Old 01-30-2021, 10:04 PM #61
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
Well I have hit a standing point, I compressed the front springs as much as I can crank on them and they are not compressed enough to go in. I think I ma going to try to figure out how to put it bck together, I am starting to question what gores where and take it somewhere or just get it towed somewhere. I have done lifts on trucks and xterras and they never take this long or involve taking so much stuff off to get new parts on. I never found the video if the install without a spring compressor. I guess I really messed up.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 12:45 PM #62
dhoang dhoang is offline
dhoang is on a distinguished road
If I had to do it again next time, I would have a shop compress the springs onto the shocks. The spacing between the new coils were so small, It was such a pain to remove the spring compressor from the coils.
dhoang is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 12:58 PM #63
Driver sides donr so I am 3/4 of the way there. I have the passengers side opened up but the UCA isn't wanting to play nice. I will say , doing it the way the video shows for the no spring compressor was a world easier, I have no clue what everyone is taling about when they say compress the spring on the strut, this kit isnt a coilover so I guess its different.
The Build
Old 01-31-2021, 02:28 PM #64
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Thought I posted this...
PART 1 TOYOTA TACOMA STRUTS INSTALL | No Spring Compressor - YouTube
Tacos are the same as our station wagons.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 08:19 PM #65
Well it took almost 3 days pretty much 2 but I did it 1 armed and I think I torques everything down to the best of my ability. When I get an alignment will they re torque everything down they undo?
The Build
Old 01-31-2021, 08:21 PM #66
Thats the video I used. and the front was a ton easier than the rear. I started the rear on friday and it was done friday nnight, the front I started the drivers side around 3-4 and was done by 10 and I started the passenger side close to noon and was done by 5.
The Build
Old 01-31-2021, 08:32 PM #67
Thank you to everyone that helped and posted information.
The Build
Old 01-31-2021, 08:38 PM #68
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Glad to see you figured it all out. Did you take measurements before and after ?
How much lift was your kit ?
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 09:06 PM #69
It's the OME 3 inch lift with the heavy springs front and rear so once I get the rear bumper on it should come down a bit
The rear was
D- 36 1/4 41 something
P - 36 1/2 41 something
Front I had them written down somewhere I will measure when I get home tomorrow It got dark and I am beat.
D -
P -
The Build
Old 01-31-2021, 09:14 PM #70
Charlievee's Avatar
Charlievee's Avatar
Can't imagine doing it with one arm, but glad you got it worked out. When you get a minute, can you go back and answer your own question from post #1 of this thread. It's sure to help others and I would bet you have a wealth of knowledge to share.truck looks good.
Old 01-31-2021, 09:48 PM #71
One last thing..... What's your go to video for a 1 inch diff drop install?
The Build
Old 01-31-2021, 11:40 PM #72
Charlievee's Avatar
Charlievee's Avatar
I don't run the diff drop, but recall it was a fairly simple process. I think wander lost covered it in their lift vid.
Old 02-01-2021, 03:03 AM #73
vt100 vt100 is offline
vt100 is on a distinguished road
Originally Posted by LandCruiser View Post
I outsourced my 4Runner due to KDSS.
KDSS does make it more complicated but insignificantly I'd say. I didn't need to disconnect the front bar at all. Jacking up one side would open (barely) enough room to fit the coilover in.
I did disconnect the rear though but it was very easy to put it back.
2018, TRD Offroad, KDSS, 2.5" Kings w/ reservoirs, TC UCA, Toytec Superflex 2.5", 285/70R17 LT Falken Wildpeaks, BMC, 4x4 labs sliders, Gobi rack/ladder
vt100 is offline   Reply With QuoteReply With Quote
hard , needed , shocks , tonight , tool
Rear Suspension Question - Non-lifted NorthIdaho4runner 3rd gen T4Rs 2 12-23-2011 05:37 PM
99 lifted... ball joint question.. rvg112 3rd gen T4Rs 1 03-09-2011 03:41 PM
Question about rear leafs on an already-lifted '87 Philbert Classic T4Rs 15 05-22-2009 08:12 PM
84 4runner lifted - shifter question? Tack427 Classic T4Rs 2 09-22-2005 10:51 AM
Lifted runner towing question T4RUSAF 4th Gen T4Rs 1 07-15-2005 10:38 PM
