Old 01-17-2021, 04:14 PM #16
dave_b dave_b is offline
dave_b is on a distinguished road
Originally Posted by Jivewalker View Post
I may be wrong, but I don't think the code would show unless it had happened more than 3 times, IIRC. That means it is already "keeps coming up." When I run OBD on mine, I have occasionally seen misfire logged as pending, but never got the code.
I would start with plugs, pull and inspect, along with the other things mentioned. Or, just go to a reliable dealer or shop if you can't pinpoint it yourself.
Thanks I'll do this. As far as the ignition coils, internet shows just use a multimeter to see if it's bad? Have a copy of the toyota repair manual to guide me. Spark plugs were last replaced 24k miles ago. Forgot to mention my runner has been idling somewhat shakey at random times recently. Surprised the dealer hasn't noticed it last time i had it serviced.
2011 Black 4Runner Trail Edition Non-KDSS
dave_b is offline   Reply With QuoteReply With Quote
Old 01-17-2021, 04:18 PM #17
Originally Posted by 85GT-79FJ40 View Post
I would think the ABS light would be on too if it was an ABS sensor. But I suspect the code reader that was plugged into this rig didn't support the ABS/traction control systems. Most generic tools won't. Mine will but I had to pay for manufacturer-specific software. Honestly I would try disconnecting the battery for a bit and see if it clears the lights just for kicks. As for a misfire if it's running fine otherwise I wouldn't freak out about it but when was the last time you changed plugs? and were they OE spec or just what happened to fit from the local chain parts store? It's not hard to swap coils and see if the misfire switches cylinders to determine if you have a bad coil. If you do have a bad coil don't buy a cheap one. Get OE or a Denso. I can't tell you how many cheap coils I have replaced due to failure within just a few months on a variety of different vehicles.
Dealer replaced plugs 24k miles ago. I was planning on picking up a coil from the dealer
Old 01-18-2021, 08:30 AM #18
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Just because plugs are fairly new doesn't mean they are good, I would pull and check each one. could also be a dirty fuel injector. At some point, after checking the easy stuff, might want to get the dealer to run it on the computer to know for sure. Don't want to cause any damage driving it while trying to figure it out. I do most of my own work, but every once in a while i have to lean on the dealer.
Rough idle could be a dirty throttle body and/or mass air flow sensor. Both are very easy to clean.
Throttle body / MAF sensor cleaning
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 08:50 AM #19
mnofpeace's Avatar
mnofpeace mnofpeace is offline
Real Name: Patrick
mnofpeace has a spectacular aura about mnofpeace has a spectacular aura about
mnofpeace's Avatar
Real Name: Patrick
'...sensor gone bad'...this man has 260,000 miles on his rig...at some point something is going to need replacing.
i cannot add anything to this, good luck to you on your repares.
i HOPE to get to 260K before i am going to need major maintenance or repairs...more power to ya
Patrick L
Ft. Washington, Md.
2014 SR5 w/ 3rd row
My TRD-Pro-Lite
mnofpeace is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 10:19 AM #20
engallop engallop is offline
engallop is on a distinguished road
Hi everyone, have a 2011 TE with 260k miles. Have maintenance done religiously by the dealer. Turned my runner on this evening, and noticed check engine light is on, slip indicator light is on, and multi terrain light is blinking. Can't turn off multi terrain. Any ideas what this may be?
Background info - just had maintenance done last month and the dealer suggested replacing the lower control arms, brakes, and rotors. Been having random squealing noises when i come to a stop from reverse but no squealing when stopping going forward. Dealer couldn't figure it out the last two maintenance visits. Still have plenty of brake pad on all four corners.
Would appreciate any feedback!
I can’t speak entirely for your 4runner but my 2016 with 65k has thrown those three lights at me a few occasions now. The first time, I lost traction on ice and it just turned on, I had to clear it days later then spoke to my friend who used to wrench for toyota for 30 years, he told me it is just a modern sensitive toyota electronics thing and that it was not a problem. Then it happened again two more times, one of them being two days ago....both after I did some work/mods on the 4R in my driveway but the codes cleared themselves by next morning. Hope this gives you some sort of relief but if doesn’t clear itself get a mechanics opinion.
As for the squeal coming to a stop in reverse, is it happening when the cars cold? If you search online, many people have had their concerns but apparently it’s pretty common on Toyota’s and/or most vehicles. My toyota buddy told me its just the brakes adjusting fast from reverse. This also happens in mine and while it used to concern me, I’ve learned to ignore it.
Hope any of this info helps and good luck.
engallop is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 09:17 AM #21
Thankfully no major repairs yet!
Old 01-19-2021, 09:20 AM #22
All of this you said helps! Actually, just yesterday all of the lights turned off. No more check engine, slip, and multi terrain. Now I'm scratching my head. Think I'll still attempt tobcheck everything mentioned so far
dealer , light , maintenance , multi , terrain
"Multi-Terrain Select Not Available" + Check Engine Light + TRAC OFF TRDORmike 5th gen T4Rs 31 01-17-2024 06:31 PM
VSC light, slip, and Check Engine Light on r32 4th Gen T4Rs 8 09-02-2022 07:21 PM
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
[Need help] Warning lights? Multi-terrain & Four-wheel drive indicator light flashing robkh1984 5th gen T4Rs 23 06-15-2019 11:20 AM
ABS, Slip indicator and Multi-Terrain Light Tuc4R Engines / Suspension / Wheels / Tires / Audio / Accessories 5 06-02-2018 10:11 PM
