Old 01-19-2021, 09:17 AM #1
Huskers79 Huskers79 is offline
Huskers79 is on a distinguished road
Question Sulfur Smell
Good morning,
Approximately two months ago I took my 2016 4Runner (~50k miles) in for an oil change, tire rotation, and the 4x4 (differential) service. When I arrived home from that service I smelled a fairly significant sulfur smell from the driver's side rear. I took it back a week later, and they were unable to diagnose any leaks or issues.
It's now going on two months and the smell persists. It strongest on the driver's side and only after being driven. The smell is much fainter near the exhaust (passenger rear).
I've read lots of complaints with early 4th gen 4Runners, but I haven't seen much with regards to the 5th gen 4Runner. Additionally, I find it suspect that I never noticed this prior to the 4x4 service.
Thank you.
Huskers79 is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 09:45 AM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Rotten Egg Smell???
Rotten Egg Smell from Exhaust
Rotten egg smell from exhaust
Exhaust Smell
Sulfur smell from exhaust around 55-60
Egg Smell... I'm Not Alone?!?!
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 09:57 AM #3
s13koop's Avatar
s13koop s13koop is offline
s13koop will become famous soon enough s13koop will become famous soon enough
s13koop's Avatar
I always associate that smell with a bad battery
00-JZX100
10-Trail Ed.
s13koop is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 11:46 AM #4
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
The rotten egg smell is caused by sulfur in the gas, i.e. cheep gas. Change your brand of gas to a top tier gas and it should go away. TOP TIER™ Gasoline Brands
fkheath is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 01:03 PM #5
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
Originally Posted by Huskers79 View Post
Good morning,
Dog farted?
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 01:20 PM #6
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Gasoline is not the issue unless you get yours from Uncle Mickey Surplus store. It is most likely Cat Convertors (5th gen has several). Usually this is issue in 4th gen and rarely 5th. Have you had any exhaust work done? Is it possible your service added some "cleaning agent" to the gas tank?
<<<< is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 01:27 PM #7
Bassturd's Avatar
Bassturd Bassturd is offline
Bassturd has a spectacular aura about Bassturd has a spectacular aura about
Bassturd's Avatar
I used to get an odd sulphuric type smell coming from my old Tacoma. Some days were worse then others. I got it to go away by replacing the charcoal inside the charcoal canister. Not really sure if that’s were the smell was coming from but at the time it was an easy solution to try and the smell went away. Good luck with yours.
2004 SR5 V8 AWD
Bassturd is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 02:45 PM #8
This is where I'm confused. First poster linked numerous threads where the answer was "it's normal". Others say it is not.
In regards to all of the questions in this thread:
- Gas is from Costco...which is supposedly top tier. Premium doesn't seem to make a difference.
- No "cleaning agents" added.
Why do I only smell on driver's side and not much at all over by exhaust? Peak smell is near the tank. And is there anything accomplished during the 4x4 service that may have caused the issue?
Thank you.
Old 01-19-2021, 03:26 PM #9
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Gear oil can have a strong sulfur smell. The fact that the smell showed up after having the gear oil changed leads me to suspect possibly loose drain or fill plugs. Overfilling and it's puking out the vent. Or plugged axle vent leading to a possible gear oil leak from an axle seal. If it is an axle seal, you will probably see the gear oil running down the inner tire sidewall.
02SE is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 11:05 AM #10
<<<<'s Avatar
<<<<'s Avatar
That is it! Gear oil possibly got splashed near exhaust pipe and when pipe gets hot you smell vapors. Just run trough a car wash with bottom rinse and you will be good.
drivers , gen , service , side , smell
Sulfur Smell rtuck1 4th Gen T4Rs 16 03-24-2012 09:00 PM
Sulfur smell in '04 V6 Border411 Problems & Warranty Issues 0 10-23-2004 02:03 PM
no sulfur smell!!! the_josh 4th Gen T4Rs 3 07-01-2004 02:58 PM
Sulfur Smell Fix?? pbm317 4th Gen T4Rs 1 05-17-2004 04:54 AM
sulfur smell stinky1 Problems & Warranty Issues 1 10-22-2003 08:07 PM
