Old 06-15-2021, 08:19 PM #16
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
Originally Posted by Too Stroked View Post
Theoretically speaking, fog pattern lights should be mounted as low as possible. As you've already discovered, mounting them higher makes correct aiming next to impossible.
Driving pattern lights can be mounted higher with fewer ill effects. I might recommend just swapping the BD lights to the higher positions and the DD lights to the lower ones to get the maximum effect. You will lose some width on the fog pattern though because of the recessed mounting.
Remember also that the DD SS3's have a completely road legal beam pattern, but the BD Squadrons do not.
This X2, put the DD SAE fogs in the fog position and they'll work better than up higher, easier to aim, more light where you want it.
The fogs seem to do a great job of filling in where the other beam is blocked width wise, complimenting each other nicely.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 12:17 AM #17
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
I definitely agree with both of y'all. Unfortunately I opted for the square bezel so it may not fit in the housing. I'm not opposed to running it how it currently is. Who knows, may look into a different lens sooner than later
I usually only run the yellows if it's raining bad and more. Just used to treating it how it is with my BD fogs.
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 06:14 AM #18
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
The other thing that may be making it impossible to properly aim your fogs is the "shelf" in the bumper that the fogs currently sit on. If it's too deep and the fogs are mounted too far back on it, this will prevent the beam from shining downward at all. Just a thought.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 01:14 PM #19
SidKo's Avatar
SidKo SidKo is offline
SidKo is on a distinguished road
SidKo's Avatar
Thoughts on Amber Sport vs Pro
So the Pro in white was way too bright. Here in NY, there is some talk about cracking down on excessively nright lights, so I am going to take opportunity to switch to amber lights. I will repurpose the white lights as ditch lights and retrofit them with the square bezels.
But I wanted to get some feedback from the group about amber lights - sport vs pro? My use is primarily using on the roads in Catskills, NY area. Higher elevation with fog throughout the year. Deer and other animal running across the road is a constant hazard here.
SidKo is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 01:58 PM #20
Originally Posted by SidKo View Post
So the Pro in white was way too bright. Here in NY, there is some talk about cracking down on excessive lights, so I am going to take opportunity to switch to amber lights. I will repurpose the white lights as ditch lights and retrofit them with the square bezels.
Real world experience and recommendations from upstate NY. The Pro is brighter than the Sport, but the pattern is not as well defined. Said another way, the flat, horizontal pattern is taller. What this will lead to is better lighting, but the possibility of bothering more oncoming drivers. Properly aimed, this will be a minor problem.
The Sports have a very well defined beam pattern and put out an amazing amount of light - especially for the money. If you like to run your fogs all the time, these are the only way to fly. Again, they have to be aimed properly.
I'm currently running the Selective Yellow Max fogs in my 4Runner and absolutely love them. The output is amazing and they rarely bother oncoming drivers. (I don't run them all the time though.) Aim is really critical with these.
Old 07-06-2021, 03:46 PM #21
rhadam's Avatar
rhadam rhadam is offline
rhadam has a spectacular aura about rhadam has a spectacular aura about
rhadam's Avatar
I have the fog amber sports. I also have the Pro SS3 ditch which i'll use for a pseudo comparison. The sport fogs provide solid coverage both forward and past the 90 degree angle. I live out in the country with a lot of deer and other animals that love to run around on the roads and can confidently say that the sport model provides a lot of clarity for this specific purpose.
The Pro SS3 ditch in amber are powerful.. sometimes too powerful. I have toyed with the idea of upgrading to pro for the fogs until I put on my ditch lights. I think for me.. the pro fogs would be too bright and almost reduce some visibility if there are trees/bushes or other objects that may reflect the light. The sport is bright enough yet not too bright. If that makes sense. And as said above, the sports aren't causing issue for oncoming drivers. And I run the fogs whenever my low beams are on. They just look so damn cool.
2017 T4R OR Super White
RRW RR4-V bronze wheels, Diode Dynamics SS3 Fog + Ditch, C4 Fab Lo Pro Winch Bumper + Smittybilt 10k synthetic, UpTop Overland Bravo Roof Rack
Dobinson's full suspension 2.5" front 1.5" rear - Dobinson's UCA - DirtKing LCA
Kenwood eXcelon 10.1 headunit + Kenwood speakers
rhadam is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 04:32 PM #22
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
I have a set of amber fogs sitting on the table waiting to get installed. I just need to wait 5-7 more weeks to get my arm out of a sling and range of motion to install them. The sale is really good.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 11:54 PM #23
chops84 chops84 is offline
chops84 is on a distinguished road
I still have the SAE fog PRO's in yellow from my 4Runner, they don't fit in my new vehicle sadly, so they are available if anyone is looking, they were in my 4Runner for about 6 months, like new condition.
I loved them when I was using them, amazing output, lights the ditches up like daytime, which was great for watching for wildlife while in rural areas.
I’m looking. How much you want for them?
chops84 is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 10:25 AM #24
IanB's Avatar
IanB's Avatar
They are now sold.
Old 07-09-2021, 12:08 AM #25
Nooooo….😭😭😭
Old 07-09-2021, 09:33 AM #26
SidKo's Avatar
SidKo's Avatar
Thanks for the feedback folks. Opted for the amber sport. It sounds like that is plenty good enough due to its excellent engineering and design. As someone mentioned here. I too found the white Pro too bright as some of the light scattered back, even with it aiming downward.
Old 07-09-2021, 11:01 AM #27
Snowtrooper Snowtrooper is offline
Snowtrooper will become famous soon enough Snowtrooper will become famous soon enough
Nice choice. My wife summarized them best as I followed her sports-car on a short road trip:
“Distinctive, bright as hell but not annoying.”
(If only she described me that way)
Snowtrooper is offline   Reply With QuoteReply With Quote
Old 01-23-2022, 10:41 AM #28
jblawrence25's Avatar
jblawrence25 jblawrence25 is offline
jblawrence25 is on a distinguished road
I am reviving an old thread I know, but do you still have these available?
- Josh
jblawrence25 is offline   Reply With QuoteReply With Quote
Old 01-23-2022, 01:46 PM #29
Dorobuta Dorobuta is offline
Dorobuta is on a distinguished road
I installed the DD SS3 Pro fog lights in amber on my 5th gen. Install was easy - other than the stupid shroud over the light on the passenger side. Aiming them was a pain, though. Only because it was awkward getting my hands and the hex key up there to tighten everything down once I had them aimed properly.
Diode Dynamics seems to be the best bang for the buck right now.
2016 TE Premium, Barcelona Red. Icon Stage 2, Motometal Wheels and BFG KO2 285/70R17s, Demello Hybrid Sliders, Wet Okole covers, Prinsu full rack, and Westscott designs ladder. Diode Dynamics SS3 Pro amber fog lights.
The only things stopping me now are physics and law enforcement
Dorobuta is offline   Reply With QuoteReply With Quote
Old 01-25-2022, 11:36 AM #30
IanB's Avatar
IanB's Avatar
- Josh
No, they have sold.
brackets , give , issue , lights , re-aiming
Diode Dynamics SS3 Fog Light Kit Installed snowpeak 5th gen T4Rs 123 06-17-2021 05:46 PM
Diode Dynamics SS3 fog light review Sea_ledford 5th gen T4Rs 8 02-01-2020 02:36 PM
