Old 01-14-2021, 03:37 PM #1
4lo.ko 4lo.ko is offline
4lo.ko is on a distinguished road
ARB Twin Owners: Where did you mount?
Driver side, passenger side or inside cab, and why?
Future goals:
- deflation / inflation
- Rear air locker
- switch pros
- 1 gallon tank? Who fully utilizes a tank and for what?
Thanks in advance.
4lo.ko is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 03:58 PM #2
Captain Planet's Avatar
Captain Planet Captain Planet is offline
Captain Planet will become famous soon enough
Passenger side on a Bandi mount.
Has 1gal Viair tank underneath. Goes to manifold which goes to a regulator and then to two QD's for hoses for tire filling and air tools.
There are extra ports in the manifold for other things, maybe an air horn down the line.
The tank lets you fill tires faster and run tools off of it.
Captain Planet is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 05:47 PM #3
Thanks for the feedback! That's one reason I would also install on the passenger side. Fill that empty void with the ARB Twin and a gallon tank.
Old 01-14-2021, 06:26 PM #4
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
I started with driver because I liked the the Rago mount (design, quality, aluminum so virtually no weight added) but I am moving it to the passenger because I'm adding a switch pros and it makes more sense on the driver side.
I think if you want a tank, passenger side is the spot.
Bandy mount requires some relocation of stuff, so I went with LFD because I didn't want to disturb anything, a few folks gave it good reviews, and it's stainless so no rust.
rageandlove is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 06:54 PM #5
ryguytheman's Avatar
ryguytheman ryguytheman is offline
ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice
Mine is on the driver side (Slee Offroad mount). I would highly recommend putting it on the passenger side. There is very little room for me to work with. I got the manifold for adding a locker, and the manifold won't fit in the current positioning.
Tons more room on the passenger side.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
ryguytheman is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 07:05 PM #6
Good insight.
Doesn't the Rago mount come with space for the switchpro unit too?
Thanks for the suggestion on LFD, i'll look into them too.
Old 01-14-2021, 07:07 PM #7
Good feedback! I'll put that into consideration.
I guess it would make a cleaner look on the passenger side huh.
Old 01-14-2021, 07:24 PM #8
Krayziekid's Avatar
Krayziekid Krayziekid is offline
Real Name: Jake
Krayziekid will become famous soon enough
Krayziekid's Avatar
Real Name: Jake
I'll echo a few people here. Passenger side with the Bandi mount. Can't go wrong. I had the mount on my 4th gen and then when I upgraded to a 5th gen, I immediately went with the 5th gen mount with the air tank.
That passenger rear side is the perfect place for the twin and a tank. I run the twin to a tank to a manifold and it has worked perfectly for the past two years through hundreds of air-ups and air-downs and lots of off-road miles. You can't go wrong.
Leaving the driver side open for an aux fuse panel or switch pros or something is definitely the right move if you plan on adding additional lights or other accessories in the future. Shorter wiring runs is almost always better!
"Po" - '18 Super White TRDORP - Build Thread Here
"Sirius Black" - '03 Limited V8 Build (Sold) - Build Thread Here l 03->06 Headlight Swap Guide
My Photography // My Videography
Krayziekid is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 09:11 PM #9
It only requires relocation if you live in a nanny state with airpump versions.
I had to relocate nothing on my 19
Old 01-14-2021, 11:42 PM #10
choochoo choochoo is offline
choochoo will become famous soon enough choochoo will become famous soon enough
Mounted the CKMTA12 on a M.O.R.E Offroad mount (which is sized for a 1 gal air tank underneath) on passenger side. Already had Switch Pro unit mounted on a Power Tray on the driver's side.
choochoo is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 12:02 AM #11
ATX14 ATX14 is offline
ATX14 will become famous soon enough
Driver’s side with the Rago mount. I mounted my sPOD on the passenger side (not shown in this picture).
ARB Twin Owners: Where did you mount?-18fdb28f-442a-422a-881e-708899892d78-jpg
2017 T4R TRD Off-Road Premium, Metallic Gray, CBI Off-road steel bumper, CBI Aluminum Skid Plates, Smitty Built 10k winch, Fox 2.5 DSC/remote reservoir w/ Eibach 700# front coil spring replacement, Icon 2" rear coil springs with Sumo Springs, Prinsu Roof Rack, Rago Fab. Window Storage Panels, Method Wheels 285/70/17 BF Goodrich KO2.
ATX14 is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 03:43 AM #12
TheWraith's Avatar
TheWraith TheWraith is offline
Real Name: Justin
TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light
TheWraith's Avatar
Real Name: Justin
Future goals:
- Rear air locker
- switch pros
Thanks in advance.
I have my twins on top of a 1gallon air tank sitting on a M.O.R.E. mount wired to a swing pro. Passenger side; because I have no need to a dual battery set up.
With the 1gallon ( I wish I went with a 2.5gallon Viair mount in rear when the spare use to be) and the 4 tire inflation kit I custom make. Takes 7 to 8 minutes to fill all 4 - 35" tires from 10 -12psi to 38psi. With the 2.5 gallon would be faster
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
TheWraith is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 04:28 AM #13
What’s the maintenance on the tank?
Do you relieve the air if the tank is not in use?
Old 01-15-2021, 05:01 AM #14
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
After every use I depressure the tank... As I don't like driving around with a pressurized tank.
My Build Thread
Old 01-15-2021, 11:35 AM #15
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
Nearly the same setup. I have my SPOD, Blue Sea distribution block, and circuit breakers on the drivers side
blksubykid is offline   Reply With QuoteReply With Quote
arb , fully , gallon , side , tank
FS - 5th Gen ARB Twin Compressor Mount (Pass Eng Compartment) - $115 to $150 bandi For Sale: T4R Items 147 11-02-2021 12:14 PM
Twin ARB Compressor mount location grapemilk 4th Gen T4Rs 14 05-16-2018 10:52 AM
ARB Twin on Slee Mount - Mud issues? xravexboix 5th gen T4Rs 6 01-10-2018 12:26 AM
Where to mount an arb twin compressor? NWFLBowhunter 3rd gen T4Rs 11 12-11-2016 12:37 PM
ARB Twin Compressor mount underhood? Victor 4th Gen T4Rs 1 04-15-2015 01:16 AM
