Old 02-27-2021, 09:48 PM #76
Carova Colton Carova Colton is offline
Carova Colton is on a distinguished road
I will pull the starter and see if I can test it.
Carova Colton is offline   Reply With QuoteReply With Quote
Old 02-28-2021, 10:47 AM #77
Thanks @Old Red , and Thanks @waypoint . you guys have been great. I’ll get the starter out this week to test and @Old Red work through the process that you send me to rename the VIN and synch the keys with the cable and software.
I’ll let you know where I stand once I get that done. Cheers.
Old 02-28-2021, 11:09 AM #78
freak4life freak4life is offline
Real Name: Rich
freak4life is on a distinguished road
Real Name: Rich
Good man
freak4life is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 11:59 PM #79
I booted up the software and was able to rewrite the VIN on the replacement ECU. I think I programmed the smart key fobs and I did @waypoint ’s pin jump hack with the 4 and 13 slots and paper clip. Next is to re-lace the starter and that camshaft position sensor plug.
Old 03-10-2021, 03:06 PM #80
@oldred, @waypoint , have any of you guys changed out the starter? I got the thing out but not out. I have spun that thing every which way and can’t get it through. I even removed the brake line brackets so I can move it as well. The steering column is in the way and the exhaust. Is there a trick? Only video I saw was for a 4th and 3rd gen and it’s a bit different. Any help is appreciated.
Thanks
Old 03-10-2021, 03:31 PM #81
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Thanks
This might help?
File Type: pdf Pages from 2010 4Runner Repair Manual.pdf (149.7 KB, 52 views)
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 09:19 PM #82
Thanks @Jivewalker . I’ll take a look at the housing removal tomorrow.
Old 03-12-2021, 01:08 PM #83
Had to bite the bullet and take it to an auto electrical place that I know is very good. I know they are going find something easy that I overlooked. Lol
Old 03-12-2021, 03:02 PM #84
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Thanks
This Tundra video might help. Starts talking about starter removal at 8:30. Really shows you at 9:50. They pull it out right behind the CVD/Axle.
https://www.youtube.com/watch?v=LuCMroYHpSI
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 08:39 AM #85
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
I get it. Did you get the starter out and tested?
waypoint is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 01:33 PM #86
Old Red Old Red is offline
Real Name: I no longer post or contribute to site that doesn't value members or their contributions.
Old Red is just really nice Old Red is just really nice Old Red is just really nice Old Red is just really nice Old Red is just really nice
@Carova Colton , any update in regards to the starter and getting everything working?
Old Red is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 06:26 PM #87
Sorry guys. Got the starter out and tested on the bench with a battery. It worked. I must have a disconnect going from the ignition push button to the starter. I sent it to an electrical shop to try to figure out for me. I will spend weeks more on this and they will get it figured out in hours. Hopefully it all works out. I will update when I get it back. Cheers
Old 03-16-2021, 05:14 PM #88
Update. The used ECM that I picked up can’t be reprogrammed. The Auto Electrical place called Toyota and they said that a new ECM from Toyota is required. There is some data that is on the old ECM that can’t be rewritten that is not allowing the 4runner to start. They are not trying to sell me a new ECM, but Toyota is for sure. Does this sound right? I am going to relook at the posts @waypoint and @oldred provided and see if there is a procedure to wipe the old ECU clean for a fresh load.
Old 03-16-2021, 05:15 PM #89
Sorry, @Old Red
Old 03-16-2021, 06:21 PM #90
@Carova Colton , let me do some digging. I don’t buy that ECU has something that can’t be rewritten or reset. There is no difference between the 14-19MY ECM unless it is a 2wd vs 4wd ECU. I’m pretty sure there is a way to reset the ecu.
carpet , disco , dry , engine , seats
WTB 2nd gen 4Runner passenger side headlight Mkrespke Want to Buy/Trade 0 03-15-2017 11:26 PM
My town is flooded, might have flooded my engine. What can I do to fix it? DeadbeatYota 4th Gen T4Rs 36 01-09-2016 09:09 PM
WTB 2013 4runner passenger side rocker panel side skirt vinodmp Want to Buy/Trade 0 10-27-2014 10:52 AM
06 4Runner passenger side mirror hgill For Sale: T4R Items 2 07-08-2014 01:08 AM
