View Poll Results: Would you buy the same sliders again
Heck yeah, they kick ass
41 |
89.13% |
41 |
89.13% |
Nope, crappy craftsmanship
1 |
2.17% |
1 |
2.17% |
No need for mall crawling
3 |
6.52% |
3 |
6.52% |
I built my own..
1 |
2.17% |
01-16-2021, 08:33 PM
#16
Would you buy the same set of sliders again?
Rsg flat w/top and no kick out . Bolted up perfectly by my self with jack stands. No complaints . Painted them myself with Krylon
Sent from my iPhone using Tapatalk Pro
01-16-2021, 09:32 PM
#17
I have Shrockworks sliders on my 18 SR5 Premium, but all holes matched up; i didn't need to drill another hole. Those stick nuts were kind of a pain though. I went flat with dimple plates. I've been really happy with them so far, but they've only functioned as steps as of today.
01-16-2021, 11:29 PM
#18
I went with SSO. Look great, beefy. Haven’t battle tested them yet, but will this month
01-17-2021, 12:00 AM
#19
So far, I would buy RCI sliders all over again.
2017 SW SR5
01-17-2021, 12:22 AM
#20
You didn't? Do you have frame holes for all the bolts for the front leg of the pax side? That's where the hole needs to be drilled, at least till 2018.
I didn't either but after seeing what can happen (not strong enough and almost got into the rocker panel), I had a whole second leg welded to the slider.
But if you have all bolts that came with the slider in place, you should be just fine.
I am not sure why it lacks a third leg but it does the job and it was a good value as of 2018. Not sure of current prices.
01-17-2021, 04:40 AM
#21
Real Name: BLACK TRD PRO
Yes, I would buy my Shrockworks angled 3 tube, no kick out sliders again. I personally don’t like the look of steps or sliders in general. I wanted the least noticeable slider that would offer good protection. My young son and 5’3” wife use them without issue. I paid a shop $75 to install them. They have done them before and were familiar with the stick nuts. No need to hassle for that price.
01-17-2021, 10:34 AM
#22
I found a deal on a set of NIB ARTEC sliders locally and jumped on them. They were bare steel so I had them powder coated. Bolted right up to the frame, installed bymself. Nice and smooth surface to step on and feel solid, although I did ad some grip tape to keep wet feet from slipping off.
2017 T4R TRD Pro Cement - Dobinsons 2/1" (300/599), IMS 700/701, Air Lift 1000 air bags (60804), Pelfreybilt hidden winch mount, Warn VR8 w/ Amsteel synth, 2021 ORP LED headlights, DD SS3 Sport yellow fogs, CBI steel skid plates, Rough Country 20" LED bar, Gobi stealth no rise w/ ladder, ARTEC sliders, ARB 63qt fridge, Canvasback liners, homemade spare tire hitch carrier, ARB single air compressor w/ Slee mount, bronze TRD Pro wheels
01-17-2021, 10:57 AM
#23
fwiw, i didn’t need to drill when installing my Shrockworks either (as above: 3 support, no kickout; minimalist). 100% would buy again.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
01-17-2021, 11:32 AM
#24
Real Name: Halko
Real Name: Halko
Ive had the Shrockworks step sliders for almost 10 years. Install was easy, powder coat still looks great, rock solid.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
01-17-2021, 01:39 PM
#25
RSG Off Road Sliders
Would you?
Yes I would.
Also 100% happy with my RSG Off Road sliders. I went with the 2010+ Toyota 4Runner Angled Sliders **NO KICK OUT**
@ JasonRSG
builds well made sliders.
Did they bolt up effortlessly, or did you have to drill new holes or whip out the ol' dremel.
They lined up perfectly, no drilling or tweaking. Used 2 jack stands by myself.
Do they stick out far enough from the side panels to offer real protection on narrow trails?
I would think so, they stick out 3-4" from the side body panels. Don't rock crawl, bought for protection when on wood trails hunting.
Flat or angled? Step plates on top or open?
Angled + Open
Do you think the connection methodology is robust enough? (I particularly like sliders that wrap around the frame rail, vs only mount to one side...)
These are very well made and engineered for strength at connection points. All welds are solid and continuous. do not appear to need to be wrapped around the frame.
Is the paint or powder coat holding up, or can you tell it was poorly prepped beforehand?
Seems to be doing fine so far. Appears to be well prepped.
Best Regards,
Saker
01-17-2021, 09:59 PM
#26
I went with C4 Fabrication sliders and I love them. Bolted right up. No issues. Beautiful sliders and pretty low profile, but still gives the rig character.
Sent from my Pixel 5 using Tapatalk
01-18-2021, 08:20 PM
#27
Originally Posted by 5thToy
I would absolutely buy my RSG angled (no kick, no top) sliders again. They are outstanding. Not a single complaint other than they should probably beef up their shipping boxes.
I originally purchased flat, grip hole top plate, no kick. Had them on for a couple of weeks but decided I didn't want a step so I reordered. I still have the flat set and really need to get around to selling them. They are essentially brand new.
INteresting.... Did you find your self not using the step? Needed that last extra little bit of clearance?
Can you still stand on the angled set at all? HOw far away from the body are they? I think I much prefer the angled designs, but being able to reach up to the ski box on the roof is still important...
01-18-2021, 09:32 PM
#28
I'm 6'-1" and single. I basically slide right in to the driver's seat. Sliders as steps are a little higher than running boards, so for me it's actually not helpful getting in and out. It's the same for me with factory running boards. If I had a wife and kids, I probably would have been happy with the flat version.
I can stand on the angled version just fine to access the roof. As far as how far they protrude from the body, it depends on where you measure from. The door curves inward toward the bottom. If you measure looking straight down to where the door curves out of sight, The angled version sticks out just shy of 3". Measuring from the bottom of the door where it meets the outer plastic door sill, just shy of 4".
01-18-2021, 09:39 PM
#29
Real Name: Kevin
Real Name: Kevin
Victory 4x4 Aluminium. Totally yes. Not as easy to use HLJ on (only two places) and bolting them together is surprisingly difficult but totally yes.
I had others before and the weight savings is just too much to give up...
01-19-2021, 03:13 AM
#30
4x4 labs sliders here - 200% yes, I'd buy them again! Protection for KDSS accumulator and lines is exceptional. Though installation (on the driver side) is real pain
2018, TRD Offroad, KDSS, 2.5" Kings w/ reservoirs, TC UCA, Toytec Superflex 2.5", 285/70R17 LT Falken Wildpeaks, BMC, 4x4 labs sliders, Gobi rack/ladder
