01-24-2021, 08:03 PM
Is there a way to calibrate the speedometer on our Gen 5s?
I was out in my 2020 today and noticed that my speedometer seems to be off, based on what my GPS is saying.
My car will read 70 MPH, but the actual speed is like 67-68 according to GPS.
It's a TRD Pro, so I thought initially that it might have been because of the different wheels and tires, but it it would read the opposite if that were the case.
It sounds inconsequential, but at that rate if the car has actually done 100k miles, the car will read almost 104,500. That's almost 4500 miles, and not insignificant.
Can Toyota handle this?
01-24-2021, 08:10 PM
Real Name: Special Ed
We used to take two Siennas on a 700 mile trip regularly.
One would have 60 miles less over the course of a one way trip, 120 round trip.
OEM wheels and tires on both.
One '03. One '04.
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
01-24-2021, 08:21 PM
The regular answer is no you can't calibrate it.
The more complex answer is anything is possible, but you're not going to want to do it (there are several previous conversations on this forum about it).
FYSA, TRD Pro comes with the same size (265/70R17s) that all other 4Runners come with (except the 20" limiteds).
Upgrade your tire size to 285/70R17s and your speedo will match.
I'm not sure that the speedo and total (not trip) odo are tied together at the same ~4.5% mismatch.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
01-24-2021, 08:29 PM
I use an iOS app called Spyglass to check my speed correlation in all my vehicle so I know if it’s reading high or low, typically calibrate at 70 mph as measured by Spyglass to know if my speedo is reading high or low.
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
01-24-2021, 09:15 PM
Thanks. That’s mind-boggling that it can’t be calibrated, but it is what it is.
01-25-2021, 05:38 AM
Your speedometer is calibrated, just not to the P265/70R17 (31.7" diameter) factory tires. Get some 33" tires and it'll be right as rain. I'm running LT255/80R17 Toyos and it's dead on with gps, as well as those radar controlled speed signs which I've specified on a few projects for the state DOT and verified they are accurate.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
01-25-2021, 11:20 AM
It used to be easier when the speedo was based on the output of a single sensor from the transfer case. In the 5th gen, it is generated by the 4 ABS sensors, so you would need to modify the signal with 4 devices.
01-25-2021, 01:22 PM
Im surprised no one has made either a FTC or NTSHA complaint about this.
Due to the speedometer being different it would affect your warranty. I realize that its usually in the consumers favor, but what if its not?
I also wonder if it affects the vehicle stability system or the abs negatively. Im sure there is some Toyota tech or other manufacturer tech that could tell us if it does. IIRC when i had a GM product it was in the owners manual that aftermarket wheels could mess up the system.
The error, while annoying, is something I can deal with. Getting hurt cause the sensor (abs,vds) is off is not.
01-25-2021, 03:25 PM
It is within an acceptable margin of error.
The ABS and stability control systems are concerned with wheel speeds relative to each other, hence don't care about wheel diameter/exact overall speed
01-25-2021, 06:26 PM
Thank you!
01-25-2021, 07:46 PM
Since my 2nd gen Tacoma days, the speedo has always been off but the odometer is correct on stock tires. Just drive.
01-26-2021, 12:05 AM
Get a ScanGauge and set its speedo with a GPS speed like GAIA or something. Done.
I do that. I need +6% to match my 295/70/17s. You will also get correct MPG.
Bonus! You get less miles on your rig if you dont correct it.
01-26-2021, 12:25 PM
the speedohealer might work? all the information is fed to the speedometer by one wire at the speedometer? Some information like mpg etc might still be off, but the display can possibly be corrected. I have too much stuff i'm working on and haven't had time to try to splice the speedohealer in yet.
I'm running 285/75r17 on 4.88 gears, definitely have a speedometer reading too low at higher speeds.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
01-26-2021, 02:57 PM
Except it's the opposite on mine. When I drive, the car think's I'm driving more miles than I actually am at the moment.
For instance, the car reads about 8000 miles right now. Based on the error, the car has actually traveled between 7650 and 7700 miles. That impacts on my warranty and resale at the very least.
Of course I wouldn't object it it was in my favor, but it's not. The only solution seems to be go up in tire size, which seems kind of funny. We as off-roaders wouldn't object to that too much, but still
01-26-2021, 03:04 PM
I believe the speedometer is intentionally less than actual and the odometer is dead accurate. Have you tested the odometer against the GPS?
My GPS says 70mph when my Speedo says 69mph on 265/70/17s. Speed has always been a MPH under on my 4runners. I tested the ODO many years back on a 3rd gen. While the speed was off, the ODO was accurate.
Its all computers now. The speed and ODO are no longer linked in a linear fashion.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
