Old 01-14-2021, 08:42 PM #1
dave_b dave_b is offline
dave_b is on a distinguished road
Help! 260k miles, check engine light, multi terrain light, and slip indicator light
Hi everyone, have a 2011 TE with 260k miles. Have maintenance done religiously by the dealer. Turned my runner on this evening, and noticed check engine light is on, slip indicator light is on, and multi terrain light is blinking. Can't turn off multi terrain. Any ideas what this may be?
Background info - just had maintenance done last month and the dealer suggested replacing the lower control arms, brakes, and rotors. Been having random squealing noises when i come to a stop from reverse but no squealing when stopping going forward. Dealer couldn't figure it out the last two maintenance visits. Still have plenty of brake pad on all four corners.
Would appreciate any feedback!
2011 Black 4Runner Trail Edition Non-KDSS
dave_b is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 09:12 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
If you use an OBD2 scan tool for diagnosis, it will likely pull up some error codes that will give you (and us) a better idea of what your dash warning lights are indicating.
Some automotive parts stores provide this service free of charge.
Check Engine Light & Traction Cntrl "Squiggly" Light On
"Multi-Terrain Select Not Available" + Check Engine Light + TRAC OFF
2016 4Runner w/ 8400mi, Check Engine + TRAC Off
Check engine light ?
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 03:46 AM #3
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
Check all four abs sensors.
Daikon is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 01:06 PM #4
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
Sounds like either a bad wheel speed sensor/sensor wire, or possibly a zero point calibration issue.
Given that you've recently had the lca's off, and brake work done, my money would be on a wheel speed sensor wire. If the tech didn't support the steering knuckle properly while he had everything disassembled for the brake/lca work, it's incredibly easy to damage the sensor wire.
An ABS capable obd2 scanner will be able to narrow the fault down to a specific corner (front/rear, passenger or driver). from there, you could swap the wheel speed sensor from the same side (pass or driver) from the rear to the front (L side or R side, they are the same front and rear). Reset the code, then drive around, if the fault reappears, it will tell you whether you have a bad sensor wire. If the fault pops up on the rear, you have a bad sensor.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 01:10 PM #5
Appreciate it Bossman. Error code is P0305 cylinder 5 misfire detected
Old 01-15-2021, 01:21 PM #6
Thank you. This helps a lot. I rarely do any work on my Runner but am somewhat mech inclined so i will try and give this a shot. After the dealer gave me the estimate to replace LCAs, brakes, and rotors, i had to pass on it and plan to do it myself sometime.
Old 01-15-2021, 01:23 PM #7
Will do! First have to figure out how to do that since I've never done it before
Old 01-15-2021, 01:24 PM #8
Jono.ful's Avatar
Jono.ful's Avatar
Suspension work on these trucks is super easy provided you have a basic set of sockets and wrenches. There are a couple things that require specialty tools, but lca's are straightforward. There is plenty of useful info here (including the toyota factory service manual) and if you get stuck, search youtube for a tutorial. Toyota "no spring compressor method" video will cover most of what you need to know to disassemble the lower ball joint, from there, just remove the eccentric alignment bolts and the lca will drop right out.
Old 01-15-2021, 01:26 PM #9
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
When was the last time you replaced spark plugs? Might look into that as a cause along with other things mentioned.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 01:33 PM #10
Jono.ful's Avatar
Jono.ful's Avatar
Completely unrelated to your dash lights. Reset that code and carry on, but if it keeps coming up it may be worth being up with your dealer
Old 01-15-2021, 02:17 PM #11
Jivewalker's Avatar
Jivewalker's Avatar
I may be wrong, but I don't think the code would show unless it had happened more than 3 times, IIRC. That means it is already "keeps coming up." When I run OBD on mine, I have occasionally seen misfire logged as pending, but never got the code.
I would start with plugs, pull and inspect, along with the other things mentioned. Or, just go to a reliable dealer or shop if you can't pinpoint it yourself.
I am fragile.
Not like a flower.
But like a bomb.
Old 01-17-2021, 01:25 AM #12
Daikon's Avatar
Daikon's Avatar
Replace all spark plugs or find out which cylinder is #5, swap the spark plug with another cylinder (A), clear code and see if the comes back as misfire in the cylinder you swapped it to. If the code shows a misfire in cylinder (A), you have a bad spark plug. If the code shows misfire in #5 again, you Nate have a bad coil. You can do the same thing as a swap it with a different coil and see if the MIL code chances.
Old 01-17-2021, 01:52 PM #13
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I would think the ABS light would be on too if it was an ABS sensor. But I suspect the code reader that was plugged into this rig didn't support the ABS/traction control systems. Most generic tools won't. Mine will but I had to pay for manufacturer-specific software. Honestly I would try disconnecting the battery for a bit and see if it clears the lights just for kicks. As for a misfire if it's running fine otherwise I wouldn't freak out about it but when was the last time you changed plugs? and were they OE spec or just what happened to fit from the local chain parts store? It's not hard to swap coils and see if the misfire switches cylinders to determine if you have a bad coil. If you do have a bad coil don't buy a cheap one. Get OE or a Denso. I can't tell you how many cheap coils I have replaced due to failure within just a few months on a variety of different vehicles.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 01-17-2021, 04:00 PM #14
24k miles ago by the dealer
Old 01-17-2021, 04:01 PM #15
Failed to mention my runner has been idling rough or shakey at times recently
dealer , light , maintenance , multi , terrain
"Multi-Terrain Select Not Available" + Check Engine Light + TRAC OFF TRDORmike 5th gen T4Rs 31 01-17-2024 06:31 PM
VSC light, slip, and Check Engine Light on r32 4th Gen T4Rs 8 09-02-2022 07:21 PM
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
[Need help] Warning lights? Multi-terrain & Four-wheel drive indicator light flashing robkh1984 5th gen T4Rs 23 06-15-2019 11:20 AM
ABS, Slip indicator and Multi-Terrain Light Tuc4R Engines / Suspension / Wheels / Tires / Audio / Accessories 5 06-02-2018 10:11 PM
