Old 01-18-2021, 12:54 PM #1
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
Question Nitro Gear 4.56 ReGear - Why the different Gear Oil???
I have searched, and I have asked in another thread... I feel like this needs its own thread because I can't be the only one with this question...
Toyota Differentials (OEM) run LT 75W-85 GL-5 Gear Oil
Nitro Gears recommends using 80W-140 Gear Oil.
So, I am curious...
Why the difference?
What is the risk of running the lighter oil with the Nitro Gears?
If you have regeared, what oil brand and weight are you using???
Background information: I have 165,000 miles on my original 3.73 gears with heavy loads and tons of towing. I had zero metal flakes on the drain at 75,000 miles and 150,000 miles. Last month, I upgraded to a Nitro Gears 4.56 gear set. I did the initial break in then drained and refilled with 80W-140 with the expected fine metal shavings a decent looking oil. I refilled it with Castrol 80W-140 per my mechanic's advice. Since then have put 2,500 miles on the vehicle, and I'm about to change the oil again just to ensure everything is okay. I have noticed that my fuel economy is way down. Power is up, but but I can't break 13MPG unloaded cruising at 55 MPH (I was as high as 18MPG fully loaded - not towing).
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 01:32 PM #2
rdruss's Avatar
rdruss rdruss is online now
Real Name: Ron
rdruss's Avatar
Real Name: Ron
So, I am curious...
Why the difference?
They are speaking from their experience and also advising you that if you have a problem and don't follow their advice don't be surprised if warranty denied.
rdruss is online now   Reply With QuoteReply With Quote
Old 01-18-2021, 08:37 PM #3
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
4.56 put more power to the ground.
More power, more pressure etc...
A lighter oil won't protect as well, (but don't mention that to people who swear by 0W20, even though they are two different applications).
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 10:01 PM #4
007Tacoma's Avatar
007Tacoma's Avatar
That doesn't explain the difference though...
My 3.73 gears looked great after years of heavy abuse with OEM gear oil (changed every 75K).
I'm 007Tacoma.
Old 01-18-2021, 10:05 PM #5
007Tacoma's Avatar
007Tacoma's Avatar
Technically, they are not putting more power to the ground. The ratio is different giving more turns of the pinion gear (input from the drivetrain) allowing the engine to spin at a higher rpm to exert the same amount of force. The pressure is actually lesser on the gears (all other things being equal), they are just having to turn faster.
I'm 007Tacoma.
Old 01-18-2021, 10:23 PM #6
spartacus's Avatar
spartacus's Avatar
You'are dead on. The one negative of regearing. Higher rpms equal less gas milage. What size tires are you running?
Old 01-18-2021, 10:28 PM #7
007Tacoma's Avatar
007Tacoma's Avatar
We are running 255/75R17 Kumho MT71s in C-Load.
I'm 007Tacoma.
Old 01-18-2021, 10:33 PM #8
spartacus's Avatar
spartacus's Avatar
You could go up a tire size and may experience some gain. As'far as why 85-140. ESGS recommends that too. There is a long explanation on their site.
Old 01-19-2021, 10:20 AM #9
007Tacoma's Avatar
007Tacoma's Avatar
Thanks! I'll check it out!
I'm 007Tacoma.
Old 01-19-2021, 10:21 AM #10
007Tacoma's Avatar
007Tacoma's Avatar
I'm guessing you meant ECGS.
I'm 007Tacoma.
Old 01-19-2021, 04:57 PM #11
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
...(but don't mention that to people who swear by 0W20, even though they are two different applications).
So why bring that up here?
Evangelize your motor oil viscosity religion elsewhere please. It is, after all, a different application.
delloro is offline   Reply With QuoteReply With Quote
gear , gears , miles , nitro , oil
--Nitro Gear & Axle + ARB Lockers Groupbuy-- Battle Born Offroad Group Buys 10 11-07-2018 04:30 PM
Nitro Gear -Re gearing question AZrunner11 5th gen T4Rs 27 03-09-2018 01:24 AM
Need to Regear? Nitro Gears GB on TW Babyjake16 Group Buys 1 10-20-2017 03:50 PM
2007 FJ Cruiser Elocker Rear 3rd member 3.73 Nitro Gear Solid Pinon Spacer vvtisupra For Sale: T4R Items 1 12-28-2015 10:46 PM
