01-29-2021, 10:54 PM
#46
01-29-2021, 11:02 PM
#47
Originally Posted by daytonaviolet
Also in this pic, you can see the washer between the shock and lower bushing.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
01-29-2021, 11:13 PM
#48
Once I saw that I took everything ogg and made it right.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
01-30-2021, 03:33 AM
#49
You don’t need a ball joint separator. A dead blow hammer will separate the ball joint from the spindle.
Originally Posted by delloro
Wrenches and sockets up to 21 or 22 mm. A spring compressor, rented mine for free from Autozone. Jackstands. Breaker bars and torque wrenches.
Only specialty tool I recall was the spring compressor, and a ball joint separator.
I spent all day but I work slowly, as I enjoy it.
01-30-2021, 08:28 AM
#50
.make sure to disconnect the ABS wire when you get to the fronts. No point risking damaging the wire when its easy to remove.
01-30-2021, 10:50 AM
#51
The fronts will be today, I am just looking for videos on how to do it a little easier than last night.
The Build
01-30-2021, 11:42 AM
#52
Just take your time. One side at a time. The bolt for the UCA will be frustrating, extra hands may help, but it is doable solo.
01-30-2021, 11:46 AM
#53
So I just watched this video and they put a washer under the top bushing in the rear and in the video I watched last night they used the bushing for the bottom of the shock? So which is it? Do I need to take the rear apart again and try to get the shock off for that washer and put it on the top bushing.
https://www.youtube.com/watch?v=KAgSmIdSVeI
https://www.youtube.com/watch?v=oxV-...ature=youtu.be
The Build
01-30-2021, 01:05 PM
#54
Real Name: Sparky
Real Name: Sparky
I lifted 2 FJCs myself (easy).
I outsourced my 4Runner due to KDSS.
I also did the no spring compression method.
Old and (c)rusty.
01-30-2021, 01:58 PM
#55
I have all day today and all day tomorrow so we will see how it goes. Working 1 armed sucks but it needs to get done. Discount Tire said they wont put the tires on and let me leave if it rubs really bad so I am trying to get this done so I can get the tires
The Build
01-30-2021, 02:55 PM
#56
I have not watched the vids yet. ( keep in mind many on tubeyou are hacks, just trying to make some money) Did the kit come with any kind of schematics? The idea of the of the washers or bushing retaining caps or what ever they are being called, is to compress the bushing under "load ". So from the bottom... Shock, washer, lower bushing, frame, upper bushing, washer, nut. Raising the axle will crush the lower bushing, giving you more thread at the top. Tightening the nut will crush both upper and lower brushing until properly torqued.
01-30-2021, 04:03 PM
#57
None so I put the washer on the bottom shock bolt between the LCA and the shock on the shave like the video that does it.
The Build
01-30-2021, 07:06 PM
#58
So, the front is a world easier than the back, everything came off with ease and I am waiting for the wife to come home with Loctite red, I didn't need the ball joint separator, just a few whacks and it came off. I should have it done tomorrow unless something happens that I am not expecting. Yes this is taking me forever but I tore the labium in my shoulder so I can't really lift anything with my right arm. The waiting sucks
The Build
01-30-2021, 07:35 PM
#59
Not sure what happened in your case, but the rear is normally a very quick job.
Various shocks will need various tricks:
Higher-end shocks may have a separate piece that goes into the small hole next to where the stem goes and that prevents rotation.
The Icon 2.0 can be held in place with pliers like this:
Stanley 84-522 $10.91 Tongue and Groove Pliers, 8 In. | Zoro.com
The Eibach is a bit more annoying but not hard with two 19 mm wrenches, one to hold underneath the bottom bushing and the other, ratcheting one, to tighten.
The ratcheting wrench is the key to making this a quick process. Otherwise, it is lots of turns!
(6112s/650lb at 1.25"-1.5" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
01-30-2021, 07:45 PM
#60
Yeah my air tools did absolutly nothing nothing came of when I tried to use them.
The Build
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
