Old 01-15-2021, 12:09 PM #16
Captain Planet's Avatar
Captain Planet Captain Planet is offline
Captain Planet will become famous soon enough
Originally Posted by blksubykid View Post
Nearly the same setup. I have my SPOD, Blue Sea distribution block, and circuit breakers on the drivers side
I went with an RTMR fuse panel and a breaker.
Captain Planet is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 12:26 PM #17
NotaTRD's Avatar
NotaTRD NotaTRD is offline
NotaTRD will become famous soon enough NotaTRD will become famous soon enough
NotaTRD's Avatar
Originally Posted by 4lo.ko View Post
Good insight.
Doesn't the Rago mount come with space for the switchpro unit too?
Thanks for the suggestion on LFD, i'll look into them too.
I don’t think you’ll have room left for a switchpro on the Rago mount with a twin on there. Here’s mine with a single and I feel like there isn’t a whole lot of room to work with.
2017 SW SR5
NotaTRD is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 04:21 PM #18
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
There's room. The shelf in the back is quite large.
Switch Pros recommends vertical mounting, so you'd ideally want to orient it vertically which would require a bracket.
So if you don't need an extra fuse block, it's quite an elegant and space-saving install.
rageandlove is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 04:41 PM #19
NotaTRD's Avatar
NotaTRD's Avatar
I stand corrected :thumbsup:
2017 SW SR5
Old 01-18-2021, 06:18 PM #20
Lollerskates Lollerskates is offline
Lollerskates is on a distinguished road
Passenger side. I went with the 4x4 Labs mount. Don't remember having any issues with the install, haven't had any issues yet.
ARB Air compressor bracket for 5th gen 4Runner – 4X4LABS
Using PowerTrays on driver side to mount electrical components.
Switch-Pros PowerTray > 4Runner/ FJ Cruiser/ GX – PowerTrays
Lollerskates is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 11:08 AM #21
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
I only have a single, but went passenger side with 4x4 Labs mount...very well done. Save the driver side for electrical.
ARB Twin Owners: Where did you mount?-air-compressor-jpg
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 11:08 AM #22
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
<<<< is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 12:26 PM #23
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
Originally Posted by ryguytheman View Post
Mine is on the driver side (Slee Offroad mount). I would highly recommend putting it on the passenger side. There is very little room for me to work with. I got the manifold for adding a locker, and the manifold won't fit in the current positioning.
Tons more room on the passenger side.
It is super tight, but does fit. There are spacers that should be included in the kit to clearance the bracket away from the fender, allowing room for the hood strut to fold down.
That said, I mounted my manifold upside down accidentally, but it still fits with two locker solenoids hooked up and the air hose attachment for filling tires.
My buddy runs the Slee mount with the manifold mounted along the side of the inner fender and it’s pretty clean, I think that was Stellarbuilt’s idea.
I couldn’t run the compressor on the passenger side cause I have a dual battery with smog pump relocation and aftermarket washer reservoir over there.
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 04:22 PM #24
2112 R's Avatar
2112 R 2112 R is offline
2112 R will become famous soon enough 2112 R will become famous soon enough
2112 R's Avatar
I have mine mounted on a Slee tray on the drivers side and while easy to install, I wish I had gone passenger side.
The driver side placement just gets SUPER hot when inflating as half the compressor is hanging over the engine and getting blasted with heat.
The heat can transfer to the inflation hose and cause a failure. When it happened to me I was lucky to have trail buddies to inflate my tires.
I solved it by adding 1.5 M extra braded hose down the side near the fuse box to dissipate the heat some before ending at the hose coupling.
2112 R is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 06:37 PM #25
<<<<'s Avatar
<<<<'s Avatar
Even the small air tank helps to run it cooler. I've 0.5 gal seamless bottle under mine.
arb , fully , gallon , side , tank
FS - 5th Gen ARB Twin Compressor Mount (Pass Eng Compartment) - $115 to $150 bandi For Sale: T4R Items 147 11-02-2021 12:14 PM
Twin ARB Compressor mount location grapemilk 4th Gen T4Rs 14 05-16-2018 10:52 AM
ARB Twin on Slee Mount - Mud issues? xravexboix 5th gen T4Rs 6 01-10-2018 12:26 AM
Where to mount an arb twin compressor? NWFLBowhunter 3rd gen T4Rs 11 12-11-2016 12:37 PM
ARB Twin Compressor mount underhood? Victor 4th Gen T4Rs 1 04-15-2015 01:16 AM
