Originally Posted by Whitemoose
Hello everyone, first post here. I just purchased a 2021 ORP in magnetic grey! I'm adding the eibach pro-truck lift which is 2.75 front and 1 rear, with JBA UCA's. I picked out 285/70/r17 Ridge Grapplers but am having trouble picking rims. I want enough to clear UCA's and have the least amount of trimming possible with the tire upgrade. I really love these fuel coverts, they come in two different sizes and I'm not sure what would be best. Size 1: 01mm offset with 5 inch backspacing. Size 2: -12mm offset with 4.5 inch backspacing. Thanks!!
As was already said that backspacing is known to be a problem with the JBA UCA's. I'd look at a different rim if you have your heart set on the JBA UCA's.
That being said, I run Fuel Revolvers in +1 5 inch. It's a great setup when paired with the right UCA's. I run 285/75's currently and have run 305/70's in the past without any rubbing on the UCA's. However, be prepared to have a BMC and do some chopping front and rear on the fender liner and make sure your caster is between 4 and 5 degrees.
Honestly if you love the rims just get a different UCA that's more universally compatible.
