Old 01-19-2021, 07:49 PM #31
umidkusername umidkusername is offline
umidkusername will become famous soon enough
Most important tool is a torque wrench. I’m telling you, if you don’t tighten things back up right you are literally a bullet on the interstate.
umidkusername is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 10:52 PM #32
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
This link has most of the torque specs
Full List of Suspension Torque Specs For the 5th Gen 4Runner
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 12:09 PM #33
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
So I don't have everything they used in this video. like the spacers for the sway bar and the rear bump stops.
How To Install a Lift Kit On a 5th Gen 4Runner-All The Details - YouTube
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 04:18 PM #34
So I started the lift today, I got the rear out and I am trying to put the springs in without a compressor. I lifted the other side and it opened it up a little but not enough to get the springs in. I am now waiting on a spring compressor. I only need to compress it a inch.
The Build
Old 01-29-2021, 05:46 PM #35
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Could have someone stand on the rotor, may give you what you need. Disconnected the sway bar links and shock on both sides?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 06:46 PM #36
I didn’t use a spring compressor. I just removed the lower shock bolts, sway bar end links and the lower end of the pan bar. While frame is held up, use a jack a lift up one end of the rear end, then the other end allows for the spring to come out. Install the spring and repeat for the other side.
Old 01-29-2021, 08:36 PM #37
So this is where I am at I have everything on, how can I tighten this though, this is the passenger side rear. I now know to pay someone to do this. I am still working on the rear passenger side and havent even started the the drivers rear or the front and I am over 6 hours into this. It's enjoyable but I have no clue how to torque the nut in the picture or even tighten it, the body is sliding and when I use a cresent wrench it is taking the paint off of it.
The Build
Old 01-29-2021, 08:37 PM #38
Imgur: The magic of the Internet
some reason pictures aren't showing up.
The Build
Old 01-29-2021, 08:50 PM #39
Strykar Strykar is offline
Strykar is on a distinguished road
All the tools everyone has mentioned above, wanted to also share if/when you get realigned, make sure they torque the cam adjusting bolts to spec or they will probably clunk like my buddies did, he had to get a 2nd alignment and re torqued to spec.
Strykar is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 09:14 PM #40
Which bolts ? Top of the rear shock ?
Old 01-29-2021, 09:18 PM #41
This was my first time installing a suspension in a 4unner.
1. When installing new UCA, do I need load the arm before torquing ?
2. When installing pan bar, do I need to load it before torquing ?
Old 01-29-2021, 09:20 PM #42
Charlievee's Avatar
Charlievee's Avatar
Not sure what brand shock your using, but most have flat sides on the top stud that you can hold with a small wrench. Barring that, jack up the axle to compress the shocks, may help. From the one pic, looks like a missing washer on the lower bushing.
Old 01-29-2021, 10:34 PM #43
This viedo helped a ton,but I dont have the 6mm square at the top of the threads to tighten the top shock but. I ended up taking the shocks off and re doing it like the video.
https://www.youtube.com/watch?v=oxV-...ature=youtu.be
The Build
Old 01-29-2021, 10:38 PM #44
Its OME Nirto shocks nike in the video below I am just missing something to tighten the nut down.
The Build
Old 01-29-2021, 10:43 PM #45
In the area circled. Is there a flat spot there to put an open end wench ? If no, the you’ll have to hold the body down as you tighten top nut.
hard , needed , shocks , tonight , tool
Rear Suspension Question - Non-lifted NorthIdaho4runner 3rd gen T4Rs 2 12-23-2011 05:37 PM
99 lifted... ball joint question.. rvg112 3rd gen T4Rs 1 03-09-2011 03:41 PM
Question about rear leafs on an already-lifted '87 Philbert Classic T4Rs 15 05-22-2009 08:12 PM
84 4runner lifted - shifter question? Tack427 Classic T4Rs 2 09-22-2005 10:51 AM
Lifted runner towing question T4RUSAF 4th Gen T4Rs 1 07-15-2005 10:38 PM
