Old 01-14-2021, 04:29 PM #1
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
2020+ TPMS sensors. What is the deal?
I am interesting in CLONING them OEM's.
No shops want to guarantee a "no light" situation with some saying they are different and their software is not up-to-date.
I want to keep the feature, not bypass, as it is one I actually appreciate.
If you added a second set of wheels and cloned the OEM, which sensors and tool did you use?
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 06:33 PM #2
ragin_cajun ragin_cajun is offline
ragin_cajun will become famous soon enough
Just went through this with my '21...
They are the same TPMS sensors as before, you can order generic. You can either clone them or just buy new sensor and scan them then load into your ecu.
I used the ATEQ Quickset X to do it and it was straightforward. Most shops do not have a TPMS tool that speak to the 20-21 yet. You don't have to clone if you buy the ATEQ. You can load it into the ECU and it automatically identifies and recognizes each corner.
Contrary to popular belief, the ECU will not magically find new TPMS that aren't cloned. You need to load the ID's into the ECU.
ragin_cajun is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 06:38 PM #3
Tanks, bud!
Could I correctly assume you are running two sets of wheels?
Is the ATEQ tool limited to ONLY their sensors?
Any info on the sensors you chose?
Old 01-14-2021, 06:43 PM #4
bamma's Avatar
bamma bamma is offline
Location: Stuck in an electric mountain trap in the Pyrenees or Mars, or Spokane WA.
Real Name: Dark Lord Xenu
bamma will become famous soon enough
bamma's Avatar
I just put on winter tires with all new sensors in my 2020 Limited and the "learn" feature detected them all within 15 minutes of driving. Hooked up Techstream and confirmed it had all the right IDs. (You do have to turn on the detect new sensors feature through the dash menu)
Greg's mother wishes she had aborted him.
bamma is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 06:45 PM #5
Originally Posted by Nobody Special View Post
Tanks, bud!
No issue swapping at all and the ATEQ system will read anything compatible frequency wise. The AUTEL toolsets require their tools, but you can clone easily with them.
I don't think you need to clone though, if you get your own tool it takes 1-2 minutes to do the swap and then your 4Runner corrects itself before you are even out of the neighborhood.
Old 01-14-2021, 06:48 PM #6
Were they Toyota OEM TPMS sensors? I've not seen this work on any of them so far. I've now done this on 8 or 9 20+ 4Runners. I don't think any of them were OEM Toyota (not that it should matter as far as I know)
On my personal rig, it went into the learning sequence and never picked them up over 75 miles of driving. Bought the ATEQ and fixed it in minutes. I guess I'm just not sure why some have problems and others dont?
Old 01-14-2021, 06:52 PM #7
Perfect.
Now... Link the sensors you used.
That way, if I have an issue, you might be able to help!
Old 01-14-2021, 06:54 PM #8
I am trying to avoid using a laptop.
Can you post up your Techstream source though?
For future reference.
I read some get bad stuff from Amazon.
Old 01-14-2021, 06:56 PM #9
Talking
Note... I tried contacting the company the cute chick works for in my sig line, but in three days, no replies to emails, no answering of calls...
Old 01-14-2021, 07:57 PM #10
bamma's Avatar
bamma's Avatar
They were Denso (Pacific) sensors, same as OEM.
Old 01-14-2021, 08:00 PM #11
bamma's Avatar
bamma's Avatar
Amazon.com: VXDIAG VCX Nano Diagnose and Programming Tool Compatible with J2534: Automotive
Other cables work to program some things, but won't program sensors (will read them). The VXDIAG works great and comes with Techstream (hacked copy like every other version out there). Been using it for a couple years now.
Old 01-14-2021, 08:04 PM #12
Danke!
This is what I was looking at
Amazon.com: DIAGKING Mini Vci J2534 TIS Techstream Diagnostic Cable for Toyota Firmware V1.4.1: Automotive
Then you see what looks to be the same for less $$$ with bad reviews.
Amazon.com: Jugger Mini Vci J2534 Cable for Toyota able Connector Scanner Adapter for Toyota TIS Techstream, 16pin Programming Diagnostic Cable TIS Techstream OBD2 USB Cable for Win XP/ WIN7 32bits: Automotive
Old 01-14-2021, 08:09 PM #13
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Thumbs up Tpms
When I bought a set of knockoff wheels OEWheels (great replicas BTW) bought some tpms from them & claim they're Toy . IDK but they worked when we cloned them to truck never had a problem yet !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 08:30 PM #14
For what is listed in your sig?
Apparently shops are having issues with 2020+
As was stated above, they may just need software updates.
Old 01-14-2021, 08:43 PM #15
bamma's Avatar
bamma's Avatar
Yep, avoid those. They work for many features, but not TMPS. I bought two just like those and junked them.
bypass , crazy , feature , oem , sensors
Tpms sensors Robs08Runner 4th Gen T4Rs 21 01-07-2021 07:01 PM
5 TPMS sensors? Sky 5th gen T4Rs 15 12-17-2019 08:49 PM
2020 4R TPMS Sensors - Part Number niadh0 5th gen T4Rs 5 11-03-2019 08:21 PM
TPMS Sensors? phillyd2 5th gen T4Rs 41 05-11-2018 11:22 PM
WTB TPMS Sensors Vladi For Sale: Suspension/Wheels/Tires 1 11-29-2014 07:57 PM
