Old 01-15-2021, 08:20 PM #1
arouth arouth is offline
arouth is on a distinguished road
Total amount of Watts produced by center console cigarette lighter power adapter?
Hi,
I have an hour and 45 commute and am charging both personal and word devices in that commute so I was wondering what the total amount of watts the center console power adapter can produce?
I put in a dual power adapter with 110 Watts total output. I'll charge my personal iPad (29 watts), my work iPad (12 watts), my iPhone 12 mini (20 watts), and the portable GPS I have (12 watts?), so that's a total output of around 75 watts give or take. It seems like it's charging everything like it should, but just thought I'd check on here. Also, I have trouble finding an actual volts to watts calculator from searching on the internet, so that's why I'm asking.
Thanks
2015 4Runner Trail Edition Premium, Red, KDSS
(Sold) 2004 4Runner Sport Edition, V8, AWD, Silver
arouth is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 08:46 PM #2
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
Watts=volts*amps*power factor
For resistive devices, you can assume a power factor of 1. for electronics it gets a little more complicated, but you're dealing with small loads so it's probably not necessary to worry about in this instance.
You're probably well below the ampacity limit of the power outlet circuit. Did you check the manual? There's probably an actual rating
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 08:55 PM #3
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
I think the outlet is rated for 10 amps, which is 120 watts.
I also use a 120v charger in the center console with two USB outputs. Splits the load from the center stack connector and you can use a quick charge unit there. You have to remember to turn it on after starting.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 10:05 PM #4
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
Usually they are fused @ 15 Amps and with a 12V system, you take 15A and multiply it by 12V and you get 180 Watts which is your safety zone. If you happen to surpass that 180 watts, then your fuse will blow.
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 08-01-2022, 03:02 PM #5
90country 90country is offline
90country is on a distinguished road
total AMPS from all combined cig lighters/ power ports in Runner
Any idea how may total amps I can draw from all the cigarette lighters/ power ports at the same time?
Got my Iphone, hand held ham radio, Engel 45 fridge, and also charging my "house" litium battery often at the same time.
Average running on the Engel is about 5 amps (max at start up for first 30 minutes is bout 30!), I can manage not running other items for an hour.
The battery DC to DC charger has max 8amp output so input is around that figure.
I'm guessing total running amps is about 20... wondering if this is all on one fuse under the hood???
Thanks!
90country is offline   Reply With QuoteReply With Quote
Old 08-01-2022, 08:07 PM #6
Captain Spalding's Avatar
Captain Spalding Captain Spalding is offline
Captain Spalding has a spectacular aura about Captain Spalding has a spectacular aura about Captain Spalding has a spectacular aura about
All three outlets have a combined capacity of 120 watts. (On a 2022 ORP)
Captain Spalding is offline   Reply With QuoteReply With Quote
adapter , personal , power , total , watts
Tapping too much power from cigarette lighter? simple 4th Gen T4Rs 7 12-03-2018 08:36 PM
Console Cigarette Lighter 12V Power Not Working luke87gt 4th Gen T4Rs 8 11-22-2015 07:26 PM
How do I replace center console cigarette lighter? longobongo 4th Gen T4Rs 7 12-23-2014 08:03 PM
110V/cigarette lighter adapter dendad General Discussions 5 11-22-2013 09:04 PM
Use cigarette lighter in other aux power outlet? NathanOfSeattle 3rd gen T4Rs 0 01-23-2013 01:47 AM
