Old 01-22-2021, 12:11 AM #1
Satweh Satweh is offline
Satweh is on a distinguished road
Failing emissions inspection help? Stating vin is vehicle simulator.
Failing emissions inspection help? Stating vin is vehicle simulator. Mechanic says obd is not communicating with scanner.. I have a 2016 trd pro 4runner 50k miles.. only aftermarket parts is a alpine halo 9 and ditch lights..mechanics believes it has to do with the stereo? Please help
Satweh is offline   Reply With QuoteReply With Quote
Old 01-22-2021, 12:20 AM #2
crawlingjunk's Avatar
crawlingjunk crawlingjunk is offline
crawlingjunk will become famous soon enough crawlingjunk will become famous soon enough
Is the radio hooked up to CAN network? If so not can cause data crash.if it only uses the radio harness. (2 plugs) and no can support then it’s not the radio
crawlingjunk is offline   Reply With QuoteReply With Quote
Old 01-22-2021, 12:23 AM #3
It has the maestro rr which gives control to steering wheel for volume..and there’s a wire connected to the obd for tire info and gauges
Old 01-22-2021, 12:27 AM #4
Unplug the rr and the obd2 connection.
Old 01-22-2021, 12:41 AM #5
I’ll try it thanks
Old 01-22-2021, 10:33 AM #6
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
in the alpine you should have settings for obd2 communications through the can network.
if you can normally see your tire pressure through the alpine, you probably have it set to always on.
need to turn it off for inspections. the maestro rr only taps 1 wire. at the obd2 connector, but you shouldn't need to disconnect.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
failing , inspection , stating , vehicle , vin
Does a failing CV sound like failing bearing? gaber6 4th Gen T4Rs 8 07-22-2020 02:34 PM
Any way to differentiate between failing double cardan joint or a failing rear most u Anthrax 3rd gen T4Rs 29 04-08-2019 09:49 PM
22R Failing Smog/Emissions Teeth Classic T4Rs 2 11-20-2017 08:19 PM
Noobie here, Vehicle Inspection Question thatsbug 4th Gen T4Rs 1 03-02-2012 01:34 PM
Colorado Emissions Exempt Vehicle keylay31 4th Gen T4Rs 13 05-31-2007 11:14 PM
