Old 01-15-2021, 07:43 PM #1
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
Red face Attn: Aux light bar installs with CUSTOM brackets, etc. Not cookie cutter.
I want to get some ideas for behind the lower grille.
Do any of you have photos of your installs using stuff you fabbed up, NOT" off-the-shelf"?
Been looking here and there for a few days, off and on, and will be installing three on a LTD/NS.
Google image search isn't all that conducive either.
Plan is...
One will be heated due to the stock LED headlights, and two fogs, one on each side of the heated unit.
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 09:37 PM #2
tough to beat the off the shelf brackets TBH. BUT i'm gonna do a combo. Rago fab behind the grille brackets, rago outside the grille tabs (they suck but they'll work) and i have a extruded aluminum cross bar coming in the mail to bolt to the tabs. from there i'll mount 3 Baja Designs XL Pro's. plan is to easily remove the cross bar/lights when not on trips.
Old 01-15-2021, 10:03 PM #3
Can't use anything that is out there (that I have seen thus far) as I am going for three separate bars and the LTD front fascias are the oddballs...
Old 01-15-2021, 10:25 PM #4
1/4" plate, cut and weld, drill holes where needed, bolt it up. its not difficult, just time consuming.
Old 01-15-2021, 11:12 PM #5
Well aware. I was going to bend up some aluminum but am interested in seeing how different people approach things.
google , heated , image , installing , installs
Absalom's Cookie Cutter 4runner Builds - New and Updated! absalom 3rd gen T4Rs 238 07-12-2023 04:12 PM
Custom Ambient Light Brackets Speedy 3rd gen T4Rs 7 02-13-2020 08:31 PM
This is NOT another Cookie Cutter Build NZDZRT 5th gen T4Rs 13 04-02-2016 12:29 PM
Need help with Cookie Cutter build warriorwagner 3rd gen T4Rs 3 06-02-2015 08:54 AM
