09-15-2017, 10:31 AM
Real Name: Jason
Real Name: Jason
Sunroof / Moonroof closes (almost) then opens halfway
So I pulled up to work this morning and after trying to close my sunroof, it stopped at the almost closed position then slide to the half way open spot. Did some looking around on the forums and haven't come across this issue yet (will try more during lunch). I found some instructions on how to reset the sunroof, based on info from the 4th gen thread, but it requires you to have the sunroof closed and use the tilt button...
Anyone have any thoughts?
09-15-2017, 10:36 AM
Registered User
Real Name: Jay
Registered User
Real Name: Jay
I'd check the track, and make sure there isn't any debris caught somewhere near the spot it stops at. Sometimes they kick open again as a safety feature if they feel resistance.
09-15-2017, 10:52 AM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
Disconnect battery for 10 minutes or so.
09-15-2017, 11:08 AM
Real Name: Ron
Real Name: Ron
Both of the above - - -
Totally stock 2013 SR5 4WD. Have added Toyo Open Country M/T LT 265/70-R17 (E) tires the first week I owned it. Added second set of Toyo M/Ts at 86900 miles.Added RCI OFF-ROAD Rock Slidersat 84000 miles. Added RCI OFF-ROAD front skid plate at 90,000 miles. Daily driver and so far spending about 30% of time/mileage off-road. Previous truck 2004 Land Rover Discovery that also spent about a third of it's life off-road. I HANG AROUND HERE "THE T4R FASHION FORUM" JUST FOR LAUGHS.
Perfect vehicle as it stands for northern Nevada terrain. Keep it stock - it'll go most anywhere as is.
09-15-2017, 11:15 AM
If there's nothing on the tracks... there's a re-initialization proceedure in your owner's manual for the 5th gen, section 3-5, "when your moonroof does not close properly" It doesn't state that the moonroof has to be closed to start. There's a proceedure with the slide button and one for the tilt.... here's what it says about the slide
1. stop the vehicle
2. press and hold the slide switch in the closed position,
the moonroof will close, reopen, and pause for approximately 10 seconds, then it will close again, tilt up and pause for approx 1 second. finally it will tilt down, open and close
3. check that the moonroof is completely closed, and then release the switch
good luck!
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
09-15-2017, 12:19 PM
Real Name: Jason
Real Name: Jason
Working! Thanks everyone for the help,
@ nb rob
's post seemed to do the trick. I like the solution too, "If it doesn't work right, just hold the switch down forever until it does."
12-01-2017, 04:11 PM
Real Name: Nick
Real Name: Nick
1. stop the vehicle
good luck!
Sorry to revive an old thread I just wanted to say thanks because I was kind of in panic mode and this worked for me!
2016 Trail Premium Mag Gray w/KDSS, TRD Pro Wheels wrapped with Cooper STT Pro 285/70R17, Fox Shocks 2.5" remote resi with DCS adjuster F/R, SPC UCA's, Pelfreybilt bumper, 15% Ceramic Window Tint, Shrockworks sliders, TRD Pro Intake, Baja Designs sitting on Rago Ditch Brackets and Ecotechne Rack, Rago MSPs in Cargo area, Baja Designs LEDs
12-01-2017, 04:45 PM
Real Name: Eddie
Real Name: Eddie
emailed myself this thread just in case
As Is: 2014 SR5 Premium. Replace 3rd Row with DIY drawer. Front SPC UCAs + Icon LT + Coils. Rear Daystar @1.5 + Icons. ARB Springs. 285/70-17 Duratracs. Antman tailgate Mod. AVS Bug Shield. V1 radar detector. Front Runner rack. AlphaFoxTrot ladder. 32" auxbeam in lower grille. Rago ditch brackets. 2 x Auxbeams pods in ditch and 2 rear facing. ARB2000 + Room. AVID Offroad Sliders. Midland MXt275. Iceco JP50 fridge + Slide.
Maybe time for a build?
IG: eddiezt4r
12-01-2017, 08:02 PM
This can also be applied for issues with the power windows.
04-17-2019, 05:38 PM
Glad I found this thread! The owner's manual method saved me.
02-02-2020, 01:08 AM
amazing! i just bought a used 4runner and had this issue. the car had a brand new battery, maybe that's why. i fixed it by opening the sunroof and then just holding close for a long time!
11-18-2023, 08:29 PM
Real Name: Joel
Real Name: Joel
1. stop the vehicle
Thanks so much for this fix. Mine would only close if I got it close, about 3 in away from being closed, and then give it little bumps and nudges with the button until it was all the way closed.
I opened the moonroof to 100%, followed the directions above by holding the button for 10 seconds and then continuing to hold. Not sure if I had to continue to hold or not. But the system is reset and the moonroof is closing properly.
Thanks so much for this advice so many years ago!
Save an Athlete. Adopt a Greyhound!
2010 4Runner Limited
