. Sounds like I have nothing to worry then. Comparing to stock, there was a lot more play on those, allowing more room for adjustment.
Glad to hear about the good experiences. I ordered mine a couple of weeks ago, but was told they were on backordered for quite a bit. To my surprise, they showed up within a week of ordering them.
01-12-2021, 11:54 AM
have the pros on mine. adjusted mine up a bit and have only had one car flash me over the last several months
01-12-2021, 12:34 PM
If you do them one at a time like I did, try to have it lined up with factory bulb and housing on the other side. I believe that mine are almost all the way angled down.
| IG: daks.4rnr | 2018 TRD Off Road Premium | Dobinsons 302/505 700/705 | Dobinsons UCA | Shrockworks Angled Sliders | RCI Skids | C4 LoPro | Prinsu 3/4 |
01-12-2021, 01:26 PM
Tis true. I ordered from HotShot Offroad on Tacoma World Forum and had to wait a bit. Same for DD chase lights/pods.
They are pretty popular right now
00-JZX100
10-Trail Ed.
01-12-2021, 02:06 PM
Do these SS3s work on 2021 T4Rs? DD's website has em listed 10-20MYs only
01-12-2021, 04:50 PM
I have the Amber Sports and like them a lot. Not too bright. Good for daily driving.
They are easy to aim by pushing on the top or bottom of the housing wiht a little force.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
06-15-2021, 12:21 PM
Just installed the SS3 Max fogs on my bumper.
Made a quick video out of it here if you want to watch it.
But here are the main screenshots out of it.
Headlights only
Headlight and SS3
Baja Designs Squadron Sports
Headlights, Baja Designs, and Diode Dynamics SS3 Max all on.
SS3 Only
Headlight only
SS3 only
YouTube
06-15-2021, 12:30 PM
I still have the SAE fog PRO's in yellow from my 4Runner, they don't fit in my new vehicle sadly, so they are available if anyone is looking, they were in my 4Runner for about 6 months, like new condition.
I loved them when I was using them, amazing output, lights the ditches up like daytime, which was great for watching for wildlife while in rural areas.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
06-15-2021, 01:40 PM
Headlights only
Headlight and SS3
SS3 Only
Headlight only
SS3 only
Impressive! Based on extensive personal experience with the SS3 Pro and Max Fog models though, I'd suggest that you might be a tad high with your current aim. You've got a pretty sizable dead zone immediately in front of the truck that a properly aimed fog beam should fill.
06-15-2021, 02:39 PM
Thanks! They are a bit high aren't they? But they're on top of my bumper above the stock fog light housing. I played with them the other night and if I aim them lower, it's just a straight horizontal beam on the ground and no light spread on the ground. Kind of looking for a middle ground situation at the moment.
The good thing is my Baja Designs takes care of that dead zone behind the SS3's.
I possibly intended to change the SS3 lens to their driving/combo lens to see further on those foggy nights in the future. Or the Baja's to a spot lens (they're recessed into the bumper anyway and I feel like I'm not getting the potential wideness). But I'd like to see how they perform in the rain and fog as is right now.
YouTube
06-15-2021, 05:31 PM
Theoretically speaking, fog pattern lights should be mounted as low as possible. As you've already discovered, mounting them higher makes correct aiming next to impossible.
Driving pattern lights can be mounted higher with fewer ill effects. I might recommend just swapping the BD lights to the higher positions and the DD lights to the lower ones to get the maximum effect. You will lose some width on the fog pattern though because of the recessed mounting.
Remember also that the DD SS3's have a completely road legal beam pattern, but the BD Squadrons do not.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
