Originally Posted by Teamoatmealpie
I would advise spending the $30-$50 and get a blue tooth Carista OBDII reader or similar - save yourself hundreds or thousands over the life of your vehicles by being able to know what's wrong versus the Stealer charging you $210 to plug in the same and tell you whats up.
My guess the ABS wire to a wheel got yanked and is not working. Replacement is literally unplug - and plug in a new one.
I have a Carista and use the same one on both my Toyota's.
Ya I’ve got a reader but it’s in Arizona right now. I find figured if the ABS wire got nicked then the ABS light would be on too, this is just the trac light. I made an SST for doing zero points for my last 4Runner, I may just go ahead and try it tonight just to see what happens.
