Old 01-17-2021, 11:00 PM #1
T4R416 T4R416 is offline
T4R416 will become famous soon enough
KDSS 5th gen suspension AND body lift????
Is it possible to do a say 2-5”-3” suspension lift on a 4runner WITH AND IN ADDITION to a 2/3” body lift??? What would need to be replaced?? Would it affect KDSS? If so or if not what else may be affected ?
T4R416 is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 11:14 AM #2
alphabeast's Avatar
alphabeast alphabeast is offline
Real Name: Shawn
alphabeast is on a distinguished road
alphabeast's Avatar
Real Name: Shawn
Body lift should not affect KDSS. The biggest concern I would have is doing a 2-3 inch body lift. I have heard of a few attempts at a 2" BL with alot of issues and I have not heard of any 3" BL's on the 5th gen. I am running a 3" suspension lift + 1" BL lift w/ KDSS and no issues.
2014 TE w/ KDSS: ToyTec BOSS Suspension Kit / Toytec 1" Body Lift / JBA A-Arm's / Cooper Evolution MT 35" 12.5" / SCS Ray 10 17 X 9 / Budbuilt Bump Out Slider's / Gobi Stealth (No Rise) Rack / Hefty Fabworks Front Bumper / Ellis Precision Auto Shifter & Transfer Case Shifter/ Rigid D-Series LED Fogs / Precision LED Interior Lighting
alphabeast is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 11:43 AM #3
BobWheelerJr BobWheelerJr is offline
Real Name: Bob Wheeler Jr
BobWheelerJr is on a distinguished road
Question That brings up a question
I'm also looking at a spacer kit (I don't want to spend all the money on a complete suspension do-over) for a 2014 4WD Limited and I'm being asked if I have the electronic leveler/pneumatic suspension leveler thingamajobby. Apparently some have it, some don't.
How the hell do I figure that out? Is there something in/on the vehicle I can use to easily identify that, am I going to need to crawl under it and manually inspect, or will I have to call the original dealer with the VIN?
Thanks in advance for any help!!
BobWheelerJr is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 12:11 PM #4
Whippersnapper02's Avatar
A body lift is not the way to go. You may run into wiring and cable (parking and trans) issues. Plus you're putting extra leversge on the body mounts. A buddy ripped a mount from the body on his Ranger.
All Limited have XRES.
Old 01-18-2021, 12:34 PM #5
Thanks! I really appreciate the help. So can I do the spacer kit or should I just spend the extra $1,500 and get some kind of suspension lift/upgrade?
Old 01-18-2021, 02:56 PM #6
alphabeast's Avatar
Real Name: Shawn
alphabeast's Avatar
Real Name: Shawn
Depends on what your goal is. If you want the lift for purely looks, then I would go spacers. If you want to make your truck more functional off-road and handle additional weight better, then I would consider going with a suspension lift.
Old 01-18-2021, 06:03 PM #7
This is EXACTLY what I wanted to do. 1” body lift.. any problems ? Anything to look out for? You did 1” all around? What spacers. ?
Old 01-19-2021, 11:38 AM #8
alphabeast's Avatar
Real Name: Shawn
alphabeast's Avatar
Real Name: Shawn
Spacer lifts go on the suspension which is different than a body lift. I have had no issues with doing a 1" body lift.
Old 01-19-2021, 01:29 PM #9
I know ZERO, about body lifts, is this something you buy for all 4 corners? What’s a decent brand? Or can you just get anything off Amazon?
Old 01-19-2021, 02:18 PM #10
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
A body lift is just spacers above each body mount of the vehicle, so all of them underneath. It's a cheap way to get "lift," but they were really designed to be a cheap way to fit bigger tires. You don't gain ground clearance or anything. I wouldn't run them on a 4Runner and instead do the job right with a suspension lift. If I were lifting an old Chevy truck wanted a cheap way to fit 38s then sure, I'd go for it.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 11:46 PM #11
I see.. I currently have a suspension lift but figure getting another inch higher definitely interests me!
affect , body , kdss , lift , suspension
Suspension for reducing body roll (no KDSS) - need advice _sauce Engines / Suspension / Wheels / Tires / Audio / Accessories 2 01-14-2021 08:17 PM
What is the best suspension/lift with KDSS 4High4Low Off-Roading 0 06-11-2018 12:13 AM
Suspension Lift for 2014 T4R with KDSS? sd3025 5th gen T4Rs 30 06-21-2017 04:40 PM
Lift kit modification alter/null 2012 TE kdss suspension? Akillez13 5th gen T4Rs 12 09-06-2015 06:41 PM
3" Suspension lift- What size Body lift for 35x12.50's? BB6-213 3rd gen T4Rs 10 11-23-2010 10:18 PM
