Old 01-16-2021, 01:24 PM #1
graeaglecrawler graeaglecrawler is offline
graeaglecrawler is on a distinguished road
How to re-torque the 19 valve body assembly bolts on the transmission
Has anybody seen a write up on this? I've done some searching bot could not find anything. Looking for sequence , torque etc. Thanks
graeaglecrawler is offline   Reply With QuoteReply With Quote
Old 01-16-2021, 01:58 PM #2
fkheath fkheath is online now
fkheath has a spectacular aura about fkheath has a spectacular aura about fkheath has a spectacular aura about
Try the factory repair manual : TOYOTA 2016-2019 4Runner Repair Manual RM27F0U
fkheath is online now   Reply With QuoteReply With Quote
Old 01-16-2021, 02:35 PM #3
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special has a spectacular aura about Nobody Special has a spectacular aura about Nobody Special has a spectacular aura about
Just curious...
Valve body mod?
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-16-2021, 03:15 PM #4
I'm just changing the fluid in the transmission and came across in a search that you should re-torque the bolts before reinstalling the filter. It mentioned the valve body gasket shrinking over time , then the bolts loosen and fluid can escape to other parts of the valve body instead of where it is supposed to go.
Old 01-17-2021, 02:30 PM #5
I'm answering my own question =). I found the info on youtube in an IPT Performance transmission video on replacing the valve body on an A750F tranny, about 10 mins. into the video. Torque 80 in/lbs. No torque sequence mentioned. There are two bolts obscured by a bracket.
bot , find , searching , sequence , torque
Transmission pan bolts: torque specs with gasket NJ-4Runner 3rd gen T4Rs 10 07-08-2020 10:56 PM
Torque on valve cover bolts? This may be a stupid question... OldRigNewParts Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-22-2018 06:52 PM
Torque specs for body mount bolts? wfo9 5th gen T4Rs 3 10-04-2015 12:07 AM
Transmission pan bolts torque spec? Pranav 3rd gen T4Rs 0 05-28-2005 12:32 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
